Question about Apple MacBook Mac Notebook
My Mac Book will not work i plug in the power cord and turn it on you can hear the fan going but nothing will turn on and i leave it alone and the fan will go on forever without any progress. help please
  • 1,305 Answers
Have your Mac OS disc handy, start your computer, as it starts, press and hold the power button, this will cause the mac to shut off. Then push the button again, while it is starting push your os disc in the drive. The goal is to get the computer to load the OS disc so you can access the Disk Utility program from the file menu.
If you're having trouble getting past the fan still, restart while holding the commnad, option, p and r keys together. Continue to hold these down until you hear the start up chime. keep holding and let it do this twice. This is "zapping" thie PRAM ... Then start it again... These should help...
k
Posted on Sep 09, 2009
Compaq presario v6101uswont boot not even start up screen
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
Apr 09, 2012 | Microsoft HP Compaq Presario V6101US...
I have a fujitsu e8410 which will not start up properly, when i push the start button it shows power but then the fan comes on and the cap num and shift lock leds flash and nothing else. can you help?
Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.
Mar 31, 2012 | Computers & Internet
MODEL LT2016U WONT BOOT UP
Is it trying to boot up or is it doing absolutely nothing when you plug in the power cord and hit the power button?
Mar 30, 2012 | Computers & Internet
HP Compaq 6735s Laptop screen was blank when turned on
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous.
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Mar 26, 2012 | Computers & Internet
The Western Digital hard drive My Book Elite does not show up on the computer screen when plugged in to the Mac computer. It has the blinking light that shows that it is thinking, and everything else...
hello
i have the same issue, exact same unit MY BOOK ELITE WD 500G ..
FYI: if this doesnt work, it is a power module (inside the black box, MY BOOK ELITE) needs to be replaced.
UNPLUG both cables from MY BOOK ELITE WD - restart your computer
- with respect to the MY BOOK ELITE WD , make sure the power cord is plugged into AC outlet wall only, and the other end of the USB into computer only -- but disconnect both from the MY BOOK WD ELITE and leave unplugged for 20 minutes .
after 20 minutes have elapsed, plug the USB cable only for 1 minute , into MY BOOK ELITE WD. Then plug the power cord into the MY BOOK WD Elite. see if it works
if this doesn't work, let the drive sit for 24-48 hours.. then repeat above instructions -- this is how i got mine to work again. FYI: To avoid this issue, i just leave the unit plugged in , while computer is running
BUT -- be aware... i use UPS (Uninterruptable power supply) to avoid power failures throughout the house. So , i suggest , if you want to leave the computer running, use a power supply to run the computer if the AC power fails..
please issue 4 thumbs up
Feb 04, 2011 | Computers & Internet
Computer turn on, but when it does it won't POST
It seems like a motherboard issue. It heats up, thus is not able to turn on continuously. You may need to check internal parts embeded on the motherboard llike the fan and processor before you could know what needs replacement.
Jul 18, 2010 | Dell Dimension E521 PC Desktop
I cant reboot my screen its all white.
Turn off the pc, disconnect the power cord. Remove the battery. Leave it alone for a few minutes. Plug in the power cord (do not replace battery yet) and turn it on. If it works, turn it off, remove power cord and replace battery. Plug power cord back in and turn on pc again.
Aug 21, 2009 | Dell Inspiron 1420 Notebook
The hard drive powers up but wont connect
Is the FW drive have been formatted? You may need to run the Disk Utility on your Mac to use the external drive. Make sure you choose FAT 32 as the format option if you want to use the drive in both Mac and Windows machines.
Mar 31, 2009 | Computers & Internet
Macintosh Powerbook G3 will not turn on at all
Hi, Sorry to hear you are having problems,
OK, let's try this, #1, remove the battery, be sure the mac is powered down and the power cord is connected to the Mac and a power outlet.
Press firmly down on the power on button for a solid second then release it.
That should start it up.
If it does work, you can safely insert the battery now operate the mac normally...
If this does not work, is it possible that your stepson eh, may have spilt some liquid into or on the Mac? A small amount of saliva in the wrong place could Kill a mac.... Just a thought..
Mar 18, 2009 | Computers & Internet
It doesn't turn on!
If your Macintosh computer won't turn on, here's how to troubleshoot it. Please keep in mind that although your computer may display similar symptoms that prevent it from showing video, this article discusses what to do if the computer won't turn on, meaning that when you press the power button:
  • You don't hear a startup chime
  • You don't hear any fan or drive noise
  • The power button or power indicator doesn't light up at all
If your computer doesn't display any video, it may display one or more of these similar symptoms when you press the power button:
  • You may hear a startup chime
  • You may hear fan or drive noise
  • You may see the power button or power indicator light up
If any of these conditions occurs, see the Troubleshooting: My computer has no video article instead. If your computer won't turn on, try each of these steps:
  1. Make sure that the power cord is plugged into a working wall outlet, and that it's properly connected to the power adapter. (To check if the wall socket is working, plug in a lamp or other electrical device.)
  2. Make sure that the power adapter is properly connected to the power port on the back of the computer.
  3. Disconnect all accessories that are plugged into the computer, such as a printer, hub, or iPod.
  4. Reset the computer's PMU or PRAM.
    • For a portable (iBook or PowerBook), click here for instructions.
    • For a Mac mini, click here.
    • For an iMac, click here.
    • For a Power Mac, click here.
    • For a Mac Pro click here.
    • For a MacBook or MacBook Pro, click here.
    • For any other computer, click here for instructions on resetting the PRAM.
  5. Try plugging a different power cord into the computer (if you have a working one available). If the computer starts up, replace the old power cord. You can get a replacement cord for some models here.
  6. If the computer uses a power adapter, try connecting a different power adapter to the computer (if you have a working one available). If the computer starts up, replace the old power adapter. (Computers that use a power adapter include MacBook, MacBook Pro, iBooks, PowerBooks, Power Mac G4 Cube, and Mac mini.)
  7. If you tried all of the steps above and the computer still won't turn on, contact Apple technical support (1-800-APL-CARE in the U.S.) or take your computer to your local Apple Store or Apple Authorized Service Provider (AASP) for diagnosis.
Feb 22, 2008 | M-Audio US85100 Keyboard
Apple MacBook Mac Notebook Logo
267 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
Martin Buck
Martin Buck
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
