Question about Coby Audio Players & Recorders
Coby MP822-4g I connected to computer.All I get is Please wait message. I looks as though the computer doesn't recognize that it is connected. Running windows XP
  • 453 Answers
Turn off the player.
Press the power button for 20 seconds.
Uninstall and reinstall the software you received with the player.
Reset the player and try and also try formatting the player.
Also try with a different data cable of the same kind.
Posted on Sep 06, 2009
I have placed photos from my pc to Photoviewer 2.3 but when I try to download photos to Coby DP-152 I just get a download failed message. Why? What am I doing wrong?
uninstall photo viewer,then reboot your computer,install the cd with photoviewer on it,(for windows,not mac),next reboot your computer,now,connect your coby to the computer,wait until it is recognized,double click on the photoviewer icon on the desktop screen,let it load,
Coby DP 152 Instruction Manual
May 30, 2015 | Photography
My computer is not recognizing the coby MP815-8GB and saying that it is corrupt. Please suggest me how to fix this problem?
On the MP3 player itself, go to Setup > System > put the USB mode to MSC.
Reconnect the MP3 player to your computer, it should appear as a 'Removable Disk' drive under 'My Computer'.
If that doesn't resolve and you still get the 'USB Device is corrupt', try replacing the USB cable.
Jun 28, 2011 | Coby MP815 Digital Media Player
My computer won't recognize the Coby MP727-8G MP3 player. I checked on the coby site for a firmware update but there is nothing available.
check wether your mp3 player is turned on when it is connected to the pc. if not turn it on. if it doesn.t work try another usb po
Dec 31, 2010 | Coby MP727 MP3 Player
I have my coby MP 600 MP3 player, but one day i make a scan and after when i start it i can not acces with anything, it posts a message error: file system error. please help me to solve this problem. Thank...
It sounds like the Coby operating system is corrupted.
I'm going to recommend you try the following procedure with one catch; I'm assuming you can turn the unit on and at least get a menu. If not this procedure isn't going to work.
NOTE: The following procedure will erase everything on your Coby so be aware!
Essentially, we're going to reformat the unit using Coby's own format routine.
1. Power Unit On
2. Scroll through your main menu going to your right. From "Music" ---> to "Settings"
3. Under "Settings" you will have another menu. Look at the bottom choice called "Sys Tools"
4. Select "Sys Tools" and you will have a series of options, choose the second option "Format"
5. Select "Format" and follow the prompts
6. Wait for the routine to complete
7. Power unit down
8. Power unit back up and reconnect to PC
9. Use Windows Explorer or My Computer to see if the unit is recognized, and it should be at this point.
10. You should be set
For some reason, the operating system for the Coby gets corrupted and this is the only way I know to fix it short of sending the unit in for repair, which isn't an option really. (Cheaper to buy a new one)
Hope this helps you or anyone else that has unexplainable problems connecting to the Coby MP-610 / MP-620.
Oct 19, 2010 | Coby MP-610 MP3 Player
My coby mp touch isnt connecting to my pc
Turn on MP3 player
Go to Setup > System > USB MODE
Put the USB MODE to MSC
Reconnect to the computer
Your computer should then recognize the MP3 player.
Apr 12, 2010 | Coby MP-705 Digital Media Player
My Coby mp3 player won't connect to my computer
QUESTION ONE:
Can you see it in "My Computer"? It will show under "Removable Drive/Storage"
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and photo folders?
QUESTION THREE:
Can you see the player in Coby Manager - under the "DEVICE" tab?
QUESTION FOUR:
When disconnected from the computer, how long can you listen to the Coby player before it goes off?
If not present in My Computer or in Coby Manager, then it is not plugged in correctly.
a. Disconnect the player from the computer.
b. Wait for it to cycle through "Please Wait" and "Updating Library" screens.
c. Make sure the player is TURNED OFF ! ! !
d. With player TURNED OFF, reconnect wire to the player then to the computer.
e. You will see a USB connector icon on the player screen and the player battery charging.
It will appear to be charging all the while it is connected to the computer. After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8-16 hour charge with the player turned OFF connected to the computer.
IT WILL NOT CHARGE WITH A COMPUTER UNLESS IT IS TURNED OFF WHEN YOU CONNECT IT.
f. Use the Coby Manager to disconnect the player
(Found HERE if you have had to format the player)
CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
1. Go to the DEVICE TAB
2. CLICK on EJECT Button in lower right hand corner.
3. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
4. The second pop-up screen will tell you "The device can now be safely removed from the system."
5. The Coby will now show "Please Wait..."
6. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
You should now have enough battery power to use it. To check the battery level,
1. Turn on the player
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter as the battery is wearing down.
Hope this helps
Apr 05, 2010 | Coby MP-610 MP3 Player
I have a coby mp-610 and I just took it out of the box and plugged it in to my computer. Nothing comes on, nothing. I've hit the reset button. I've turned it off and on. It doesn't even show it's charging....
COBY PLAYER MUST BE TURNED OFF WHEN BEING ATTACHED TO A COMPUTER...
QUESTION ONE:
QUESTION TWO:
QUESTION THREE:
e. Let your computer recognize it.
f. You will see a USB connector icon on the player screen and the player charging.
It will appear to be charging all the while it is connected to the computer. After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8-16 hour charge with the PLAYER OFF the COMPUTER ON.
f. Use the Coby Manager to disconnect the player (Found HERE If you've lost your copy on the player)
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter horizontally as the battery is wearing down.
Hope this helps
Computer will not respond when usb is connected
Your computer should be able to fix the Coby's firmware even though you are having trouble connecting in the usual way. Please try these steps to fix your Coby MP-610 MP3 Player.
Feb 21, 2010 | Coby MP-610 MP3 Player
Computer does not recognize coby mp705
you know the hold button on mp3 player? while connected to the computer, move it to the left until it says hold and it stays there... or if its already on hold move it to the right until its stuck on start symbol
or move it to the right and left vs left or right..
it worked after i played with it for a while...
now if you wait 30 seconds it may or may not reappear :o
Jan 06, 2009 | Coby MP-705 Digital Media Player
Computer will not recognize my Coby MP-C7095
i know how to , you just go on your mp3 and go to settings and go to usb connectiona and then you switch the thing it says two options pic the other one simple as that ;D
Dec 21, 2007 | Coby MP-C7085 MP3 Player
18 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
