Bad smell in Simpson Eziset 550
I have a Simpson Eziset 550 which has developed a smelly-drain type smell which appears to eminate from the agitator - note that I clean the filter after each wash. I have used Epsom Salts and also a dishwasher tablet on the hot cycle (no clothes in, fill and agitate for 30mins, leave overnight, finish cycle) but while the dishwasher tablet was the most effective the smell returns. I was going to try and remove the agitator to see if there is any blockage under it but there is a bolt at the bottom and I'm not sure if it holds the agitator in or not. Any ideas appreciated. Phil
Pour a few litres of vinegar in the machine on low level of water and do a wash with no clothes in it. should clean tub and drain hose
Posted on Sep 12, 2009
    Problem Solver:
  • 3 Answers
Two suggestions, First I would check the drain hose located in back of washer totally clean out and put back. You also could try and use Iron Out through a complete cycle.
Posted on Sep 06, 2009
Simpson washing machine
you need a 10mm socket and some extensions and a ratchet take the fabric softer filter out and undo the ,bolt at the bottom of the agitator and lift out
May 28, 2017 | Simpson Washing Machines
I have a silk blouse caught under the agitator of my Simpson eziset 8.5kg top load washer. does the agitator come off?
They should come off though I am not sure of your machine, they are designed to be changed.
Mar 05, 2016 | Simpson Washing Machines
Where does the washing detergent go in a Simpson eziset 550 washer
Bleach goes in the left hand side portal softener is put in top of agitator an washing powder I normally dissolve at start when machine filling before putting items in
Feb 23, 2015 | Simpson Washing Machines
Simpson eziset 550
good day,
the problem of your unit is the main pcb board if electronic type or the mechanical switch problem, but same cause its burnt part and its hard to check. call the technician for your safety and to not waste your money to buy some part if you dont know what the main reason why its burnt part
Nov 02, 2013 | Washing Machines
Eziset 950 wont spin and gives slight electric shock
Possible that the motor has failed and it has developed a leak to the body which seems to be felt over the machine, Isolate the motor and test the external voltage presence.. if absent it can be related to the motor.
Jan 12, 2013 | Simpson Washing Machines
Eziset 550 Drains as it fills
Replace the fuse inside the control panel make sure you turn if off.
depending on where you are the fuse is more than likly a "4amp slow blow" fuse
hope this helps
Dec 02, 2012 | Washing Machines
Simpson eziset 550 stops at rinse cycle, light flashing
I had the same problem before, but removing the kink in drain hose does the trick. Maybe yours is more complicated but try it.
Aug 28, 2012 | Washing Machines
Simpson EziSet 750 washing machine won't spin - what am I looking for to fix it? Appears to be working in all other respects.
the lid-lock button keeps beeping on my simpson eziset 750washing machine. how do i make it stop!
Sep 20, 2008 | Washing Machines
Washing Machines Logo
975 people viewed this question
Top Washing Machines Experts
