Question about American Standard 2771.002.021 Cadet 5' x 36" Bathtub, Bone
Cadet 5' x 36'' Whirlpool white 2771.018W. Bath is filled, turn on, buzz for a few seconds stops and dosen't do any thing. After a few minutes buzz again as if it wants to turn on but nothing.
    Scholar:
  • 80 Answers
From the sound of it the pump has seized and the thermal breaker is tripping causing the off and on buzzing sound. The problem could be in the motor or the pump attached to the motor. The easiest way to check this is to pull the pump/motor assembly out and check the rotation of the impeller. The impeller should spin freely with no drag. Most pump/motor assembly have a screw slot in the back under a plug or just open in the middle of the back of the motor. In some cases this test can be done without removing the pump/motor assembly. If the motor and pump do not spin freely, puchase a new pump and motor as one unit..
Posted on Sep 06, 2009
American standard jet bath tub black particles coming out of jets
The problem you are experiencing is common to many jetted bathtubs.It is a result of dried bathing water in the tub. There are a couple of solutions to resolve this ongoing problem.
  1. Use your tub more frequently as the water will not have time to fester in the pipes.
  2. Use a cleaning solution made for cleaning the pipes on jetted bathtubs once every three months.
You find Cleaning and Maintenance Products for jetted tubs at the following website. US Parts Center
Rod
US Parts Center
888-521-6183
Feb 25, 2013 | American Standard Evolution Oval Comfort...
The oil was low in my Cub Cadet SLT 1550 so i filled it up, and after about 5 minutes the engine started smoking blue, smelled like oil and after a few seconds it turned really cloudy white
remove the spark plug and try and crank it over see if oil spits out you might have dumped it in to fast and it went threw the breather
Jul 10, 2012 | Garden
Jacuzzi whirlpool bath not working when i turn it on i get a buzzing sound
buzzing sounds tend to be a motor problem. You may need to change the pump. When you turn it on it just buzzes? that indicates a bad motor.
Dec 20, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Our fridge is making a loud humming noise ..when you turn the cooling knob to #1 setting it stops but then starts againa few minutes after you turn it back to 4
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Sep 17, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Thor 806 washing machine buzzes, doesn't fill
Check the water supply. Possible problem with the solenoid on inlet. Or timer if old machine.
Sep 20, 2009 | Whirlpool WFW9200S Front Load Washer
Odd buzzing after timer stopped, food was still being heated
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
r6uw
Aug 20, 2009 | Whirlpool MH1150XM Convection/Microwave...
Two jets stopped working
Most of these jets turn to close. Check if you turn the nozzle. Hope it helps
Jun 04, 2009 | American Standard 2770.018w.020 Cadet...
Whirlpool pump only buzzes.
Well there are two things....You say "buzzes?" Like pump is running "humming" & not pushing water. That would be an "airlock" in the pump & it needs to be primed.
If it's "buzzing" & pump motor is not turning (Like it's froze) you might have a bad start up capacitor on the pump that needs to be replaced. Worst case scenerio entire pump needs replacement.
Jan 13, 2009 | American Standard 2770.018w.020 Cadet...
My machine runs for 5 seconds and stops for 15 minutes
The spinning motor are not turning / try it manually /if okey / the timer contactor is malfunction.
Jan 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
American Standard 2771.002.021 Cadet 5' x 36" Bathtub, Bone Logo
126 people viewed this question
Top American Standard Home Experts
Mike
john h
Tom Chichester
Are you an American Standard Home Expert? Answer questions, earn points and help others
