Question about Car Audio & Video
Jeep CJ-7 304 V8 motor
Hello
I am builting a jeep 304 V8 engine for my 1984 I have gotten the motor painted and put back together all the way to the water pump to the pullies
top and bottom on the harmonic balancer my problem is
I have bought a HP water pump inwhich I had thougt was the problem untill I had bought a stock water pump but I have put a level on both and they are the same according to the level in highth and the bubble
It seems that the bottom pullie and the water pump pullies are are 1/4 to 3/8 out with the harmonic balancer pullie being closer to the motor and the water pump pullie being a 1/4 to 3/8 away from the motor
These pullies are not lining up together like they should and im afraid that this will jump the belts
Im stumped on this problem what do you think
Thanks Chris
    Sergeant:
    Champion:
  • 362 Answers
Did you put the washer back on the harmonic balancer this very well could be your problem, and did you use the old balance or a new one.but you are right if they dont line up right the belts wont stay on. give me more info. and i can help you get it straight.
Posted on Dec 22, 2007
Where do i get the engine serial number for jeep cherokee v8 2000 model petrol engine
this is only covered in the Real FSM. book
first chapter. in fact.
Identifying engines.
page 62 , under ENGINE chapter
http://www.jeep4x4center.com/knowledge-base/index.htm?utm_source=cj#service
even shows photos.
4.7L
front ,right block,
just to right of #2 (right) front freeze plug, bingo
Feb 11, 2015 | 2000 Jeep Grand Cherokee
Where can i find free wire diagrams
free, for free google all day... join a real jeep forum and beg>?
sure
if time is more important.
alldata.com
log in and read.
or
Aug 08, 2014 | 1984 Jeep CJ7
How many qts of oil do i need
Depends on your engine.
1980 JEEP CJ-7 2.5L 4-cyl Engine Code [B]
CAPACITIES
Engine, GM without filter..........2.4 quarts[1]
Wix Filter ........ 51040
Cooling System, Initial Fill..........8.0 quarts
Automatic Transmission, A904, 30RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, A999, 32RH Initial Fill..........4.0 quarts[2]
Automatic Transmission, Total Fill
3 speed A999, 32RH..........8.4 quarts
3 speed A904, 30RH..........7.0 quarts
Manual Transmission, 4-SPD, SR-4..........3.0 pints
Manual Transmission, 4-SPD, T176..........3.6 pints
Differential, Front..........2.5 pints[3]
Differential, Rear..........4.9 pints
Transfer Case,..........4.0 pints
1. Add extra oil when replacing filter. After refill check oil level.
2. With engine automatic transmission operating temperature, shift through all gears.
Check fluid level in NEUTRAL and add fluid as needed.
3. 1984-1992 Models with command-Track, add 5 oz of 75W-90 GL-5 to shift motor housing opening.
TORQUES
Oil Drain Plug.....25 ft-lbs
Manual Transmission T176
Fill Plug.....15 ft-lbs
Drain Plug.....15 ft-lbs
Manual Transmission SR4
Fill Plug.....20 ft-lbs
1980 JEEP CJ-7 4.2L 6-cyl Engine Code [C]
CAPACITIES
Engine, without filter..........5.0 quarts[1]
Wix Filter..... 51522
Cooling System, Initial Fill..........11.0 quarts
TORQUES
Oil Drain Plug.....30 ft-lbs
1980 JEEP CJ-7 5.0L 8-cyl Engine Code [H]
CAPACITIES
Engine, without filter..........4.0 quarts[1]
Wix Filter..... 51258
Cooling System, Initial Fill..........13.0 quarts
TORQUES
Oilman
Feb 02, 2013 | 1984 Jeep CJ7
Gmart270@cableone.netI installed a 1984 engine in my 1975 CJ5 , I need to know how to connect the wiring for the ignition module
I just find this diagrams (click images for zoom)...
Fig. 5: 1975 Jeep CJ wiring schematic
Fig. 24: 1984 Jeep CJ and Scrambler 4 cylinder engine, wiring schematic
Fig. 25: 1984 Jeep CJ and Scrambler 6 cylinder engine, wiring schematic
Fig. 26: 1984 Jeep CJ and Scrambler wiring schematic, continued
Fig. 27: 1984 Jeep CJ and Scrambler wiring schematic, continued
Hope helps.
Sep 11, 2011 | Car Audio & Video
Jeep CJ 7 problems Dana 30 and AMC 20
gear ratio on 4 wheel drives are matched up together so that one does not push or drag the other if you change one it will affect the other
Feb 25, 2010 | 1983 Jeep CJ7
Engine compartment wiring diagram for a 88 cj7 jeep v8
The last Cj-7 was built in 1986. And they didn't come factory with a V-8 so you have a conversion of some type. Most factory wiring diagrams aren't going to help much. Sorry
Dec 08, 2009 | 1986 Jeep CJ7
1984Jeep fails NO portion of smog test.
cts coolant tempretur switch and or wiring they make a new pigtail for the sensor
Aug 15, 2009 | 1986 Jeep CJ7
Battery keeps dying?
try to check ignition switch or replace it
Apr 12, 2009 | 1984 Jeep CJ7
Car Audio & Video Logo
364 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
