Question about HP Photosmart C6180 All-In-One InkJet Printer
My HPC6180 turns on the display and then turn off on the button and cannot fully start ekkps turning on and off
    Brigadier General:
  • 8,619 Answers
Hi
You need to try to reset the printer using the # and the number 6 buttons, holding them down and then inserting the power cord at the back of the printer. You can also unplug printer in back while ON. Then hold the "Cancel" and the "OK" button and put the plug back in, after you turn it back off/on it should work.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Sep 06, 2009
2010 equinox. oil change due warning won't go off after oil change. how do i reset?3 times gas pedal, engine off then start,100% thanks'
Turn IGN to ON/RUN but don't start engine
Fully depress pedal 3 times within a total of 5-secs
If you have the Driver information center
Press the DIC menu button until Remaining Oil life displays
Press and hold the set/clear button until 100% displays
Turn the key to OFF
Aug 27, 2017 | Cars & Trucks
Tip
Chevrolet service light 1991-01
Camaro
1998-01
To reset the "OIL CHANGE" light, press and hold the "TRIP/OIL RESET" button on the instrument panel for 12 seconds. When the light flashes and then goes out, the system is reset.
Corvette
1997-01
To reset the monitor after an oil change, turn the ignition on. Press the "TRIP" button so that the "OIL LIFE" percentage is displayed. Press "RESET" and hold it for two seconds. The word "RESET" should appear on the monitor, then "OIL LIFE 90%".
Impala,
Monte Carlo
2000-01
Turn the ignition to ON without starting the engine. Fully press and release the accelerator three times within five seconds. If the CHG OIL SOON lights two times, the system is resetting. Turn the key to OFF, then start the vehicle. If the CHG OIL SOON light comes back on, the system has not been reset, repeat the procedure. Follow this procedure to reset the GM Oil Life System using the DE 100 Series Radio. Turn the ignition to ACC or ON and the radio off. Press and hold the DISP button on the radio for at least five seconds until SETTINGS is displayed. Press the SEEK up or down arrow to scroll through the main menu. Scroll until OIL LIFE appears on the display. Press the PREV or NEXT button to enter the submenu. RESET will be displayed. Press the DISP button to reset. A chime will be heard to verify the new setting and DONE will be displayed for one second. Once the message has been reset, scroll until EXIT appears on the display. Press the DISP button to exit programming. A chime will be heard to exit programming. A chime will be heard to verify the exit.
Impala,
Caprice
1994
To reset the "CHANGE OIL" light, turn the ignition switch to the run position with the engine off. Access the reset button on the end of the instrument panel by the fuse block. Press the switch and hold it for at least 5 seconds.
Lumina,
Monte Carlo,
Impala,
Caprice
1996-00,
1996-99,
1995-96,
1995-96
To reset "CHANGE OIL" light, turn the ignition switch to the run position without starting the engine. Fully depress and release the accelerator pedal 3 times within 5 seconds. The light will flash and go out.
Corvette
1990-96
After an oil change, or when "CHANGE OIL" appears on the Trip Monitor, with the ignition on and engine off, press the "ENG MET" button (located on trip monitor) once. Press the "ENG MET" button again within 5 seconds. Within 5 seconds, press and hold the "RANGE" button (1990-1994) or "GAUGES" button (1995). The light will flash. When it stops flashing and goes out, the system is reset.
Chevrolet Suburban,
GMC Yukon XL,
Chevrolet Silverado,
GMC Trucks Sierra
2000-01,
1999-00
Turn the ignition key to the RUN position. Fully push and release the accelerator pedal 3 times within 5 seconds. If the CHANGE OIL SOON light flashes 2 times, the system is reset. However, if the light comes on and stays on for 5 seconds, the system did not reset. Repeat the procedure if the system does not reset.
Silverado, Sierra Trucks
1991-93
To reset the "CHANGE ENGINE OIL" message, turn the ignition key to the run position. Press and release the accelerator pedal three times within 5 seconds. If the light flashes for 5 seconds, the system is reset. Repeat procedure as needed.
on Dec 07, 2009 | Chevrolet Camaro Cars & Trucks
Software is unable to start and a fault is displayed immediately after start of software.
try to turn it off. get the network cable out the machine. wait 1 minute. press 6-stop-powersave (all 3 at the same time, powersave top right corner) With these buttons pressed, start the machine and keep the buttons down until machine is fully started.
Nov 14, 2013 | Xerox Workcentre 7335 All-in-one Laser...
Why does my monitor die (it goes black) when I remove the adapter even if the battery is 100% fully charged?
Try going into your control panel, and resetting the options for your display.
Mine works this way...click Start button lower left corner of screen.
Type the word display in the search box. that will open a window that will allow you to decide when the display can be turned off.
If that doesnt get you to display settings try pushing Start button,Find the Control Panel button and clck it.Find Mobile PC, or Power Options. If you find Mobile PC click it, then find Power Options.on the left side is a caption that allows you to dicide when to turn off the display. Hope it helps
Jan 25, 2013 | Lenovo G480 218422U Dark Brown 3rd...
How to turn of change engine oil light on 2011 ford focus
From FocusFanatics online - -
Resetting the oil life monitoring system
1. Turn the ignition key to the on position. Do not start the engine.
For vehicles with push-button start, press and hold the START/STOP
button for two seconds without pressing the brake pedal. Do not attempt
to start the engine.
2. Press both the accelerator and brake pedals at the same time.
3. Keep both pedals fully pressed.
4. After three seconds, the Service: Oil reset in prog. message will be
displayed.
5. After 25 seconds, the Service: Oil reset complete message will be
displayed.
6. Release both the accelerator and brake pedals.
7. The Service: Oil reset complete message will no longer be
displayed.
8. Rotate the key to the off position.
For vehicles with push-button start, press the START/STOP button to
turn the vehicle off completely.
Jul 07, 2012 | Ford Cars & Trucks
My casio elexim has a system error 0e01. Thanks. Irene.
Please download a backup of the firmware from this site: http://www.oborona.net/stuff/qv-r40/QV-R40.zip
Turn off your camera. Press down "Menu" and "Disp" simultaneously and hold down, then press the power button until the camera turns on. The display will now display some tech gibberish. Quickly press the ring joystick right 2 times, then press "Menu" again.
You should now be in the engineering menu of the camera. Please do not change settings in here. Now the camera can be connected to the PC via USB. Place the file from the start on the camera.
Disconnect your camera and turn it off. Hold the "Menu" button down and turn the camera on.
You should see "PROGRAM UPDATE" on the display. Select "Yes" and wait for 30-60 seconds, while the camera starts flashing.
Your camera should now be fully functional again.
Aug 26, 2011 | Casio QV-R40 Digital Camera
How do you set it on english
Follow these steps to resolve the issue.
  1. Unplug the power cord from the back of the product.
  2. Press and hold the OK button and the Help button simultaneously, and reconnect the power cord.
  3. Continue pressing the buttons until the display goes blank or Reset shows on the control panel display.
  4. If the product automatically turns off, turn it on.
  5. Allow the product to fully start up before continuing with the product setup.
  6. Select the correct language code and region when the product prompts.
Regards
Riztech
Nov 26, 2010 | HP Photosmart C5280 Printer
How do I reset my oil light on my 2004 Buick Rendezvous?
Turn the ignition to ON without starting the engine. Fully press and release the accelerator pedal three time in five seconds. If the CHANGE OIL SOON’ indicator flashes two times, the system is resetting. Turn the key to OFF, then start the vehicle. If the CHANGE OIL SOON indicator comes on and stays on for five seconds, repeat the procedure.
Sep 07, 2009 | 2004 Buick Rendezvous
Set language in german
  2. Press and hold the # and 6 buttons simultaneously on the control panel, and then reconnect the power cord.
  5. Allow the product to fully start up, and then select the correct language code and country/region when prompted.
Jul 17, 2009 | HP Photosmart C7280 Laser Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
13 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
