Question about Canon Pixma MP500 All-In-One InkJet Printer
Sometimes printer won't turn on and after pressing
Sometimes Canon MP 500 printer won't turn on and after pressing the on off key a number of times, it turns on. Was just printing and it turned off, everything went blank... almost like the power turned off. Pressing on / off won't turn it back on. All power cords are secure. Any help you can provide would be greatly appreciated...
Christine
Error 5B00
Canon PIXMA MP180 All-In-One InkJet Printer
Error 5B00
Jul 04, 2012 | Canon PIXMA MP180 All-In-One InkJet...
How do I replace wast ink tank on canon pixma mp 780 printer
Hello! here is your solution.
1) Press the following keys in sequence: Copy-Menu-Scan-Copy-Scan.
The display will say:
SERVICE MODE
#1 SSSW
2) Press the > key (also labeled +) six times.
SERVICE MODE
#7 PRINTER
3) Press OK.
#7 PRINTER
#1 SSSW
4) Press the > key (also labeled +) four times.
#7 PRINTER
#5 INK ABS CAPA
5) Press OK.
SUCTION
XX (where XX is how full the waste ink tank is as an integer percentage)
Sep 01, 2011 | Canon Office Equipment & Supplies
How can the pixma mp 240 be reset after refilling the ink tanks? Thank you. RJ
Hi rjwebb77,
Here's the steps to reset your canon PIXMA MP240.
  • The printer is turned off and plugged the power cord.
  • Press the button STOP / RESET and hold, then press and hold the POWER button.
  • POWER button is pressed, release the STOP / RESET, then press the STOP / RESET 2 times in a state of the power button is pressed.
  • Release both buttons simultaneously.
  • The printer will proceed in a while (a while), then the LCD panel will show the number zero (0)
  • The computer will detect NEW DEVICE, Ignore it .....
  • Press the power button, then the printer will die.
  • Press the power button again, then the printer will be lit and ready for use.
Hope this helps you out!
Good Luck!
Mar 15, 2011 | Canon PIXMA MP240 All-In-One InkJet...
An error appear in lcd screen of canon Mp550 is 5b00 please send to me an urgent soluation
If you encounter "Error Code 5B00" it means that the Printer Counter Protection is Full and it required a reset and Ink absorber replacement, if you want your printer to work again. There are two ways to reset the Canon MP printer, One is by using a Software tool and the other is manually resetting the EEPROM of the printer. Below is the step by step procedure on how to reset your Canon printer.
1. Using MPtool Software to reset Canon MP Printer
Turn of printer then run mptool software this software automatically detect the printer.
Click reset main and reset platen button in the waste ink counter section.
If you want to reset the cartridge ink level, click reset black and reset color in the ink counter section.
2. Manual Reset of the printer
Turn off the Printers.
Press and Hold the button Resume/Cancel then press POWER button.
Release the Resume/Cancel button while keeping POWER button on press.
Press Resume/Cancel 2 times and then release all the buttons.
When the indicator recorded GREEN - click Resume/Cancel 4 times!
Turn off and On the Canon Pixma MP Printers. And your done.
Feb 21, 2011 | Canon PIXMA MP520 InkJet Printer
En la pantalla de mi impresora aparece error 5B00 digame q puedo hacer?
Feb 02, 2011 | Canon MP490 InkJet Printer
ERREUR 5B00
Jan 17, 2011 | Canon PIXMA MX310 All-In-One Printer
How to set the date and time
You can set the date and time on the machine:
1) Press <Fax>
2) Press <Menu>
3) Use [<] or [>] to get to "User Settings"
4) Use the number keys to enter the date (only use the last two digits of the year) and time (in 24 hr format)
5) Press <OK>
6) Press <Stop/Reset>
Your MP 530 should obtain the time from your computer when hooked up with the MP driver installed.
Jan 14, 2010 | Canon PIXMA MP530 All-In-One InkJet...
How can i empty the ink absorber in canon mp 210
In the ink absorber counter setting mode, press the Stop/Reset button the specified number of
time(s) according to the ink absorber whose counter value should be transferred to the EEPROM.
Oct 12, 2009 | Canon Office Equipment & Supplies
Setting the Canon MP25DV clock and calendar
press clock/calendar once to set date
1) press equal numbers will flash then use number keys to current time then the X to set am and pm. press = again to set time
2)press clock/calendar until date flashes. use number keys to current date. Press = to set
Nov 02, 2008 | Canon MP-25DV Calculator
Canon Pixma MP500 All-In-One InkJet Printer Logo
273 people viewed this question
old marine
old marine
