Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Find replacement belt for LT 2000 17.5 HP Kohler Engine
  • 582 Answers
WHICH BELT ARE YOU LOOKING FOR A LOT OF AUTO PARTS STORES WILL GET THEM FOR YOU OR ORDER ONLINE. GET THE MAKE AND MODEL AND SERIAL FROM TRACTOR , BELTS SRE NOT HARD TO FIND
Posted on Sep 06, 2009
42inch LT 2000, Kohler pro17OHV. What is the drive belt size?
Craftsman Replacement Belt for 42 in. Deck - Lawn ... - Sears
www.sears.com/craftsman-replacement-belt...42.../p-07133153000.. Sears
Rating: 3.5 - ‎42 votes
Jun 1, 2010 - Replacement Belt for 42 in. tractor deck. ... After a wast of time at searssaying that they could not find the belt we walked out angry and .... The Craftsman 42" Ground Hydro Drive Tractor Belt replaces manufacturers #140294.
Aug 11, 2015 | Craftsman Garden
I have a new Cub Cadet RZT-S - 23 HP Kohler. I was
check the drive belt on hydraulic pump under you seat
Aug 09, 2013 | Cub Cadet Garden
Need to know how to change transmission fluid on cub cadet lt 1045 riding mower
Cub Cadet has five models in their new Series 1000 lawn tractors, all powered by Kohler engines. Cub Cadet models -- as several other lawn equipment brands -- are manufactured by MTD Products.
The Cub Cadet LT 1045 has a 20-hp Kohler single-cylinder engine, with an aluminum block and cast-iron sleeve for longer life. It has a full-pressure lubrication system with spin-on oil filter for easier maintenance. This engine is not as powerful or as long lasting as the Kohler V-Twin OHV, which is available in other models in the line, but the LT 1045's engine is still solid enough to provide years of mowing.
The hydrostatic (automatic) transmission is a good match with the engine and provides sufficient grip to cut grass on moderate inclines. Power is transferred from the engine to the transmission by a heavy-duty Kevlar belt rather than a more expensive shaft drive. A Kevlar belt also drives the three cutting blades.
The mowing deck cuts a swath of grass 46 inches wide at one pass, and is removable for service and cleaning. Four anti-scalping wheels help keep the deck from scalping grass on uneven ground. The cutting height is manually adjusted from 1-1/2 to 4 inches. The turning radius is 18 inches, which standard for lawn tractors. This model is intended for use on 1- to 2-acre lawns without many turns or small obstacles.
Jul 28, 2012 | Cub Cadet Garden
Replacing 24 hp B&S with a 20 hp kohler, need to
Yes I agree. I would figure that out first before changing the engine.
Sep 07, 2011 | Briggs & Stratton Garden
Electrical schematic
i need a diagram for the ignition switch on my craftsman mower
....7 prongs all labeled with letters sure what 3 are for not other 4
Apr 10, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Loud knocking sound
bad connecting rod in engine...eventually it will go completely, and cause sever damage
Apr 10, 2010 | Garden
Where can i fine manual for engine replacement
TO REMOVE THE PULLEY FROM THE CRANKSHAFT END:
Remove the blade belt and, if needed, the deck to give yourself more room to work. Apply your brake pedal and lock it down, this will relieve the tension on the ground drive belt.
If you have an electric blade clutch, find the plug where the wire goes over from the clutch to the frame and unplug it.(Electric clutch will be heavy when unbolted so be ready for it.)
In the center of the pulley or blade clutch you will find a long bolt (most likely a 5/8 head on it) You may need a deep socket to reach it depending upon the type of stack pulley on it, remove this bolt and the pulley should slide freely on the crankshaft. slide it downward and slip off the belt on the top of the pulley then remove the pulley the rest of the way
Oct 05, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a Craftsman 18hp Kohler engine. What is
there is no clutch drive belt needs replacing cost of drive belt $20.00
Sep 02, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
15 hp kohler starts runs but when put load on it dosnt have enough power to mow help
oil pump maybe going bad throwing timing out a bit,this would cause a governer malfunction keep pushing it the timing belt will fail that's if this engine is similar to the triad 16 hp horizontal shaft,not sure about vertical
Jul 10, 2009 | Kohler CH25 PA-CH730-0040 Command Gasoline...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
200 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
