Question about Microsoft Windows XP Media Center Edition 2005 for PC
BootMGR Mine also says bootMGR is compressed and i really dont know what to do as i have a laptop which came with vista so i cannot use the disk as i dont possess one :(
  • 916 Answers
If the machine giving you this problem has vista on it and you do not have a disk call the manufacturer of the computer. They are required to send you a recovery disc if requested.
Posted on Sep 07, 2009
Testimonial: "thanks"
What happen when pc says bootmgr is compressed?
if you have the OS disk you can use that and fix windows bootmgr.
Mar 09, 2015 | Microsoft Computers & Internet
On display - BOOTMGR IS COMPRESSED i pressed ctrl -alt -del but nothing happened kindly advise next step laptop acer extensa 5620
Here is the fix for Bootmgr problem in Vista/7
Bootmgr Windows Vista/7
For windows XP : Try to fix your windows by selecting repair option.
  • Boot your computer with the Windows XP CD
  • At the first screen select R to repair
  • If you got a command prompt, just type on the command prompt "fixboot" then hit enter.
If those information did not help you with the bootmgr issue, then you might need to reinstall windows on your computer.
Hope this will help
Sep 12, 2011 | Computers & Internet
My laptop says bootmgr is missing and i dont know how to fix
First make sure that all usb devices are unplugged and remove all cd's or dvd's or sd cards etc.
If you are running Windows 7 or Vista you can try do a repair by hitting F8 while it boots and then select repair. If this does not work you will need a install disc. If you have Windows XP you will need an install CD to do a repair. I have attached a few links that may help explain in detail. Thanks for using fixya.
bootmgr-is-missing-error-while-trying-to-boot-windows-vista/">http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
http://pcsupport.about.com/od/findbyerrormessage/a/bootmgr-is-missing.htm
May 15, 2011 | Acer Aspire 3050-1733 Notebook
When pc boots it says bootmgr is compressed and does not boot
Boot using the Vista DVD or the respective OS Disc and use the "Repair Option" or go the next step.
Boot using the Vista DVD or the respective OS disc. Go to the Command Prompt. then type the following.
expand bootmgr temp
attrib bootmgr -s -r -h
del bootmgr
ren temp bootmgr
attrib bootmgr -a +s +r +h.
This should Work.
Oct 25, 2010 | Computers & Internet
BOOTMGR is compressed. Press Ctrl+Alt+Del to restart in Windows Vista Home Premium
BOOTMGR is Compressed
http://img.roxio.com/enu/support/products/backontrack/resolving-bootmgr-error.pdf
follow the steps on the above link and resolve the issue..
It will surely work..
The link is very very helpfull
May 17, 2010 | HP Pavilion dv5170us Notebook
I have an acer aspire 5920 laptop and it wont boot up. displays message BOOTMGR COMPRESSED.
First before doing this you need to make sure you have your windows vista CD.
If you do not you need to obtain a copy of this,
the following site should have all the details you need to make the CD and also to fix the problem :)
To make the recovery cd/dvd you need
http://www.vistax64.com/tutorials/141820-create-recovery-disc.html
to fix the bootmgr problem
http://www.vistax64.com/tutorials/202609-bootmgr-compressed-message-boot-fix.html
Please let me know if you have any other questions
Mar 20, 2010 | Acer Aspire 5920-6335 Laptop
HP Mini 1000 - USB to boot in dos
If you are receiving an error message that Bootmgr is missing, follow the steps in the below link:
http://www.windowsreference.com/windows-vista/how-to-fix-bootmgr-is-missing-error-in-vista/
Insert the Recovery disc and boot of your laptop and Repair your computer
Jun 23, 2009 | HP Mini 1000 Netbook
Cannot restart laptop
"Boot with the Vista DVD, when it enters Setup hit your SHIFT-F10 keys Setup will run "cmd", and drops you to a command prompt that is running with SYSTEM privileges.
Then at the command prompt type the following (hitting <enter>) after each line.:
del bootmgr
ren temp bootmgr
hope this helps! :)
cite: http://www.cybertechhelp.com/forums/showthread.php?t=151686
May 30, 2009 | Acer Aspire 5500 5570-2609 Laptop
Bootmgr is compressed
I know of three solutions, none of them will work without recovery or OS discs, and I can only guarantee one of them--the one that whipes your system. Try these in this order (assuming you have system discs);
#1 Boot from the system disc and choose the "repair" option. This is the quickest fix, and you lose anything.
#2 Boot from the system disc, and in your Start menu search type "Command Prompt". Open Command Prompt and type (hit enter after each line);
expand bootmgr temp
del bootmgr
ren temp bootmgr
#3 Run a full system recovery from your system discs.
Now, if you don't have your system discs, and you're running Windows Vista, there is another possible option. If your computer is fairly new then you probably have a WinRE partition for recovery, (a "factory image" drive)? I won't go into this now, if you have your discs option 1 or 2 should work for you.
Feb 27, 2009 | Acer Computers & Internet
Hard drive compressed/bootmgr compressed
I'm assuming that you are running vista. Try one of the following:
You will require a Vista DVD to boot off of.
Proceed to the System Repair Option, and follow the steps. It should repair your boot sectors..
Or
Once you have booted up, Press SHIFT+F10 to run 'cmd' prompt.
del bootmgr
ren temp bootmgr
Sep 16, 2008 | Computers & Internet
Microsoft Windows XP Media Center Edition 2005 for PC Logo
88 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
