Question about Malibu Intermatic Inc. ML300RTW 300-Watt Power Pack with Timer and Ground S
Where is the manual ON/OFF switch on the ML300RTW
    President:
  • 704 Answers
It is located next to the mechanical timer wheel. It's not so much a switch as is it a small black stem that you have to turn (clockwise) to turn the timer ON or OFF without advancing the timing wheel.
Hope this helps and you find it Very Helpful - best regards!
Posted on Sep 09, 2009
I have a Malibu 300 watt ML300rtw, timer goes until it reaches "on" pin then stops. if i manually turn timer, i hear click and lights go on - they turn off no problem. pins are not broken. what next?
Sounds like the mechanical timer assembly likely has never been lubricated, You may use a lightweight oil, such as WD-40, to lubricate the timer mechanism.
May 09, 2015 | Malibu ML300RTW - Low Voltage Power Pack...
Lights not working
Check if outlet has power.
See if manual override switch will turn lights ON.
Copy following link for full Malibu troubleshooting resources.
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Jul 19, 2012 | Intermatic Malibu 300W Power Pack...
Lost manual for ML300RTW transformer. Does this transformer have an override so I can plug into exterior timer? If so, where is it?
Yes power pack has override, depending on model.
There should be a small knob located above and to left of dial that rotates: Step 8 in Manual says: You can manually operate the lights by turning the Manual ON/OFF Switch counter clockwise.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/professional%20lighting/ml300rtw%20ml300rtwsn%20trilingual.ashx
For information on Intermatic/Malibu power packs showing links to manuals, troubleshoot steps, replacement trippers, useful links, warranties and tips:
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 02, 2011 | Intermatic Malibu 300W Power Pack...
How do you set the timer on Malibu 300 watt transformer, ML300RTW. I have the pins in the right spots, but the timer doesn't go around. I there a on/off switch to activate the unit?
Make sure there is power to the plug. Then set the clock and install the on and off pins to control the lights. The on/off switch is for manually turning on the lights. The clock should run as soon as it's plugged in.
Jul 01, 2009 | Malibu Intermatic Inc. ML300RTW 300-Watt...
Malibu Intermatic Inc. ML300RTW  300-Watt Power Pack with Timer and Ground S Logo
401 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
Scott Jelt
Scott Jelt
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
