Question about ICOM Informatique GPS
How do i boot my nuvi 855 - ICOM Informatique GPS
  • 4 more comments
  • thabiet971 Sep 06, 2009
    i tried all that and still no results
    my nuvi 855 is getting stuck at the loading map screen. i tried to reset the unit in and out of the charger. i tried a software update and but still no result. i tried to preboot the unit but then it get stuck at the press dot screen. what other solution is there for this problem.
    i have a nuvi 855
    please post me the link to mygarmin tools restore.
  • 13,433 Answers
Try pressing the reset button, if that doesn't help, plug it to the charger, and try the reset again. Also press the power button both in and out of charger.
Posted on Sep 06, 2009
  • Ekse Sep 06, 2009
    can you clarify what do you mean with boot your nuvi?
  • Ekse Sep 06, 2009
    I see.. Send it to garmin for repair service. you have done everything you can do at home to this machine. Garmin repairs their own equipment and don't give out service details out easy.
    Brigadier General:
  • 5,158 Answers
Please confirm the model number of the nuvi that you have
  • Roberta Smith
    Roberta Smith Sep 06, 2009
    to restore you would go to tools (looks like a wrench on my garmin)
    touch restore
    select yes
    robert
  • Roberta Smith
    if that fails... slide the power switch and hold it for 8 seconds release it then power on the unit
Forgotten memory card password
final thing is format memorry card and try to recovery files
Nov 19, 2013 | Skque 8GB MicroSDHC / MicroSD / Micro SD...
Want to add phone to Garmin Nuvi 860.Device is not phone neary by
Are you trying to add another phone to the Garmin? If so, you have to activate the bluetooth on the phone so Garmin can see it.
Feb 11, 2012 | Garmin Nuvi 800, 850, 855, 860, 880, 885T
My Garmin Nuvi 855 is locking up. I can only get as far as entering the city and sometimes not even that when entering an address. How do I fix?
Go to Garmin's site and download & install the Web Updater as directed. The address is:
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
After running the updater on your nuvi 855, it will have the latest firmware (this process does not download and install the latest map software) and should solve your problem.
If you continue to have problems, you might want to contact Garmin Customer Support directly at the address below:
http://www.garmin.com/garmin/cms/home/support/supportcontact
The people there are knowledgeable and can solve many problems over the phone. Their service is free of charge.
Please take a moment to rate this answer if you found it helpful. Thanks - and good luck!
Jun 29, 2010 | Garmin nuvi 350 GPS Receiver
Will a 4g micro sd hc work in a garmin nuvi 1300
It would Work.If you wish, you could buy it from :-
http://cgi.ebay.com/4GB-Memory-Card-for-Garmin-nuvi-855%2F885T%2F1200%2F1250%2F1300_W0QQitemZ400099612983QQcmdZViewItemQQimsxZ20100126?IMSfp=TL1001261810018r4225
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 12, 2010 | Garmin GPS
Screen Acts likes its locked
Question: My nuvi 850, 855, 860, 865, 880, or 885 is freezing up or will not boot up past the Loading Maps screen.....
Answer: If your nuvi 850, 855, 860, 865, 880, or 885 is experiencing any of the following symptoms:
  • The touch screen is no longer responsive and the unit appears to be locked up
  • The unit will turn on however freeze at the point where it indicates that it is Loading Maps...
  • The unit takes five minutes or longer to be recognized by your computer as a mass storage device
A software update is now available for you to update your nuvi to correct these issues. Please use our WebUpdater program to install this update.
Please note: Due to this problem, it may take up to five minutes before your computer will recognize your nuvi as a mass storage device. This software update will correct this issue as well. //changed this line from 'solution1description.innerHTML' to use getElementById //to prevent FF warnings. They both appeared to work, but this is cleaner. solution = document.getElementById('solution1description').innerHTML; Last modified on: 12/21/2009
Feb 07, 2010 | Garmin nuvi 885T GPS Receiver
Charging Garmin Nuvi battery for first time
The Garmin Nuvi 855 uses a Lithium-ion battery. It is a very clean system and does not need priming as nickel-based batteries do. The 1st charge is no different to the 5th or the 50th charge.
In other words there is no memory effect with these batteries and it should be safe to charge it for as long as you like on the first charge. I would estimate 4 hours will give you a full charge if you wish to do this from the outset.
Jun 21, 2009 | Garmin Nuvi 760 Car GPS Receiver
REGISTERING MY GARMIN NUVI 855 GPS 4.3''
When registrating your GPS on myGarmin you should type in your serial number. It's on a tiny label on the back/bottom of the unit, and is the identification number needed to start the registrating process. Your GPS will need to be connected to the PC on the next step.
Jun 03, 2009 | Garmin nuvi 885T GPS Receiver
Need Garmin nuvi 855 manual
Your manual for your Garmin Nuvi 855 can be found at this following manufacturer link:
http://www8.garmin.com/support/userManual.jsp?market=4&subcategory=41&product=010-00577-31
Please be sure to vote if this was helpful to you.
Regards,
Joe
May 07, 2009 | ICOM Informatique GPS
GPS Logo
114 people viewed this question
Top ICOM Informatique GPS Experts
Are you an ICOM Informatique GPS Expert? Answer questions, earn points and help others
