Question about Craftsman 25cc Gas Line Trimmer
32 cc craftsman weedeater
What about a 3 fuel line system diagram
#1 Taper
  • 1041 Answers
SOURCE: need diagram on fuel lines on a 26 cc craftsman weed eater
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jun 16, 2009
moretons
  • 155 Answers
SOURCE: GAS LINE PROBLEM
Hi this is the way it should go: 1 from the filter in the tank to the bottom of the carby,2 from the top of the carby to the inlet on the primer,3 from the outlet on the primer back to the tank as this is the return line nothing goes onto it.
Posted on Aug 04, 2009
SOURCE: repairing fuel line on craftsman 32cc weed trimmer.
Cut the end of the line at a sharp angle. Spray WD-40 on the line and fuel tank hole. Slowly screw the line in the tank far enough so you can connect the fuel filter if you are replacing that line. If not just push the line into the tank if you have a two line system. Remember on the fuel primer, the long tip has the line going to the tank, and the short tip has the fuel line going to the carb.
Posted on Sep 05, 2009
  • 52 Answers
SOURCE: need gas line sketch for craftsman brush wacker
Most 2 cycle engines are basically the same. The primer button has two lines coming from it. Gas is actually s.ucked thru the carb and not pushed thru when you prime it. Take a look at the sketch I provided and hopefully you will get yours running again.58fe8f0.jpg
Posted on Apr 26, 2010
rycgl
  • 1545 Answers
SOURCE: Craftsman 32cc Weedeater -- need fuel line diagram
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. co0mpleting the purge circuit. This info pertains to my 2006 Craftsman 32cc with Zama carb.
Posted on Jun 01, 2010
How do the fuel lines in a weedeater trimmer pe550 hook up inside the gas tank
I have an older model that has a weighted filter in the tank. The filter flops around and can 'fall' into the fuel no matter which way you tilt the trimmer/tank. You should have one in your tank. Feed in the new line and make the end come out the gas cap. Push the filter/weight into the end of the fuel line. Pull the extra fuel line out of the tank to match the original position. You should have cut the new line to approximately the proper or same length as the old fuel line with an angle cut so you could push it into the tank.
Jul 23, 2014 | Poulan Craftsman/poulan/weedeater Fuel...
Why does the fuel not stay in the primer bulb, when I prime the craftsman weedeater with sim-pul
Fuel lines probably need replacing. Have you been using ethanol? The alcohol eats the fuel lines on most 2 cycle motors up.
Jul 06, 2014 | Craftsman Convertible 25cc. Gas Line...
32 cc craftsman trimmer starts but will not run at full rpm
Air fuel mixture problem,,,you need to have the filter pulled out and cleaned. Check fuel system for debris and clean, that includes all the fuel lines and possibly disassemble carb and clean and reassemble.
Apr 27, 2010 | Craftsman 25cc Gas Line Trimmer
I'd like to have a little diagram of the correct possition of the gas hoses coming from the gas tank to the primer and carburator for a Sears Craftsman 26 cc blower 150mph 340cfm
unfortunatly there arent any diagrams, my best advise would be to install the fuel lines leaving excess to trim off as you route them betwixt and between. remember that the fuel lines complete a circuit and that the primer bulb does not pressure up the carb, all it does is circulate fuel through the system and makes a loop
hope this helps and good luck
Nov 20, 2009 | Craftsman Garden
Diagram of fuel line for Craftsman 16" chainsaw
Your saw is a Poulan. Try converting the cc to a model number. A 2.2cc Craftsman is often a Poulan model 2200. go to this link and find something that appears the same under (POULAN-WEED-EATER).
http://www.ordertree.com/cms/illustrated-parts-list/9788.html
The IPL will help. Pay attention to the year there is a different area for older saws.
For a current saw Craftsman should have something available.
Sep 04, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
GAS LINE PROBLEM
Aug 02, 2009 | Craftsman 25cc Gas Line Trimmer
My craftsman weedeater just shut off while I was using it. It had ran for about 20 min with no problems? Anythoughts...and yes it has fuel
Check 3 things: 1-are you getting spark/ is the plug good
2. is the carb getting fuel/ is carb "jammed" or is there a line pinched or broken 3. Do you have compression These are most common things to check that usualy resolve the prob.
Jul 10, 2009 | Craftsman 25cc Gas Line Trimmer
My craftsman 32 cc 2 cycle line trimmer doesn't
Check the line head and cable, there may be grass or something like twine twisted between the shaft and housing. If nothing is found there take the spark plug out and see if it will turn over, possibly liquid gasoline has gotten into the cylinder somehow.
Jul 05, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 25 cc weedeater keeps shuting off, was running fine
Probably fuel line into tank has hole in it, If over 5 years old these fuel lines become brittle and break easy. Go to local hardware or repair shop that has small engine parts and you should find the fuel lines. Be sure to take sample with you as there are many sizes. If you have trouble installing them get back to me. Be sure you know how the lines are routed before removing.
Apr 05, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 25cc Gas Line Trimmer Logo
521 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
