Question about Salter 3007 Aquatronic Digital Scale
Salter 3007 Aquatronic Digital Scale. What does the error message "EE" mean and how do I clear it to make the scale function properly? Batteries are good.Self check works. auto shut-down works.
  • 10865 Answers
SOURCE: Salter 9001 bathroom scale stopped working
Hi Pete. I don't keep receipts either : ^ )
No that I am done commeserating, try this. Remove the batteries. Use the eraser end of a common pencil to scrub and clean the battery contacts inside the battery compartment. Also pull the contacts a little closer to the surface if you can. Then reinstall the batteries and you may be up and running.
Please rate my answer as verey helpful thanks. Joe
Posted on Mar 26, 2010
SOURCE: Have been given Salter Aquatronic 1030 scales but
Posted on May 12, 2009
  • 86 Answers
SOURCE: how do i contact salter scale customer service i
you can contact our customer service by this email address
sales@accurate-scales.com
Posted on Aug 04, 2009
SOURCE: setting the clock on salter scale model 5007
Hold down the g-oz key and the off key at the same time for about 5 sec's
The hour digit will flash
press the ml-floz key to move the hours.
then press the g-oz key again to move to the minutes.
press the ml-floz key again to set the minutes.
press the g-oz key and it moves to setting the cloak to 12h or 24h option.press the g-oz key to set the time.
And your done.
Posted on May 23, 2010
SOURCE: Kitchen scale, Salter, model 2006: change batteries
The 1 part just slides off.
Posted on Jun 28, 2010
Is my scale calibrated. When I turn it on it first shows 8888 7/8, then it 0/0g
Take a ten pound bag of sugar and calibrate the scale to read 10 pounds.
Oct 30, 2014 | Salter 3007 Aquatronic Digital Scale
My Salter Model 2001 kitchen scale, shows an 'ee' on the screen. This error code is not listed in the manual. Any suggestions?
"EE" means that the scale has been overloaded. Try placing a small weight (i.e. 250g block of butter) on the scale and then turning the scale off and then on again with the small weight still on the scale. What this does is to try and re-calibrate the scale. If this doesn't work then I am pretty certain that the scales will need to be replaced. The scales in question do have a 15 year guarantee and you can try contacting Salter Housewares directly if you have your proof of purchase.
EE showing on screen
Sep 12, 2014 | Salter 2001 electronic kitchen scale
My Salter Electronic scale (3007) got soaked and is giving incorrect / unstable readings. I am trying to take it apart ASAP to dry the board, contacts, etc. but cannot work out how to detach the weighing...
The weighing pad mates with a circular metal plate underneath and needs to be rotated clockwise to unclip from the metal plate. Peel back the lower right corner of the instruction label on the bottom. This reveals a hole through which a philips head screwdriver needs to be inserted to loosen a screw which then allows the weighing pad to be rotated. The screw only needs to be loosened, not removed.
Sep 02, 2010 | Salter 3007 Aquatronic Digital Scale
I have taken the back off my bathroom scales as they stopped working and as I did i pulled a few of the wires off, not sure now how to re attach them and to where is there anywhere that you can get...
mcdevito75 here, Chances are the digital portion is burnt out, You can try an appliace repair shop in your area, I don"t think you"ll be able to get the wire schematic, you can also try to call the manfacturer or vist online. Sorry!
Jun 30, 2010 | Salter 3007 Aquatronic Digital Scale
I have a Salter 307 kitchen scale. Are there any instructions for disassembling this unit? Removed 6 + 1 screws and I still cannot open the unit. Please help!!
How to open up the Salter 3007 Aquatronic Digital Scale:
1. Look for a hole (covered by a label) on the bottom of the device, not far from the L-R centre line, and about 1-3/4" from the front. Peel back the label and use a small cross-head screwdriver to loosen the screw that can be seen though the hole (needs about one turn, no need to remove it). Place the scale upright, and rotate the weighing pad slightly in a clockwise direction. This will disengage the tabs on the plastic pad which hold it to a metal base, so that it can be lifted off. 2. Remove the six screws recessed around the bottom of the scale. 3. Place the scale upright and gently "snap" apart the top and bottom shells (catches molded into the left and right ends). Be *** VERY CAREFUL *** when doing this as the display is held in place on a plastic bridge by the upper shell. When this is removed the display is loose except for a flexible plastic printed connector strip (which links it to the circuit board). It is *** all too easy for this strip to break away at one end or the other ***.
Apr 01, 2010 | Salter 3007 Aquatronic Digital Scale
Setting the clock on salter scale model 5007
And your done.
Oct 06, 2009 | Salter Bakers Dream Aquatronic Kitchen...
I have lost my instructions for my Salter glass bathroom scales 9103. I have a EE on the digital mode what does this mean and what can I do to fix it so the correct weight shows
The scales display EE as they are reading a negative weight.
With the scales switched OFF place 2 glass plates on the scales and press ON.
The scales should now display 0g.
If this doesn't work add more weight and try again.
There is also 4 screws on the underside of the scales which hold the weighing bar in place, if you loosen the 2 smaller screws this should relieve some of the stress so less weight is needed to zero the scales.
Jan 26, 2009 | Salter Stainless Steel Electronic Bathroom...
Salter 3007 Aquatronic Digital Scale Logo
181 people viewed this question
Top Salter Health & Beauty Experts
traccie
Level 1 Expert
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
