Question about Cell Phones
PalmCentro wont send pix or connect to broadband access..i think?
Ok, so my verizon wireless palm centro phone will not let me send or recieve messages. It also says "roaming" on the homepage and idk its never said that before. Every time i try it won't let me. And it wont let me connect to the internet either. I DO have pix messaging, its included in my plan. Any suggestions? Its really annoying me
My palm Centro is having problems sending/recieving texts, and takes a long time to do it. i have full service...
Make sure that the memory isn't very full and that there aren't many programs running. Try a soft reset, I've never done it on a Centro, but Google will tell you.
Feb 17, 2010 | Palm AT&T C/PHONE PALM CENTRO S64801
Centro will not send or recieve calls or emails, shows no incoming signal (at&t)phone comes on all apps seem to work just will not send or recieve
if you don't card what you have in your phone, just try to hard reset your phone (everything will gone, and setting will be taken)..........
unless your phone has problem, then you should be fine.
make sure that you are using a AT&T SIM card (or you can ask anyone who using ATT service, then try their sim card)
Dec 29, 2009 | Palm Treo 500 Centro
Hi. I have a palm Centro phone through Verizon with a cracked screen. How do I go about replacing the screen?
If your Centro is in warranty then you should probably take it to a Verizon store and let them repair or replace it.
If you want to try to fix it yourself, a Google search for "palm centro screen replacement" will show you several sources for the parts needed. There are also some special tools you may need to buy. This video shows the process and should help you decide if this is something you want to try:
Oct 12, 2009 | Palm Treo 500 Centro
I cant use any other sim card on palm centro phone which is unlocked one. i can use airtel india with internet but others are not accepting internet connection
Every operator has its parametre for recieving data or GPRS and 3G (UMTS).Your phone is configured for airtel but if you want to use others their parameters must be entered separately and set as defaul correct one when changing SIM. To find parameters wisit other operators pages, there may be special numbers where you can call and recieve data messages containing parameters and simply save or find instructions how to manually enter them. Also you must activate WAP/GPRS function in every opearator and it winn need aditional charge.
Aug 03, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Palm centro won't receive multiple sms
Generally, 160 is the default limit for text messages. Some carriers will allow for up to 500 characters but that's usually within the same network (e.g. Verizon to Verizon). This is why text messages often use modified words (e.g. r u ok?, lol).
Mar 26, 2009 | Palm Treo 500 Centro
My verizon wireless palm centro is unlocked but now it wont send or receive picture or video message! Any ideas on what to do?
have u contacted your new network provider?
they will enable MMS for you, (multimedia messaging)
they send you a txt and you accept/install then it should work.
pls let me know if all goes ok
Mar 21, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Phone wont send or receive picture messages
call ATT, mine did this same problem, and it for some reason got kicked off in the ATT system that i didnt have the correct messaging plan anymore. it sounds odd, but it fixed mine. good luck!
you may try a master reset after backing up to your PC if that doesnt work.
Hope this helps! pls dont forget to rate the solution!
Mar 02, 2009 | Palm AT&T C/PHONE PALM CENTRO S64801
Mp3
go onto mytreo.net and they have things you can hotsync onto your phone like skins for pTunes. you have to download it then hot sync it from the computer
Feb 18, 2009 | Palm Treo 500 Centro
Connecting my PS3 to the internet using a 3G Verizon Broadband
Unfortunately the PS3 will not be recieving internet through this device, the USB connectors are set up to only work with PC or MAC specifically for that reason that gamers cannot use their Xbox or Playstation, and that is because Verizon offers a Wireless router cell phone data device which costs almost a thousand dollars, definately not worth it.
Jan 28, 2009 | Sony Playstation 3 (PS3) Console
Picture messaging
I've had the same issue, and I was told that in order to send or recieve picture messages, you have to subscribe to Verizon's Internet plan. The reason that you can still send and recieve text messages is because it's on a different system. I was a bit peeved when I found this out after the fact.
Jan 10, 2008 | Audiovox PPC 6700
Cell Phones Logo
82 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
