Question about HP Photosmart C3180 All-In-One InkJet Printer
My hp photosmart C3180 printer isn't working- it just keeps saying 'printing has stopped' and it adds the print job to the quere. The copy machine works just fine, I have ink, paper-- what should I try now?
  • 1 more comment
  • bchite Sep 06, 2009
    I was able to un-install the software, but can't get it re-installed....
    I have a Mac OS X
    Thanks
    The USB port I had the printer plugged into must be 'bad'. It was plugged in a TECHGEAR 4 port hub, not in the back of my computer. It's been in that port for awhile, do you know why this problem would have developed?
    When I plugged the printer into the usb port on the back of my Mac, it worked. Prior to moving the plug into the other port, the download would not work...
    thanks for your help! :)
    Brigadier General:
  • 8,619 Answers
Hi
The first thing you need to do is unplug and re-plug the printer. Also, Please click on this link for the step by step instructions:
HP Photosmart C3180 Not Printing
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 06, 2009
  • Rylee Smith
    Rylee Smith Sep 06, 2009
    You can download the drivers from the below link:
    HP Photosmart C3180 Software & Drivers
    Thanks
    Rylee
  • Rylee Smith
    The issue could also be due to bad USB Cable. You need to check the cable if the cable is fine then its definetely the port which needs to be replaced.
    Thanks
    Rylee
How do I get rid of shadows on my printing from my HP Photosmart C3180 printer? There is an extra shadow behind EVERY single piece of text. It makes the whole page look blurry. It isn't as if t
I have a Canon printer. Whenever pictures or text gets a double or blurry image I open the printer solutions menu. It sounds as though there is a problem with inkjet alignment. By clicking the realignment button the printer will automatically realign the jets. I usually test the alignment by printing a page from that program. All the line segments should line up.
Jan 01, 2013 | HP Photosmart C3180 All-In-One InkJet...
Why is there 'ghost printing'/shadows on my HP Photosmart C3180 all-in-one printing?
Clean the Carts with Isopropyl Achohol, Open the printer settings, right click on the Printer Icon, open properties, Maintenance, clean print heads.
Dec 31, 2012 | HP Photosmart C3180 All-In-One InkJet...
My hp photosmart c3180 printer keep saying check paper when im trying to print or copy something.
please disconnect the power cable from the wall outlet then press and hold the power bottoum for 20-30 sec then restart
and try to print test page and copy if still it not work then follow this instrution mention from the below URL
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00652863&cc=us&lc=en&dlc=en&product=1146331
if still your problem is not resolved then contact HP toll free number 1800-474-6836.they will replace your printer if its under warranty.
thanks
regards
Hamid
Feb 25, 2010 | HP Photosmart C3180 All-In-One InkJet...
Region codes for France for a photosmart c3180 all in one
Well I had the exact same problem with a C3180 bought in the USA and I moved to France. I called the HP tech support and after I bought 5 brand new cartridges upon their recommendation we haven't been able to print the 10 tap test page
I recommend that you try doing that before you call them otherwise you will be wasting your time
To print the 10 tap test page you need to press simultaneously CANCEL and START COLOR COPY. I couldn't print the 10 tap test page because the printer will not recognize the cartridges bought in France (START COLOR COPY and START BLACK COPY blinking + E in front of COPIES)
If somebody knows an alternate method to print the 10 tap test page, please share it as this is the blocking point with HP support
Thanks
Feb 10, 2010 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C3180 prints a solid black line left side of paper ONLY when you COPY. When you print from computer, it prints just fine. It is only from COPY mode that the solid black line appears.Already...
Unfortunately, your C3180 printer needs some repairs done to it or you . A section of the printing arm that does the printing is faulty. This happened to me and apart from replacing the arm (at considerable cost) I purchased a new printer at a much cheaper cost. You can use your faulty printer for printing from the computer but not for copying or scanning. MG
Jun 08, 2009 | HP Photosmart C3180 All-In-One InkJet...
Unable to add a functioning (second) printer, for greyscale.
Clicked on Start/Control Panel/PrinterI. Clicked Add a printer. Obtained (Copy 1) of my HP Photosmart C7280 all-in-one printer. Right clicked on (Copy 1)/properties. Opened Ports tab. Saw comment "Print to the following Ports. Documents will print to the first free checked port." A listed USB Virtual printer port, showed three printers -- my first printer, my copy 1 (& my fax printer) -- was unchecked. I placed a checkmark in this Port box. Both the original printer, and my copy 1 printer are printing just fine. *I have not checked to verify that my fax is functional.
I did rename the original "color". I renamed Copy 1 as "grayscale", and --under printer preferences, checked, under "color options", to print in greyscale.
Mar 30, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP Officejet J5780 All-In-One Won't print double sided with Vista
You can install an instance of the Deskjet 6500 series drivers using "Add Printer", local printer, (use the same port the J5780 is installed on). You can have this co-exist with the J5780 driver and you could name it J5780 Duplex if you wish.
Regards,
Bob Headrick, MIcrosoft MVP Printing/Imaging
Mar 02, 2009 | HP Photosmart C3180 All-In-One InkJet...
PRINTING IN BLACK ONLY
My solution would be stop typing in caps so I won't hesitate to help you, but my solution is to just buy the ink cartridges or get an old, black only printer instead of a $120.00 HP All-In-One c3180. I have one and I cant use it for some reason, but I'm trying to get it to work desperately...
Jul 25, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C3180 All-In-One InkJet Printer Logo
53 people viewed this question
Seeker5211
Seeker5211
