Question about Dell UltraSharp 1504FP 15" Flat Panel LCD Monitor
Monitor wont power up
Moved computer, disconnected monitor and 1 day later reconnected.even used computer power cord on monitor with no luck.Video connection is correct. Can a monitor go bad in 1 day? Havent had any probelms prior.
  • GBMaker May 11, 2010
    Does the amber standby LED light up?
  • 20 Answers
Hello, I work on thes44ee monitors and your problem is that on the power supply board there are capacotors that are needing to be changed and if you do that or have that done it will fix your problem 95%of the time
Posted on Feb 17, 2011
  • Dell Master
  • 32,281 Answers
It is possible especially if it has a loose or slightly faulty component and moving the monitor has caused it to fail especially if you bump it in the move.
Does the power LED light up when you switch on the monitor?
Posted on Sep 06, 2009
My monitor no display and light is blinking
if the monitor light is blinking this suggests that, there is no display signal coming from the tower. This could be because of the following .
1. Bad video card 2. Bad video software
To check,where the problem is , power of the system tower and remove the power cord from the back of the tower. Press and hold the power buttoon for 10 seconds and the reconnect the power cord and turn the tower on. Check if there is any display or the status of the light changes from amber to green for even a small instance.
If the light changes to green and back to amber the video port on the tower is bad
Alternatively you can connect the monitor to another desktop or laptop to check if the same is working correctly.
Thanks for using fixya
Proton
Oct 13, 2012 | Computers & Internet
I have a Philips LCD monitor - 150S4FB/00B - and for a year or so when i disconnect the power cord i would have problems to switch the monitor on when i reconnect it. I would have to disconnect and...
i will state the obvious first...u have subbed out the power and vga cables right...to make sure that is not the issue? Then of course the power plug internally - those contacts can go if you have been plugging unplugging lots... If apart, you will need to check continuity with a multimeter against the plug holes to the board. Likely requires a spot solder - 400deg silver solder. Also make sure it is not your PC or video card that is loose. Good luck!
Jun 14, 2011 | Philips 150S4FB 15" LCD Monitor
My CPU is on but no display in the monitor.
may be your video card is broken.. try to barrow a monitor from your friend or relatives and test if the problem is in your monitor or video card..
Apr 18, 2011 | Computers & Internet
Tenho uma placa mae ibm 49p1599 mas nao esta entrando o windows xp erro na inicializacao
If power to your computer is interrupted while BIOS is being updated, your computer might not restart correctly. The Clear CMOS/Recovery jumper enables you to restart the system and recover the BIOS. To perform a Flash/BIOS recovery using the Clear CMOS/Recovery jumper, use the following procedure: Before proceding, be sure to review the safety information.
  1. Turn off the computer and any attached devices, such as printers, monitors, and external drives.
  2. Unplug all power cords from electrical outlets, and remove the cover.
  3. Locate the Clear CMOS/Recovery jumper on the system board.
  4. If necessary, remove any adapters that impede access to the Clear CMOS/Recovery jumper.
  5. Move the jumper from the standard position (pins 1 and 2) to pins 2 and 3.
  6. Replace any adapters that were removed.
  7. Replace the cover.
  8. Reconnect the power cords for the computer and monitor to electrical outlets.
  9. Insert the POST/BIOS update (flash) diskette into drive A, and turn on the computer and the monitor. The system will begin to beep.
  10. After the update session is completed, there will be no video and the series of beeps will end. Remove the diskette from the diskette drive, and turn off the computer and monitor.
  11. Unplug the power cords from electrical outlets.
  12. Remove the cover.
  13. If necessary, remove any adapters that impede access to the Clear CMOS/Recovery jumper.
  14. Return the Clear CMOS/Recovery jumper to its original position.
  15. Replace any adapters that were removed.
  16. Replace the cover and reconnect any cables that were disconnected.
  17. Turn on the computer to restart the operating system.
  18. You may now want to update the BIOS normally. Refer to the readme.txt file that came with your flash BIOS update.
Nov 30, 2010 | IBM NetVista PC Desktop
I changed the ink of my printer and now it wont print anything just keeps flashing a red light. Ive tried turning the computer on and off but nothing is fixing it. Please help
Please perform the steps below and check..
1. Make sure the product is on, and then disconnect the power cord from the product.
2. Disconnect the USB cable from the product, and then disconnect it from the computer.
3. Reconnect the USB cable to the computer, and then reconnect it securely to the product.
4. Disconnect the power cord from the wall outlet, and then reconnect it to the wall outlet.
5. Reconnect the power cord to the product.
6. Press the Power button to turn on the product.
If the issue still persists please get back to me with the Printer name and model number
May 18, 2010 | Office Equipment & Supplies
Flickering screen (likea strobe light)
one check your refresh rate in windows boot the pc into safe mode if flickering is gone then lower your refresh rate if not replace lcd inverter board.
May 16, 2009 | Gateway XHD3000 LCD TV
LED's blinking, no video
Your C5707 transistors in the monitor have failed. Suggest replacing all four with the Sanyo C5707 transistor. A common problem.
Dec 10, 2007 | Dell E173FP 17" LCD Monitor
Compaq monitor no working properly
Did monitor work's on another pc?
If YESS so u need to change ur VGA
Nov 02, 2007 | Compaq Presario 5000 PC Desktop
Monitor switching to standby - CV735 monitor with Presario 5000 series desktop
my compaq crt monitor not showing color. its shows only blue, green colors . u please tell me. what is the problem in.how to solve it.
is the monitor fault or any other.
Oct 30, 2006 | Compaq CV735 17" CRT Monitor
Nothing on the screen after power on
Turn on the computer and complete the following steps: Step 1: Check cable connections (If you can see the initial HP or Compaq logo screen but later lose the picture, you can skip to Step 2.) check the video cable connection on the back of the computer and on the monitor. Make sure that it is connected properly and the connecting screws are tight. Turn the monitor off and then back on again (while the computer is on) to see if an image appears. Some Flat Panel monitors have two similar power input connections placed side-by-side on the back of the monitor, which sometimes allows them to get confused for one another. One connector is used to supply power to the speakers with a separate power cord, while the other connector is used for the monitor's power adapter. Ensure that you have the monitor's power adapter cord plugged into the power connector and not the speaker connector. After you have reconnected the power cord, turn on the monitor (while the computer is on) to see if an image appears. If there is still no image, continue to the next Step. Step 2: Resetting the monitor At first setup, or under certain signal conditions, the monitor may not be able to switch to a new display resolution. Do NOT shut down or restart the computer. Instead, perform the following steps: Turn off the monitor using the Power button on the front. If the Power button does not respond, unplug the power cord from the back of monitor and wait five seconds. Plug the power cord back in. You should see the image from the computer on the screen.
Jan 05, 2006 | HP Compaq FP 7317 17" Flat Panel LCD...
Dell UltraSharp 1504FP 15" Flat Panel LCD Monitor Logo
128 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
