Question about Kenmore Elite 45986 Front Load Washer
Dshwasher has water on the bottom after cycle
My kenmore has water on the bottom after a cycle. it doesn't drain all the water out. I can hear it draining but there's still lots of water left in the dishwasher and on the floor?
We have taken off the rotating arm that sprays the hot water on the bottom of the dishwasher.
    Sergeant:
    Champion:
  • 362 Answers
Your drain line is clogged or your pump is bad check both. the drain push a coat hanger down it and see if you can pull anything out.
Posted on Dec 20, 2007
I have a kenmore 80 series washer that goes thru all the cycles except that it doesn't drain after rinsing and this is my serial and model number if you need it: mod20852990 ser4549516
does it drain after the wash cycle before therinse cycle? if not there are usually 2 belt on the bottom of the washer, one is for the aggitator the other for the water pump. check to see if the belt is still attached and also take the drain hose down to floor level to see if the water gravity feeds out, if it does not pour out then your pump would likely be clogged from lint.
Apr 24, 2012 | Kenmore Washing Machines
SEWAGE SMELLING WATER COLLECTS AT THE BOTTOM OF THE DSHWASHER.
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you’ll need to clean the drain filter and drain pump.
Please note that dishwashers don’t drain out the complete water such that heating element doesn’t overheat.
Please post back for any further assistance.
Daniel
Aug 27, 2010 | Dishwashers
Kenmore dishwasher water will not stay in there
It sounds like you have a drain hose problem. The drain hose needs to have a rise in it. If it is going down hill or to a drain that is lower than the tub it can drain as fast as it fills.
Apr 24, 2010 | Kenmore Dishwashers
Need Help Regarding Draining Problem
you might have a blockage in your air gap or your garbage disposal line. check those areas first. do you hear the pump humming and not pushing any water through or do you hear is poushing the water through but just trickling through the garbage disposal? let me know
Jun 02, 2009 | Dishwashers
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
Feb 14, 2009 | Kenmore 12502 Top Load Washer
Water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Hi
Check the bottom of the machine and where water goes,there might be some scrap food,or other item that is not allowing the water to go in the time when the valve is open.This leaves some water and increases in other cycles,causing flooding on the floor.Also check for bend in the pipes at the back.
Hope this helps
jay
Nov 17, 2007 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Elite 45986 Front Load Washer Logo
97 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
