Question about Rockford Fosgate T10001BD- Car Audio 500watts Mono Power Amplifier Car Audio Amplifier
Photo diagram of a 2006 rockford fosgate power t10001 bd amp
I need a photo diagram and part labeling of the inside of a 2006 model rockford fosgate power t10001 bd amplifier to point out where the the thermister that is located on the mehsa insulator
3 Suggested Answers
bill_48632
  • 149 Answers
SOURCE: connect rockford fosgate amplifier & speaker together
Assuming your P3 has a single voice coil (it will have only one place to plug your wires into) you will be running this in a bridged mode. You will take the left (+) coming off the amp and plug it into the (+) on the P3. Then take the right (+) from the amp and plug it into the (-) on the P3. This will make your amp push 500 watts to your sub. Now on the amp make sure your adjustments are as follows: Signal input switch is set to unbalanced for RCA input. Left Phase switch is set to 0. Right phase switch is set to 180. your X-card should be set to low pass. And adjust the gain for both R and L equally so it has equal power from both channels.
Posted on Aug 09, 2009
fkuk
  • 311 Answers
SOURCE: lights up & getting no power to subs
for a test
disconnect everything from the remote terminal in the amplifier
get a bit of wire and connect the remote terminal to a 12 volt supply
does it turn on now?
if yes then check the remote wire from the radio does it become 12v when the radio is on and 0v when it is off
if no make sure that the amplifier has been grounded properly and all the power cables are connected properly
Posted on Dec 31, 2009
Why is the Protect light
you have an internal short inside the amp
May 12, 2014 | Rockford Fosgate T1500-1BDCP 1500 Watt...
Lights up & getting no power to subs
for a test
Dec 31, 2009 | Rockford Fosgate T10001 bd Car Audio...
Hi my amp keeps clipping at high volume......i know is not the wiring...can u help me
turn the volume down or the gains on the amp (should be around 3/4 and no more) or get a bigger amp so you do have this problem
Sep 25, 2009 | Rockford Fosgate T10001 bd Car Audio...
My amp is protecting unessacarily when ran at 2 ohms
are you factoring the ohm rating from running them parallel?
2 x 2o subs parallel = 0.5 ohm (lowers ohm's)
2x 2oh subs series = 4 ohm
IT is posable that you are calculating the ohm rating fine, BUT some SUBS can reach lower ohm rating while hitting bass- i didnt know this till i had a rather insane sub that would dip to 1ohm while hitting hard bass causing my amp to go into protect mode.
May 21, 2009 | Rockford Fosgate T10001 bd Car Audio...
Best sub For RF T10001
There is no "best" its a matter of opinion, and fabrication. I have installed $75 subs in the properly fabricated and tuned enclosure that sound like $300 sub in a pre-fabbed enclosure. For volume, you will need a vented enclosure. For sound quality, a small sealed. Both have pros and cons. SoloX 10 is 2500W rms 5000W peak.
Kicker is plastic. Solobaric may be your best choice in such a small space, however soundsplinter makes an 8" RLi sub that will kick a$$ in the proper enclosure.
When looking to buy, compare x-max : as this is the linear distance the cone will move. More movement = more air displacement = more volume.
Dec 13, 2008 | Rockford Fosgate T10001 bd Car Audio...
No sound no protection light no obvious problem...
there is a wiring issue in your truck and i would get rid of the preamp
Dec 12, 2008 | Rockford Fosgate T10001 bd Car Audio...
Heater problem 96 cherokee
Is the heater valve opening?
You may want to re-post this in the automotive section. For some reason, it's in the car audio amplifier troubleshooting section.
Nov 23, 2007 | Rockford Fosgate T10001 bd Car Audio...
Smoke and no more juice
I Have also had this happen to me, pretty similar around the time it happened to you also, but I'm not just getting my hands dirty and inside the amp. If I fix this, I'll be sure to let you know what it was that I did, or bought and replaced......... I would also like some ideas and support on this if this has already been taken care of
Apr 29, 2007 | Rockford Fosgate T10001 bd Car Audio...
Car Audio & Video Logo
149 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
