Question about Craftsman 25cc Gas Line Trimmer
Weedeater wont stay running without choke on
NEED A DIAGRAM OF THE FUEL LINE ON A 3 LINE SYSTEM
5 Suggested Answers
#1 Taper
  • 1041 Answers
SOURCE: craftsman 28cc gas weedeater gas line connections
The longest, and sometimes smaller in diameter of the two fuel lines, goes from the carburetor to the bottom of the tank. Leave enough slack in this line so that the filter that attaches to the end will rest comfortably at the bottom of the tank.
The other fuel line goes from the primer bulb to just inside the tank, (about an inch). make sure that you get the right size fuel lines. The plastic coupling goes on the end of this line, inside the tank. This keeps the line from pulling out of the tank.
(HINT): When feeding the lines through the tank holes, cut the lines at an angle. They will feed much easier into the holes. You can than cut them off square, once you know that you have enough to work with.
If you need further assistance, just let me know.
Jim
Posted on Jul 03, 2009
jblee1975
  • 15 Answers
SOURCE: new fuel lines, wont stay run, swapt in/out line, wont stay run
Sometimes simply removing the carb and placing it in a carb dip will clean it without tearing it apart, also check or replace the spark plug. Make sure you have compression, good spark, and that fuel is getting to the carb. If that doesnt work, email me and I'll find you a diagram. Jblee1975@yahoo.com
Posted on Jul 12, 2009
  • 143 Answers
SOURCE: weedeater will not run with choke off
Check your carburettor mounting screws,they might be loose and it would mean the engine is
getting to much air and it would leak gas. Stephen
Posted on Sep 06, 2009
rycgl
  • 1545 Answers
SOURCE: Craftsman 32cc Weedeater -- need fuel line diagram
The smaller diameter line (fuel supply) goes from the fuel tank (w/filter) to the carb body. Another larger line (purge line) goes from carb body to the right nipple on the primer bulb. Another large line (return line) goes from the left nipple of the primer bulb into the fuel tank. co0mpleting the purge circuit. This info pertains to my 2006 Craftsman 32cc with Zama carb.
Posted on Jun 01, 2010
I have a 2012 mercury 6hp four stroke that will not idle without the choke on
Hi, Lee and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting ***** set too low.
8. Air/fuel mixture ***** set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
Boat Motor Won Stay Running Watch This
Mercury Outboard Idle Adjustment
2010 6 hp Yamaha 4 stroke wont run with choke in Page 1 iboats Boating...
8m0055686r. google this for a free manual
Won Idle Here what did to fix it Yamaha Outboard Parts Forum
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 13, 2016 | Motorcycles
1995 Kawasaki ZZR 1100 only runs with the choke on
Hi, Anonymous and the usual suspects are:
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
13. Faulty auto choke or wiring connection.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.zxforums.com/forums/zx-11-forum/5696-92-wont-run-without-choke.html
Bike will not run off choke KawiForums Kawasaki Motorcycle Forums
Kawasaki Ninja ZX 11 Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Jun 13, 2014 | 1995 kawasaki ZZR 1100
1980 Honda GL 1100 Interstate Gold Wing only runs with choke on
Hi, Eric and the usual suspects are:
wont stay running without full choke GL1100 Information Questions...
GL1100 wont start without full choke won idle
Honda GoldWing GL1100 Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda Goldwing GL1100 Interstate 1981 Owner Manual
Apr 16, 2013 | 1980 Honda GL 1100 Innerstate Gold Wing
Why does my yamaha yzf 600 shuts off when i turn off the choke
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
YZF600R Forums View topic Wont run without choke on full
03 Yamaha YZF 600R wont stay running
Yamaha YZF600 YZF600R 1994 2007 Service Repair Manual PDF Download Manuals...
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-yz-owners-manuals
May 08, 2012 | Yamaha YZF 600 R thunder cat Motorcycles
1997 Honda CB 250 Nighthawk will not run without the choke on
Hi, Bill and the usual suspects are:
99 Nighthawk Choke Needs to Stay up to Run Fixxit
Oakys Garage Carb clean Pilot Jet clogged Won run without Choke Carbs 101
Honda CB250 Shop Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB250 Nighthawk Owner Manual
Oct 19, 2011 | 1997 Honda CB 250 Nighthawk
I need a carb diagram for yamaha tzr 250 cc motor cycle year 1988 it will not rev with out choke on . blocked jets?
Hi, Rolandwhitfo and the usual suspects are:
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
TZR 250 WON START
Will start but wont stay running without choke Yamaha Outboard Parts Forum
Yamaha TZR250 1987 Service Manual
http://mybikemanuals.com/yamaha/yamaha-tz-owners-manuals
Aug 08, 2011 | 1988 Yamaha TZR 250
1999 Kawasaki VN 1500 Vulcan Classic will not idle without choke
Hi, Jthendrick23 and the usual suspects are:
97 VN800 Classic won idle off the choke Kawasaki Vulcan Forum Vulcan Forums
http://www.kawasakimotorcycle.org/forum/kawasaki-cruisers/127513-97-vn800-classic-wont-idle-off-choke-runs-terrible-low-rpms.html
http://serwer.robert.webd.pl:30/manual/Kawasaki_VN_1500_87'-99_Service_Manual_ENG.pdf
2000 Kawasaki Vulcan 1500 Classic Owner Manual
Jul 19, 2010 | 1999 kawasaki VN 1500 Vulcan Classic
2002 Honda VT 1100 C2 Shadow Sabre will not idle without the choke being on
Hi, Esw2035 and the usual suspects are:
Need Help Bike won run choke in
Starts but won stay running unless with choke Discussion
Honda shadow vt1100 Owners Workshop Manual
Honda VT1100C2 Owner Manual Page 3
Apr 21, 2010 | 2002 Honda VT 1100 C2 Shadow Sabre
Weedeater XT 85T wont run
Check to see if your feul line is cracked or it is drawing air . Check your clamps that hold the lines on . One other thing you can check is to see if any bolts are loose that hold the carb on . Best of luck Ed.
Jun 18, 2009 | Garden
Craftsman 25cc Gas Line Trimmer Logo
562 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
