Question about Car Audio & Video
Doesnt have any sound and the serv light is not on but the power light is on
    Problem Solver:
  • 10 Answers
If your talking about your amp make sure you have connected your remote wire from your head unit to your amp, this sends the signal from your radio to your amp telling it to turn on
Posted on Sep 16, 2009
WHY HAS MY CAFE STOPPED WORKING? IT DOESNT DRIP COFFEE INTO CUP.
Sounds like your machine is congested. Consider cleaning out the nozzle or the filter.
Sep 22, 2014 | Bunn Commercial Bunn My Cafe Pourover...
Bmw x5 2001 the car doesnt pick up speed when put in gear and doesnt always go into gear there is a delay when put reverse I follow manual intructions turn off the engine and wait a few minutes then...
Read the trouble codes for your automatic transmission using a scan tool. I like the wireless ELM327 OBD2 adapter and OBD Fusion app.
The trouble codes will tell you why the transmissiion is putting the car in limp mode.
Dec 22, 2017 | BMW X5 Series Cars & Trucks
M-audio ProKeys 88sx -- all led lights flash, no sound Upon turning the keyboard on, all led lights on the top panel flash. No sound from the keyboard. Is there a re-set button or something?
I have two of these. First thing check your power adapter for output. Just because LED's are on doesn't mean there is correct voltage... There is no reset button... Cycling power serves to reset it.
ALSO check the power input connector... sometimes those get intermittent and break connection due to vibration and initial current surge when turning on.
May 31, 2010 | M-Audio M Audio Keystation 88es 88 Key USB...
Computor doesnt connect to internet states a local network cable is unplugged 4 green lights on routerand one red light turn off all power and unplugged cable also reset button but no internet connection...
If the red light is your DSL light it means you have a line fault or no internet connection. Contact your provider
If the red light is your broadband / internet light - it means you are not logged on properly. Chck your username and password are correct - especially after the reset!
Oct 06, 2009 | Belkin (F5D5231-4) Router
Doesnt seem to get power or the dryer barrel is stuck
Sounds like the belt is off the idler. This is all I can think of that would bind it like you say.
Please rate solution
Aug 25, 2009 | Kenmore Dryers
LIGHT DOESNT COME ON AT ALL
all the possibility but check all you power source and rca;;
Mar 29, 2009 | Sony XM-2165GTX Car Audio Amplifier
Worcester bosch highflow 400 - the green demand light never works when i select it, there's no hot water or heating. The green demand light does not comes on but there is noise from the boiler . .
Sounds like a control panel.Detatch the block connector that serves the gas valve,see if you have power on the bare pins.both left and right pins should measure mains voltage.If you have no power at the pins its the pcb control board.Replace the board.
Nov 01, 2008 | Heating & Cooling
Samsung hc-r5245w no power
Hello Chac c,
The reason that you are getting a 'red light' is because your lamp is burned out. There is a panel on the back of the TV that gives you access to this lamp. You can remove it and check the part# to be sure then replace it. I did a quick search for you just based on the model# which you provided. You can see it here - http://www.nextag.com/serv/main/buyer/OutPDir.jsp?search=samsung+lamp&gg_site=&gg_aid=1295966762
Hope this helps :)
Mar 17, 2008 | Samsung HC-R5245W 52" HDTV
Is motherboard dead?
Either motherboard, ram module or if no power at all sounds more like a power supply. If the computer has on board video you will need the ram to get any video. But with it removed the board should still beep if the case speaker is connected to the board. Have seen a lot of these less expensive motherboards fail. If there is no power up at all or lights coming on on the case I would think it is a power supply problem. Happens all the time and quite easy to repair. Just put on a new power supply.
Dec 12, 2007 | EliteGroup ECS P4M800-M Socket...
Car Audio & Video Logo
14 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
