Question about Kenmore 3.2 cu. ft. Plus Top Load Washer
Rinse and spin cycles don't work the wash cycles work fine but water won't drain out after wash cycle you can hear the cycle timer ticking but only for a few minutes then the machine just stops working at the rinse cycle. it does it on every one of the types of wash cycles. Heavy, perm press, delicate, etc.
  • 89 Answers
Check the lid switch sounds like it is bad this is a common problem with whirlpool washers
Posted on Sep 07, 2009
Hi my washing machine works perfectly fine but the water don't pump out srew out bottom filter is clean and I clean it on a regular basis. Defy 1300 laundromaid. Thanks please help
You probably have a rock or some object stuck in the pump blades. Take out the pump and turn the blades get out the obstruction
Nov 26, 2014 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Does not drain and spin
It sounds as if you have a defective timer control. Try operating the washer on a different cycle, if it spins on these cycles the mechanical workings are fine it's an electrical switching problem in the timer.
Sep 17, 2009 | Malber WD1000 Front Load Washer/Dryer
Maytag SAV5910aww will not always drain. Fills and agitates fine but will go through entire cycle without draining. Will sometimes give end of cycle buzz sometimes not. If I am in the room and lift the lid...
"I have found spinning the timer back to begining of rinse cycle first helps". The timer only rotates clockwise; counterclockwise rotation can destroy it.
May 18, 2017 | Maytag SAV5910 Top Load Washer
Spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
May 21, 2009 | Kenmore Washing Machines
Washing machine wont drain or spin all other cycles work fine
you may have a timer problem just advanced your timer on click ahead when it happenes if it drains or spin replce your timer thanks from giles
Mar 14, 2009 | Washing Machines
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 3.2 cu. ft. Plus Top Load Washer Logo
329 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
