Question about Kirby G4 Bagged Upright Vacuum
I cannot find my manual which I will I am sure but I am trying to shampoo and I cannot remember if it is red on red or green on green. I have the newest Kirby I think the Sentra.
  • 438 Answers
Here's a great video that will help you anytime you need to shampoo the carpets. This will explain step by step how you attach the carpet cleaning attachment to your vacuum cleaner. Feel free to request a clarification if you have any questions about how to install, I'm always happy to help. If you find the video helpful, please be kind and rate the video by clicking the thumbs up incons below;
http://kirbywhq.powweb.com/videos/Carpet_Shampoo.mov
Thank you so much, I really do appreciate it. I hoped this video helped!
Chris J.
Posted on Mar 21, 2010
I have a Bissell Power Lifter Shampoo Machine but no instructions
I have a bissell power lifter shampoo machine and no instructions.
Oct 01, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
I have a kirby sentria vaccum carpet shampoo system and I cannot get the shampoo suction head to work! It comes on but the belt is not turning. I have tried taking it off and looking at the assembly but no...
I had the same problem at first but figured it out. Make sure before you put it on the vacuum itself, that the shampooing unit is completely together. The belt needs to be taunt like it would be when the brush is turning. Once you put it on and turn the dial to the green arrow, it should be on the vacuum cleaner and will turn the brushes . That was my problem is I didn't have it completely together right. Hope this helps.
Sep 19, 2009 | Vacuums
Having trouble shampooing
I found this on a website. Hope it helps others...
by Mainelyvacs in: Kirby
  • First a short explanation of how the Kirby shampoo system works: Kirby uses a “Dry Foam” type of shampoo. Basically, it spreads a shampoo foam solution on the surface of your carpet. This foam needs to stay on the surface of the carpet until it is completely dry (usually 1 to 2 hours depending on temperature and humidity) As the foam dries, it soaks up grease and dirt. You then vacuum the carpet and up comes the shampoo residue along with the absorbed dirt and grease. It does a very good job on the surface but will not extract stains from the bottom of the carpet or carpet pad. Several other brands such as Electrolux, Hoover and Koblenz make Carpet Cleaning machines that use the same system.
    So, you’ve read your manual, you’ve removed the carpet cleaning nozzle and the bag assembly from your Kirby, you’ve installed your shampoo tank and carpet shampooing nozzle tray and you start to shampoo but all you get on your carpet is a puddle of soapy water and no foam. Here’s a few things to look for:
  • Make sure you are using a Dry Foam Shampoo(preferably Kirby) and NOT an extraction shampoo, the Rug Doctor shampoo you had left over from your last rental will not work.
  • Make sure you have the correct mixture. If you are using Kirby Dry foam shampoo you simply fill the tank with water and put a tank cap full of shampoo in with the water. You can use other brands of “Dry Foam” shampoo, but the mixture ratio may be different, so read the label first.
  • Don’t reuse last year’s leftover mixture, it’s probably no good.
  • Make sure a family member didn’t pour any leftover mixture back into the empty shampoo bottle - further diluting a mixture will not produce any foam.
  • Don’t use shampoo that’s seen extreme temperatures.
  • Check the tank and make sure that the sponge filter is in place and if it is in place that it is not deteriorated. The sponge filter is located under the tank at the point where you attach the tank to the hole that you removed the bag assembly from.
  • Check the hose that runs from the tank to the nozzle. It should have a screen in the end that attaches to the tank (older models had a cloth screen with a metal retainer, models after 1989 have a 1 piece metal and plastic screen.
Apr 13, 2009 | Kirby Ultimate G Bagged Upright Vacuum
No water or shampoo releasing
Take off the 2 spray nozzles and blow thru them, they may be clogged. You ay also try running a mix of water and vinegar thru it to help clean out the lines. May have a bad pump.
May 24, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Little green machine solution
on the solution tank of the green machine has a line on ot showing how much solution
May 11, 2008 | Bissell 1720-1 Little Green Wet/Dry Vacuum
How do i put together my kirby carpet shampoo system?
Vacuum thoroughly before shampooing for maximum cleaning. Then, remove the bag and the Power Nozzle to prepare for shampooing. Turn the Carpet Shampoo System Nozzle Belt Lifter to the right of the center position (fully clockwise) until the green arrows line up. a4bbc62.jpg Slide the slots on the side of the Carpet shampoo system over the outer shoulders of the Carpet Shampoo System Tray. e14fe2e.jpg While pushing up on the Belt with your finger, turn the Belt Lifter left (counter- clockwise looking at it from the front) until the red arrows line up. (The Belt Lifter Hook will catch and stretch the belt.)
Press the bottom Toe Touch Pedal all the way down to raise the front of the Kirby.
While sliding the carpet shampoo system Nozzle/Tray Assembly toward the Kirby and over the Motor shaft, connect the hooks on the bottom rear of the nozzle to the Attaching Bar.
Push the nozzle up against the Kirby and turn the Accessory Lock to the
right (clockwise) to lock the nozzle in place. To engage the belt, turn the Belt Lifter
all the way to the right (clockwise) until the green arrows line up. Then lower the Headlight Hood
Apr 18, 2008 | Vacuums
Shampooing with the kirby
In the cap where you fill the shampoo, make sure the filter and components are clean
Apr 17, 2008 | Kirby Ultimate G Bagged Upright Vacuum
No suds when shampooing
The sponge filter is in the large opening on the underside of the kirby shampoo tank. It is where the shampoo tank connects to the kirby. The cap the manual is referring to is the shampooer tank cap. It looks like a cup.
If the mesh screen in the hose is in place (try pulling it out of the hose and seating it in the tank where the hose connects.) and you're still having very little suds...(I'm assuming you're using Kirby shampoo as well)...I would suggest going slower when yours "laying down suds". And lower the shampooer head all the way to its lowest setting. I have found if there are a lot of oils in the carpet, the emulsifiers in the shampoo break down quickly and make the suds "disappear".
Be sure to go back over the carpet with the tank in the off position to scoop up any excess moisture. If excessive oil (from cooking, barefeet, and pets are main causes) is the cause of the lack of suds, numerous shampooings will rectify that situation.
Hope this helps!!
Feb 18, 2008 | Kirby Generation 3 Bagged Upright Vacuum
Tiara
try this shampooing guide
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
and make sure the brushes on the shampooer head are spinning and that the shampooer head (same height adjustment on the kirby when vacuuming) is set to the lowest setting.
Dec 09, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby G4 Bagged Upright Vacuum Logo
67 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
