Question about Maytag Neptune MAH5500B Front Load Washer
Washer timer advances all the way to off, but never stops. washer just keeps spinning. new timer is not the solution.
  • 582 Answers
IF THE TIMER HAS BEEN REPLACED AND SOUNDS LIKE IT'S WORKING THERE HAS TO BE A WIRE OUT OF PLACE. THE TIMES HAS CONTACTS THRU OUT THE DIAL TO PUT MACHING INTO DIFFERANT CYCLES AT THE STOP CYCLE THE WASHER SHOULD STOP IF THE CONTACTS ARE GOOD
Posted on Sep 06, 2009
Won't stop washing
Generally this is caused from a bad timer motor. The timer motor makes the washer advance through the different cycles. Replacing the timer should fix your problem.
Jan 20, 2013 | Kenmore Washing Machines
My 21882 top load Kenmore washer will start the cycle but stops after filling up; i can restart the cycle by pushing the knob in and going a little further in the cycle then starting again. But after a...
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
  • Jan 29, 2011 | Kenmore 24032\24036 Top Load Washer
    My wahser just stopped working it filled with water and then started agitating and then all the sudden stopped please help
    Kenmore 110 Spin Cycle
    Assuming that this is a basic top load, direct drive, neutral drain washer it seems as if the problem is likely in the timer.
    The transmission and draining are controlled by the motor which gets it's power through the timer. If the timer isn't advancing once it gets to the spin cycle area, the motor keeps getting power, the machine keeps spinning and only by pushing in the control knob will the motor stop.
    Here are a couple of places to look at how the machine works and parts for a basic Kenmore washer.
    Sears parts site:
    http://www.searspartsdirect.com/partsdirect/index.action
    Enter your model number and you'll see a number of sub catagories for the washer components.
    Whirlpool Installation and maintenance PDF.
    This is a public domain Whirlpool manual describing how the washer works and a good troubleshooting section.
    https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
    Sep 21, 2009 | Kenmore 22642 Top Load Washer
    Stops in the middle of wash cycle
    Hi!
    If the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    Please do rate this solution as FixYa and revert for further assistance.
    Thanks
    Rylee
    May 29, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
    The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
    May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
    Washer fills/agitates and stops prior to draining
    If pump works fine or still pumps out water, then it is a timer malfunction. Replace the timer and you should be fine. To locate a part number for your timer, refer to www3.sears.com with the model number off your washer.
    Mar 14, 2008 | Kenmore 24032\24036 Top Load Washer
    Maytag Neptune MAH5500B Front Load Washer Logo
    Top Maytag Washing Machines Experts
    Bill Long
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    John Tripp
    John Tripp
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
