Cant reprogram my sat dish
I,m trying to repair my sat dish with the program called loader 2,,. This program worked great on my windows xp home pc but when i got this new one wich has windosw vista pre,,I cant get loader 2 to work at all !! EVERY TIME I TRY TO RUN IT THE SCREEN STARTS FLASHING OFF AND ON AND I HAVE TO REBOOT !!!!! Does anyone have a fix in mind or do i have to sticl with windows xp ??
  • cn chuck Dec 11, 2007
    Thank you very much fedarion for the reply ! Do you think i should move this question to another topic ? maybe i put this in the wrong one ?
  • 33 Answers
If you haven't already, try running the program in Vista's compatibility mode for XP. This page has instructions on how to do that.
If you've already tried that, or if it doesn't work when you try it, the program may simply be incompatible with Vista; if that's the case, you'll have to wait until the program's author releases a Vista-compatible version.
Posted on Dec 10, 2007
I cant get my guide to come up. How do I correct this? Thanks in advance!
Have you tried unplugging the receiver for 10 seconds? Also, do the other functions on this remote work properly? You can also try reprogramming the remote by pressing the system info button on the front of the receiver and pressing the "SAT" button you should hear three tones confirming it worked. If you need further assistance e-mail me at daniel.busa@dishnetwork.com
Daniel Busa
DISH Network
Customer Service
Jun 23, 2011 | DISH Network 32 Ir 137180 Remote 5900 3100...
HAD REMOTE2 set to turn on/off LG TV. trying to reprogram and it wont take code nor scan to find. Sat works tv does not.
dmmcgregor
I'm sorry you are having problems reprogramming your TV 2 remote to your LG TV. Have you replaced your batteries? If so, I have provided a link on how to reprogram the remote and how to perform a power scan. I will also give you several codes that should work with the LG TV. This is the link with the instructions for programming the remote to your TV. It begins with step 6.
http://www.dishnetwork.com/SupportSection/power-scan-instructions
If you have any other questions or problems, please respond to this site.
Ray Calo DISH Network
Jan 22, 2011 | DISH Network IR Remote Control
Will not function with Windows 7, what is wrong?
Not all programs that worked in Windows XP will run in Windows Vista or Windows 7.
I suggest you try compatibility mode to see if it helps.
If the program is not compatible, then you may try to install and run the program in compatibility mode.
Use the following steps:
1) Right click on the Program
2) Click on Properties
3) Click on Compatibility tab
4) Select Run this program in compatibility mode and select Windows Vista or whatever operating system the program was running successfully.
Refer to the link here: Make older programs run in this version of Windows
http://windows.microsoft.com/en-us/windows7/Make-older-programs-run-in-this-version-of-Windows
If the compatibility is not successful, then try and runthe Program Compatibility troubleshooter:
1. Open the Program Compatibility troubleshooter by clicking theStart button.
Then click Control Panel. In the search box, type troubleshooter, and then clickTroubleshooting. Under Programs, clickRun programs made for previous versions of Windows.
2. Follow the instructions in the troubleshooter.
If you cannot install a program, insert the installation disc for the program and, using the troubleshooter, browse to the program's setup file, usually called Setup.exe, Install.exe, or something similar. The troubleshooter is not designed to work on programs that have an .msi file name extension.
If you run Windows 7 Professional or Ultimate version, install Windows Virtual PC and Windows XP mode (http://www.microsoft.com/windows/virtual-pc/default.aspx) and execute your software in Windows XP.
If you run Windows 7 Home Premium, try VirtualBox (www.virtualbox.org) or VMware Player (www.vmware.com) and install a separate copy of Windows XP (either Home Edition or Professional) for that purpose.You can find virtualization software free of charge that will run on Windows 7 Home Premium.
Hope this helps.
Oct 28, 2010 | MGI Software PhotoSuite 3 for PC
When I installed and tried to run your program I get the following error: This application requires using the 4.73 help system or a more recent version. I am running Windows 7. What is the problem? Can...
The specs for that program shows the last operating system it was designed for was XP. Let's try the easy fix first. ClickStart, type Compatibility in the search field, and click theEnter key. This will bring up the Program Compatibility troubleshooter. ClickNext and it do a quick check on your machine. It will ask you toSelect the program you're having problems with and click Next. Click Troubleshoot Program, then check the box forThe program worked in earlier viersions of Windows... Click Windows XP (Service Pack 2)and click Next. Click the box for Start the program. It will attempt to open the program as if you were running XP. After the program attempts to open, clickNext. Now it will ask if it worked for you. If so, click Yes, save these settings for this program. If you clicked Yes, every time you open the program now it will open as if it was running in XP. You're done if this worked!
Sometimes that method doesn't work. For those cases, there is a new feature called XP Mode, which will install a virtual machine for you to run your program in. It's not too hard to get configured; it actually installs a legal copy of Windows XP for you to run your program in. Here's a Microsoft article on how to get it set up: http://www.microsoft.com/windows/virtual-pc/. XP mode will now work even if you don't have the chip installed for Hardware Assisted Virtualization Technology.
Sep 02, 2010 | Anuman Interactive Home Budgets for...
We just got a new Dish HD/DVR Receiver and need the remote code for the Bose remote control to operate it.
Here is what I did for my Bose Solo Tv to work on the Bell 9242 receiver.( see page 17 of Bell 9242 guide) 1. Hold down the aux button until all lights flash. 2. Press 2 to ensure Aux is set to audio. 3.Enter code 761 and press the pound (#) button. Now to have the satellite remote default volume to Bose Solo do the following. 1.Press and hold AUX 2.press # pound 3. Press the + side of volume 4. Press 0 5. Press pound ( AUX button will flash 3 times) 6. Press SAT mode 7. Test the volume on Bose Solo. (see page 22 of Bell 9242 guide)
Jul 05, 2010 | Bose 3 2 1 GSX System
Dual Boot problem in Windows XP & VISTA
Don't try to edit the xp boot.ini or the vista bootloader. It only leads to other problems and headaches.
Try this first: Take note as to which drive has vista on it, put your vista installation cd in the drive and let it boot to the "installation window", then choose "repair", then "startup repair." Make sure you choose the drive that already has vista on it. Let that run and when it re-boots you should then be given a choice to boot to vista or "other windows".
There is also a (free) program called EasyBCD. Download that, read the directions and have at it.
If none of that works, you'll have to do a clean install. Install XP on one drive first, then Vista on the second drive in that order. The Vista bootloader will pick up the XP. However, XP is NOT forward compatible and will not recognize the Vista bootloader. Make sure that you don't have any flashdrives or media cards plugged in before doing the install.
Another approach would be to shrink the Vista volume, creat a new partition, then install Linux Ubuntu that partition. Linux will detect all of the OS's and create a boot menu. Unfortunately, you'll lose about 5 gigs to the Linux OS and it's swap partition, but then, you get to goof around with Linux :-)
Feb 25, 2009 | Microsoft Windows Vista Home Premium with...
Forgotten admin password
Try this http://home.eunet.no/pnordahl/ntpasswd/ i have used it on a cuople of computers and works great.
Jan 19, 2009 | Microsoft Windows XP Professional With...
Windows installer is not working
You have to re-install the Operating System. Do you have the discs to re-install it? You will be prompted after you put the discs in to choose what you want to do. Choose 're-install windows XP' or whatever your OS is called. It will walk you through the prompts.
Jul 11, 2008 | Microsoft Windows XP Home Edition
Ihave a SmartScan 2700. It was working great until I switched from XP to Vista Home Premium. I downloaded and installed the Cyber X program. The program doesn't work and a message comes up that states...
I have a new Reflecta DigitDia 5000 slide scanner & during almost every scan this message comes up & it stops functioning "Pfs Loader MFC application has stopped working".
I am using Windows 7 Premium.
Any ideas?
Apr 06, 2008 | Office Equipment & Supplies
Killer.exe virus
dont be afraid, go to www.nod32.com and download the v.3.0
work well
Sergio
Mar 09, 2008 | Microsoft Windows XP Home Edition
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
