Question about RTO Spur Sprocket For Stihl 017, 021 Chainsaws
Stihl 017 that will not throddle up after getting warmed up.
It starts fine an will run properly for about five minutes then will not throddle up almost like it is flooding out. It idles fine and will start fine when warmed up. I have cleaned the filter and the muffler and spark screen.Thank you for your time!
    President:
  • 583 Answers
Isuggest you clean the carburetta does not take much grit or dust to foul up the works
Posted on Sep 06, 2009
017 Stihl chainsaw problem
Could be the spark isn't as strong as you think it is. Could be the spark weakens when the unit is warm. Electronic module ignition needs an energetic pull at the best of times to get a strong enough spark for starting and if it is weaker it would be impossible to pull the starter cord fast enough.
Instead of testing the spark with the standard spark plug try using a spare plug with the gap opened to about 1 to 1.5 mm. The atmosphere in the cylinder during compression is much more dense than in open air and a much stronger spark is needed to jump the gap.
If the spark is satisfactory it could be the crankcase compression that is low, perhaps leaking past the crankshaft seals. If the chainsaw is little used and stands idle for longish periods this could be the problem. Seals tend to lose flexibility quicker under those conditions.
Mar 26, 2016 | Stihl Garden
My stihl sh 55 blower starts then shuts off
If it is getting smokey exhaust befor stopping it is getting too much fuel. If not smokey it is not getting enough fuel. If smokey first take out the air filter and clean it. If it runs fine your done. If not smokey open the high needle valve (marked with an H) on the the carb a little (no more than a 1/4 turn).
Aug 02, 2013 | RTO Spur Sprocket For Stihl 017, 021...
Will a complete engine from a stihl 017 fit into a stihl ms180 chainsaw.
you should be able to get the engine to fit. The 017, ms170 and ms180 are all part of the same family.
Jan 15, 2013 | Stihl Garden
Will a stihl chainsaw engine assembly from 017 fit in a ms180
those saws are part of the same family so there should be no problem putting the two together
Jan 10, 2013 | Stihl 017 Crankshaft Assembly W/ Piston...
Saw has new vent wont run after hot unless i loosen cap
The vent is not working properly or was installed incorrectly, so there is no negative air entering the tank to take up the space of the fuel leaving it for the combustion chamber. Perhaps your tank cap has a vent as well that isn't working.
Aug 05, 2012 | Stihl Chain Saws, 017, 019, 021, 023 & 025
Which is more reliable..a stihl 017 or a stihl 021 ? looking to bid both in good runnung shape...thanks
Hi, you cant go wrong their both stihls. The 021 is a more powerful saw and the 017 is lighter, so it all depends on your intended use. Regards Phil.
Jun 26, 2012 | Garden
My stihl 021 runs for 30 seconds then stalls
remove the muffler and run it after finding that it runs fine open the muffler and clean the screen inside (it is made to open to clean it)
Jun 22, 2012 | RTO Spur Sprocket For Stihl 017, 021...
RTO Spur Sprocket For Stihl 017, 021 Chainsaws Logo
337 people viewed this question
Top RTO Garden Experts
John Trevino
Joseph Mueller
Joseph Mueller
Andy
Are you a RTO Garden Expert? Answer questions, earn points and help others
