Question about SanDisk Sansa e260 MP3 Player
My Sansa Fuze Screen is blank
After I turn on my Sansa Fuze the screen lights up but with no images or menu options available. It also seems to stuck in the radio mode I cna't get to any of my songs in the library. The sreen remains blank but lighted. I've tried several methods to reset the device with no luck.
  • 3 Answers
SOURCE: Sandisk Sansa e260
u have to wait till the screen will be black. I had the same problem with my sansa. it can lasts 1 or 2 days. after screen is black and then do following: 2. change lock switch to orange position 3. Press and hold rec button (at left side) 4. while pressing the rec button, turn the player on 5. it will appear the boot menu. connect the USB cable and try to continue the firmware 6. if it doesn't work, do a firmware downgrade. download this file: http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe 7. execute the application while in boot mode good luck darek
Posted on Apr 04, 2007
  • 7 Answers
SOURCE: Nothing except for "sansa" on the sreen.
there is some problem in sansa's firmware so load firmware from the CD which provided with sansa m240 it will work ...
Posted on Jan 15, 2008
  • 51 Answers
SOURCE: i lost my sansa fuse driver. were can i find a new driver?
just connect it to your computer...open it as a external hard disk and copy paste songs on to it...it should work...
Posted on May 21, 2009
SmartAviator
  • 449 Answers
SOURCE: Sansa Fuze not being detected
Try using it with Power Switch to ON position. Ehtesham.
Posted on Jul 12, 2009
meeknotweak
  • 341 Answers
SOURCE: my computer doesn't recognize my sansa fuze and i
On your Sansa Go to "Settings" then "System Settings" then "USB Mode," change it to MSC, now try connecting it. If that doesn't work try the other modes just in case.
Hope this helps.
Posted on Sep 29, 2009
My sansa fuze 8g won.t turn on, the sreen is blank when I put it on, the wheel is still there but I cannot choose any program because nothing can be seen
images?q=tbn:and9gcsb9oziak98wfbldmcvinyavo_rmsvbsyuocssrou-epn-nmma4bqimages?q=tbn:and9gcrpr6kd-tlf1-2z44vxjzmisxr6eqaymcupuii2vgslv7lxdpkifawhich one?
i have a decent amount of knowledge concerning the left picture. your problem is a little vague but i think it may be broken. let me start with the basics. the sansa fuze has a hard reset function that when you hold the slider to the right for a few seconds it turns off. when released it should slide back to the left. when you slide it again it turns it back on "boots". now you say it is a dark screen, but are the lights on the wheel on? when the ribbon cable to the wheel is loose or broken 1 or more of these lights usually go out. if you take a flashlight and shine it directly into the screen do you see any image. it is easier to see when moving through the menus.
Nov 26, 2013 | Audio Players & Recorders
I was charging my Sansa Fuze and when I disconnected it from my desktop, I got a blank screen and now it won't turn off
If your device freezes up press the Menu button and hold for 15 seconds.
This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
Apr 08, 2010 | SanDisk Sansa Fuze MP3 Player
Theres a blank screen after charging mp3 it wont turn off
Press the power and the Play (>||) button together for 20 seconds to reset the unit
Feb 28, 2010 | SanDisk Sansa Fuze MP3 Player
I have a sansa fuse and a jvc home theater. when i plug the sansa into the jvc's usb port all i get is ''reading'' on the jvc display screen and connected on the sansa screen. Do i need a memory card?
Your Fuze MAY have an option to change USB modes If it has this option, go into the "Settings" menu and under "USB" change the mode the Fuze uses to communicate and see if that helps.
Keep in mind, changing it will affect how it connects to the computer too, so you may have to change the setting each time you switch between the computer and the home theater, unless you find a mode that works for both.
May 03, 2009 | SanDisk Sansa Fuse MP3 Player
My sansa fuze screen goes black whenever i move the wheel or push a button. it comes back on in aprox 5 seconds but as soon as a buttons push of wheels turn it goes black.
I have the same problem.
Only work around I found was installing Rockbox, then in the settings turning off the wheel light.
Seemed guessing cable issue?? once wheel light when out, the screen would come back.
Dec 19, 2008 | SanDisk Sansa Fuze MP3 Player
Sansa fuze 2gb is screen is white
If you just bought it, By all means return it!  Otherwise call sansa tech support.  The're rather good for tech suppport people.  If you bought an extended warranty, the place you bought it from should replace/repair it and you troubles will be over!
-Aptera
Nov 24, 2008 | SanDisk Sansa Fuze MP3 Player
Can not get the image back on my astar hdtv when I choose the option
First check Tv menu comes on screen?
Connect DVD Player at any a-v input and confirm picture on tv. This will confirm that tv has no problem except in tuning circuit.
Now check Antenna / cable hooked up in RF input of tv properly.
Perform Auto-Search / Auto-Tuning / Auto-channel on TV menu and tune all available channels.
Still blue screen? means TV Tuner looks bad.
Sep 16, 2008 | Astar Televison & Video
Frozen
Reset your Fuze by holding the power slider switch in the "On" position for 15-30 seconds. Release the button once the unit begins to power down.
Jul 02, 2008 | SanDisk Sansa Fuze MP3 Player
SanDisk Sansa e260 MP3 Player Logo
378 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
