Question about HP OfficeJet 6110 All-In-One InkJet Printer
My pc dont see the 6310 all in one printer - HP OfficeJet 6110 All-In-One InkJet Printer
My HP officejet printer gives me an error codes stating no connection on printer screen
Have you tried to change the conning plug. If you dont get that "BONG" sound it usually means the printer and PC have not meet (connected).
Try a new cable connecting the Printer & PC.
Good Luck
Dec 07, 2012 | HP Officejet 6310 All-In-One InkJet...
I have a HP offficejet 6310 all in one copy fax and scanner it will not allow me to scan
Hi there plese follow these
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Jan 21, 2011 | HP Officejet 6310 All-In-One InkJet...
Hello, I lost the software for the hp office jet 6310,and also the manual,and dont know how to make it work wireless.
First download driver from below link. Click here Then install it in computer. Make sure your in printer settings wireless is enable .Also make sure printer ip address and computer ip address of wireless are in same subnet and gateway. Then check. Let me know if you need further assistance. Thanks for using FixYa.
Aug 29, 2010 | HP Officejet 6310 All-In-One InkJet...
Why cant i find a printer when I need to print a Bus schedule ?? I have an HP Printer 6310 but dont know how to make it print information on my computer .
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=1119598&lc=en&cc=us&dlc=en&lang=en&cc=us
Need to input the operating system into the above web page to find the proper drivers to download to your computer so that when installed will run your printer and make it findable... so that one may print their Bus Schedule out.
Aug 06, 2010 | HP Officejet 6310 All-In-One InkJet...
HP 6310 print problem-prints first 10 lines OK then next 10 are on a new page etc. Re-booting PC fixes problem.
Please check the Page selecton
check the page setup click on file -click on pagesetup
Press Ctrl+P
Check the layout settings
Check print priver if print privew is ok then its software issue
Check the printer drivers
DRIVERS HP Officejet 6310 All-in-One Printer
Jan 05, 2010 | HP OfficeJet 6310 All-in-One Printer...
Can't get 6310 to find laptop and allow wireless printing
you have to setup the network on the printer first click setup then go to network then wireless setup wizard once you do that insert the cd and add a device if that doesn't work it may be a firewall issue disable every firewall on your pc if it still wont find it it may be the firewall on your router
Jun 17, 2009 | HP Officejet 6310 All-In-One InkJet...
Unable to print on my computer
Hello sir,
you go on HP Officejet 6310 All-in-One printer, double click on it, a small window will appear, delete all recent commands
if problem not solve then turn off your pc and printer both and unplug the U.S.B cable, now turn on the pc and delete HP Officejet 6310 All-in-One driver and restart pc then install the driver manually again and print your documents again.
thanks
Jan 14, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Hooking up my 6310 to my computer
hookiing up my 6310 to my computer. HP 6310 all in one
Sep 05, 2008 | HP Officejet 6310 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
21 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
