Question about Canon PIXMA MP530 All-In-One InkJet Printer
My OG5 ink cartridge went dry ( I shouod have
My PG5 ink cartridge went dry ( I shouod have changed sooner ) now all I get after turning on the MP530 is a dsiplay saying to check printer code A600
    President:
  • 2,306 Answers
6A00 means the purge assembly is stuck. Replacement is the best, QM2-3032-000.
Posted on Sep 08, 2009
After some colour copying on my MP530 I tried to print, but had issue that all black parts were not printed at all. So I changed cartridges (previous one were not empty), but problem persists. Black color...
from the solutions center or from proprietis of printer select clean the prin cartige if after that problem persist clean the circuit from the printer where the black cartige has entered with alchool. after the circuit is dry put the cartidge back and click clean again.
May 17, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Canon mp530 printer
With the power on to machine and it turned on, open scanner lid by lifting entire top upwards(operations panel lifts up), cartridge mechanism should move to the left to allow cartridge removal, push cartridges down to remove.
here is link to user guide
http://www.usa.canon.com/consumer/contro... cut copy and paste this link will work http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=116&modelid= 13368#DownloadDetailAct
Dec 07, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Are my ink cartridges drying out in the printer? The printer indicates they are empty when they are not.
Yes, if you don't use them on a regular basis and generally after about 3 months the ink begins to dry out inside the cartridges - even sooner if you live in a dry, hot place.
Oct 08, 2010 | Kodak ESP5250 All-In-One InkJet Printer
I need a new print head
Check if the service station proper covers the black nozzles when the printhead is parked. Sometimes the mechanics change its position and the printhead dries out.
Try to unclog the nozzles with very hot water. Sometimes it helps. The new printhead is very expensive and you may want to buy a new printer instead.
Remove the printhed, put it in a bowl with the nozzles down and fill with boiled water until the nozzles are covered. Wait 15 min and dry the electric contacts with a dry napkin. Good luck!
Jun 15, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Set ink cartridge message on canon mp530
1. Set all the printer cartridge both black and color cartridge (including the empty one)
2. Right click on printer driver properties
3. Click Maintenance tab
4. Click on Ink Cartridge Setting mark
5. In pop up menu, select the cartridge which has ink inside (black only or color only). or get more information for set ink cartridge .
Jan 29, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Canon mp530 - colors print dull and faded
The ink tanks may be full but sometimes the pins that connect the cartridges to the printer may have dried up ink on them preventing the ink from flowing. You can try to swab these with a bit of rubbing alcohol on a Qtip and letting it dry for moment or two. I would strongly suggest doing a couple of deep cleanings first and try test printing of the individual colours separately in a program such as paint to see which colour is affected.
Jan 24, 2010 | Canon PIXMA MP530 All-In-One InkJet...
How do i change ink cartridge on canon mp530
Here is a link to the user manual for your MP530.
Go to page Chapter 8, Page 99 for step by step instructions on changing an ink cartridge...
http://gdlp01.c-wss.com/gds/0900002804/mp530_ug_us_v2.pdf
You may want to save the manual to your PC for future reference.
Nov 27, 2009 | Canon PIXMA® MP530 All-In-One Printer
Ran out of black ink. replaced cartridge. now
If it ran dry before you replaced it then you need to do a deep clean of the head. This can be done under the maintenance tab of printer properties. If that doesn't get it working then physically remove the print head and clean it with a water moistened cotton bud (make sure you use a separate cotton bud for each ink nozzle). Running a cartridge completely dry can (and often does) damage the print head (overheats due to lack of cooling provided by the ink flow).
Oct 03, 2009 | Canon PIXMA MP530 All-In-One InkJet...
How do I get my first blank ink cartridge to work?
you really need to replace the empty cartridge...it's a protection for keeping your printhead from drying or else the micro nozzles will be clogged with dry ink. did u try setting the printer settings to use greyscale or black and white only?
Aug 11, 2009 | Canon PIXMA MP530 All-In-One InkJet...
MP600 printer won't use the 8 BK black ink
Quick and easy way to do this is to use the automatic duplex more as this uses the 8K cartridge instead of the 5K.
Thing to note is that the 8K is the photo black and dyebase whilst the PG5 is a pigment ink.
As a general rule you'll want to use the PG5 because it's cleaner and sharper for text while the 8K is much better for photo quality inks...
... and the reason it's used for duplexing? Simple... it dries quicker! .. So, you don't have to wait as long for the page to be pulled back in and you get less chance of smudging...
Hope that helps...
Mar 13, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
79 people viewed this question
old marine
old marine
