Question about Whirlpool LEN2000PW Dryer
I have a Whirlpool LEN2000PW1 dryer. It runs, but
I have a Whirlpool LEN2000PW1 dryer. It runs, but does not heat up. It stays cool.
  • 304 Answers
Unplug unit . Check to be sure you have 240 Volts at wall outlet.
Most parts likely to fail on electric dryers are inside the rear cover. Heater is on right inside can, safety thermostat on lower left of can, High limit thermostat (non-resettable) higher left of can.
On the blower housing to the left are the operating thermostat and, in some models, a thermal fuse (white plastic). ALL can be continuity checked easily. Always disconnect wire on one side of what you are testing. One will likely be open. Replace the component that fails the continuity test.
Heater replacement sometimes requires lifting of top. Under the lint filter cover there are two screws. Remove them WITHOUT dropping them into the vent or you may cause a more serious problem. Insert a putty knife between the front and top about 2 inches in on both sides. This will release the top for raising. Good Luck
Posted on Sep 06, 2009
Whirlpool Duet dryer runs way too hot, even during air only cycle.
sounds like restricted air flow to me . check filter and the vent for plugged pipe
Apr 18, 2012 | Whirlpool WED9400S Electric Dryer
Whirlpooldryer LEN2000PW1 when you shut the door turn the dial you hear a clicking sound and doesnt tumble. Belts not broke and you can turn motor manuelly.
This is a symptom of a blown thermal fuse located on the blower housing. It is wired in series with the motor and therefore cuts power to the motor when it blows and results in the motor not running. No dryer function works when the motor is not running. Remove the rear access panel and locate the thermal fuse. Replace it if found blown open including the cycling thermostat. Click on the link below for the detailed troubleshooting procedure.
Troubleshooting Not Starting Whirlpool and Kenmore Dryers
Apr 04, 2011 | Dryers
Dryer heats for about 1 minute then stays cool for rest of time. Any ideas?
Is it possible that the problem you are experiencing may be caused by a worn heating element or the fuse associated with the forementioned component?
Sep 28, 2009 | Whirlpool LEQ8000JQ Electric Dryer
Whirlpool dryer model LGQ80000JQ4 starts to heat and runs then stops heating, but rest of dryer seems to run fine
Hello, This problem is going to be your safety valve coils...basically they get old and over time of heating then cooling develop a short when they heat up...It may appear the gas lights to start but then goes out until the safety valve coils cool back down. Here is a picture of the coils 57d5263.jpgThis The coils are mounted to the gas safety valve, This should solve your problem. Hope this helps, Please feel free to comment again if you have any further questions or concerns. Good Luck! Mike
Sep 18, 2009 | Whirlpool LGQ8000JQ Gas Dryer
Heat will not stay on
Hi, very common problem.
The problem is with the gas coils.
When they get weak, they only come on for about 10 minutes and then the machine will blow cold air. There are 2 of them with one being the booster coil. They come in a pair and run less than $20.
Best of luck. Please e-mail me if you have any other questions.
Sep 15, 2009 | Whirlpool LGN2000LWH Gas Dryer
Whirlpool gas dryer heats for one cycle, then cool air only.
Yes , replace the coils . Should take care of the problem .
Jul 13, 2009 | Whirlpool Dryers
Whirpool dryer won't heat up
You need to replace the thermal fuse and the timer. A bad timer will over draw a thermal fuse and cause it to blow.
Please remember to unplug the dryer before servicing
Mar 28, 2009 | Whirlpool LER5636P Electric Dryer
Dryer not going to cool down cycle, thermal fuse failed 2x
Most problems like this arise from air flow problems. You need to break down the dryer and clean out the lint. Including removal of the filter housing.making sure your outside vent is clear as well.If that fuse keeps blowing you especially need to remove and rinse out that filter housing.
Dec 30, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool LEN2000PW Dryer Logo
461 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
