Question about Refrigerators
The back wall of my fridge is freezing up... I had a repair man replace two sensors and to no avail then I replaced the mother board and that did not work either... what now?
  • Refrigerators Master
  • 1,606 Answers
Unplug the refrigerator . Remove the motherboard cover . Remove the blue plug with large wires from the motherboard . Looking at the plug , you'll see wire1,wire2,space,wire3 . Using a short piece of wire with both ends striped , insert the ends into wire2 and wire3 . Plug refrig back in . Look in the freezer at the bottom of the rear wall , for a red glow . May take several min . If no red glow , replace the defrost heater AND the defrost thermostat (bimetal ) . If red glow , bad control board .
The defrost heater and bimetal , are behind the rear lower panel inside the freezer section . The heater is at the bottom of the coils , and the bimetal is clipped on at the top of the coils ( blue and pink wire ) .
Posted on Sep 06, 2009
Have a ge profile refrigerator went completely dead,repair man replaced mother board and control panel still not working, fridge is only 14 months
If there is no power after the repair man replaced the board and panel, the repair job is not complete. Have the repair man finish the job.
May 03, 2016 | GE PFE29PSDSS 29 cu. ft. French Door...
Why is the refrigerated side freezing food?
Your freezer door seal may be the problem forcing the freezer side to work too long, thus affecting fridge side.
May 31, 2015 | GE Monogram ZISS480DRSS Stainless Steel
Wherfe is the defrost timer on the GE PSS25ngmww.is it part of the mother board
sometimes the timers are located inside the fridge side by the light or on the electronic board in the back of the unit depending how old this is.
Dec 16, 2013 | GE PSS25NGM Side by Side Refrigerator
Fridge keeps freezing up have replaced motherboard
What is the model number of your unit?
Nov 23, 2012 | Refrigerators
Idesit built in fridge, compressor running, fridge doesn't seem to be cold although there is a build up of ice on back wall, happened a couple of times , if i defrost works fine for a while then back...
simple thing first make sure the door is sealing properly, unlikely to be this.
push the back wall of fridge with your hand, it should be solid.
if it is spongey it means the insulation has broken down and you need a new fridge
if not the back wall more than likely a blockage in the system, you will need a pot man out to check the system.
if this is the case and your fridge is over 5 years old dont waste money on repairing, buy a new fridge. if under 5 years def contact indesit company
Jun 19, 2011 | Refrigerators
Miela fridge freezer freezes food in the fridge
Most likely reason is fridge evaporator sensor faulty. The sensor is screwed to the back wall of the fridge behind bracket next to light and has a green band near the end . The sensor come as a repair kit (part no. 7323301). Just follow instructions in the packet.It is quite straight forward
Jul 24, 2010 | Miele KFN8762SDED Bottom Freezer...
We have replaced our G.E. side by side refrigerator mother board ,it did fix the problem with the ice maker and water not working ,a week later ,the ice started to build up agian and fridge is not getting...
The bdefrost heater behind the wall inside the freezer is bad if the ice you have is on the back wall of the freezer. Remove the back wall and deice the coils and replace heater. wr51x10101
May 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GSL25JFPA - Freezer not freezin
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
heatman101
Apr 12, 2010 | GE Refrigerators
GE fridge problem
Sounds to me like your man did not know much about the product. You will need a test meter to diagnose this problem. Call a GE authorized servicer as I assume you are not repairing this yourself. Please leave feedback.
Nov 22, 2008 | Refrigerators
Center Column is getting Hot
The light for the filter is not a problem. The thing to check is that the fan in the back is running. It should run any time the compressor is running to cool the compressor. If it is, then you need to pull the front grille or toe kick off and look under the fridge. Is there a lot of dust and dirt blocking the airflow? If so, vacuum it out. If not, pull the fridge out and check behind it. Is there a grate clogged up with dust? The reason the divider gets hot is because there is a freon line running through that part of the fridge to keep moisture from forming around the door seals. If the fridge is not cooling properly (dead fan motor or dirt blocked airflow) then the freon in this line gets very hot and all the pressures in the system rise, eventually leading to the fridge not cooling. Good Luck !
Oct 07, 2006 | Frigidaire FRS23H5AS Side by Side...
Refrigerators Logo
81 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
