Question about Toshiba Satellite 1805-S274 Notebook
Need solution My Toshiba laptop has had issues ever since the battery would not hold a charge.  It will not always, notice I said always, come on or STAY on even when plugged in. Today, again, I made sure the battery was charged 100% and tried using the machine and after a few minutes everything went black.  So I turn the machine over, take the battery loose, after a few moments put the battery back in, plug the machine into the electrical outlet and everything works.  Recently I took this machine into a computer tech who only plugged it in and it always ran.  He has suggested that perhaps jostling around the machine is causing a Motherboard problem.  I understand his thinking.  However, this machine has been stationary forever and not hardly ever moved.  It has had excellent care.  I am considering buying a new battery.  I just hate to spend the bucks if this is a Motherboard issue and I will need to purchase a new machine anyway.  Any help is greatly appreciated.  Thank you for your time. Sharon Rauch
  • Molly Rauch Dec 11, 2007
    Thank you very much, I'll get back to ya if that worked. Appreciate you help.
    Any other thoughts?
  • 181 Answers
This sounds like an overheating problem to me. Try powering down the laptop, and then blowing the fans out with canned air.
Posted on Dec 11, 2007
Toshiba A205-S5809 Wont power on
Try another cord/charger with the EXACT same power specs. If you have a multimeter, verify DC voltage at the AC jack plug. If the AC jack, in the laptop, has been pulled, damaged, it's may have a loose connection. You didn' say if ANY LED's, battery charge, work? If the battery is charged and it doesn't start on battery only, then you have other issues. It may need a ride to a Qualified Computer Tech.
Jan 08, 2013 | Toshiba Satellite A205-S5809 Notebook
Older Toshiba laptop runs on battery, but not AC cord.
on some older laptops the battery has to be installed for it to turn on.
if the battery don't hold a charge it's no good.. but you need it to get power from plug.
Jan 04, 2013 | Toshiba Computers & Internet
Toshiba satellite battery won't charge
Apr 26, 2012 | Toshiba Satellite A65-S126 Notebook
I have a Toshiba A305-S6898 that works while plugged in and it shows that the battery is charging, but the battery level has not changed in 2 hrs. Stays at 57% What could be the issue?
Sounds like the battery is shot. More than likely it isn't even holding a charge, or very little and just running straight off the plug. Best solution would be to find a replacement at one of your local ma and pa computer shops, always the best deals!
Here's a link to compare some prices: Link Here!
Hope this helps!
Aug 11, 2011 | Toshiba Satellite A305D-S6835 Notebook
Toshiba Satellite M300 won't detect power when running, will only detect it and charge battery when turned off.
If there is no problem with the battery(does it hold a full charge?) or power cabling (unnatural bunching inside the plastic sheath, frayed wires etc), then the power adapter is not providing enough current to run and charge your laptop battery at the same time. This would suggest a hardware issue with your power adapter, consider replacing it.
Oct 10, 2010 | Toshiba Satellite Pro M300-S1002X Notebook
Plug in not charging
There are several factors why this situation happens. It could be improper use of the power adapter or because the battery is not being cared correctly. On the other hand, exercising the performance of battery sometimes by draining it completely before charging it again is a good method of prolonging the battery life. If you noticed that the battery is not charging, always check first the power outlet if it is live or not before doing serious investigation.If the wall socket is not the cause of laptop battery charging failure, the following troubleshooting tips might help you.
1. Check if the AC adapter is bad or not. Detach the battery from the laptop and turn on the computer with the power plug connected. If the laptop does not turn on, try using another power adapter to verify if the first one is defective. If the second trial does not work as well, the problem might be the power circuit of the motherboard. Look for a certified computer technician to help you solve the issue.
2. If the computer does turn on, the power adapter is in good condition and not the cause the problem. In this case, try placing another battery that meets the technical specifications of the laptop for proper testing. If the second battery works well, it can be concluded that the first one is defective.
3. Determine if the problem is not caused by a software related issue. If the notebook battery status is not being displayed correctly though software, it can be considered that the software is causing the problem and not really the battery.
4. Power reset the unit by unplugging it and removing the battery. After doing that, hold the power button down for a minute. Then, attach the battery and power adapter, and start the laptop again. This method is being done to ensure that the motherboard is not holding power anymore when the battery went down causing a "hiccup" in the system. This may solve the charging failure of the battery.
5. If the battery stops charging every time the charge indicator reaches 96-98%, the laptop may need to be recalibrated for a new battery. For proper notebook recalibration, the Windows power management should be configured to prevent the system from going into sleep mode or hibernation when the battery reaches the low level. For Windows XP users, navigate to Control Panel > Performance and Maintenance > Power Options. Set "Power Schemes" to "Always On". Under "Alarms", uncheck "Low battery alarm" and "Critical battery alarm". Under "Hibernate", uncheck "Enable hibernation", and then click on Apply. Doing this procedure, the laptop battery can now be drained fully until the computer system shuts off. Then, put the adapter back into the power jack and let it charge completely. Sometimes the cycle must be repeated 2-3 times before it actually reaches the 100% full charge. The charging process should last at least around 14 hours.
Dec 01, 2009 | Dell Inspiron 1300 Notebook
Battery won't charge
It can be a defective battery, return it and get another one if you can, if that not the problem then its a laptop internal issue. If its a laptop issue take it to a mom and pop computer shop to pin point problem. Can be several issues if its the laptop. Have to look at it .
Aug 15, 2009 | Toshiba Satellite M35X-S149 Notebook
Toshiba satellite m35 power issues
Hi !
While power off, disconnect the power adaptor.
Take off battery.
Plug the power adaptor back and try to start !
Is it running?
If yes, than the power adaptor is OK.
Now shut down and disconnect the power adaptor.
Put back your battery and start!
Leave it untill you 'empty' the battery.
Do not start your laptop.
Plug the power adaptor and do not start your laptop yet.
Is there a led idicator showing that the battery is charging ?
Does it shows when the battery is full charged (e.g. red/yellow=charging, to green/off charged)?
If not, leave it for at least 3 hours. After that, start your laptop (adaptor is plugged) and see if you still have an icon saying charging 99%.
If that is the case, then something is wrong with the battery.
Check your warranty, and replace it.
DO NOT OPEN the battery - nothing interesting you will find inside - nothing you can do !
Mar 28, 2009 | Toshiba Satellite M35-S456 Notebook
Always running on batteries
You can still use your laptop even if you take out the battery and run on ac alone. You can also leave your battery in with the ac plugged in for 4 hours to charge it even if the laptop is off. Hope this helps. Thank you.
Sep 20, 2008 | Toshiba Satellite P35-S611 Notebook
Toshiba Satellite 1805-S274 Notebook Logo
61 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
