Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Fuse in electrical system keeps blowing can't find cause?
  • 582 Answers
OK, TRY DISCONNECTING THE LIGHTS AND CHECK ALL THE WIRES FOR BARE SPOTS DON'T JUMP OUT THE FUSE SOME PEOPLE TRY TO FIND THE SHORT BY DOING THIS AND END UP BURNING THE WIREING HARNESS. THERE HAS TO BE A DEAD GROUND SOME WHERE TO BLOW THE FUSE THAT QUICK
Posted on Sep 06, 2009
Dodge radio problems
fuses blow because of excessive current flow from a dead short to earth. You haven't stated which fuse blows and what the items are covered by that fuse. so check the power wire from that fuse and trace it until you find a burnt area or a place where the power wire is touching the body before it gets to something it is running
Dec 22, 2013 | Cars & Trucks
Cause fuse keep blowing
-Sounds like power line touch ground some where between door and to fuse block.
Mai Lor
Oct 07, 2013 | Honda Odyssey Cars & Trucks
A/t Cont fuse Nissan Navara keeps blowing
Fuses only blow if the load is heavier than it is designed for. Most likely causes are, Shorted wire. Defective part To small fuse. If you have the correct fuse then somewhere in the wiring circuit is asking for too much. You need a good electrical tech to find out your cause. If it blows the fuse once a month then this can be a pain in the rear to find the cause. Most wiring is made very durable. Look for damaged areas, or where work has been performed in the past and wiring has been disturbed and not properly secured. Look for alterations, Hope that helps.
Dec 28, 2012 | 2005 Nissan Pickup Navara
20 amp ignition fuse keeps blowing on my 2003 dodge stratus
SOunds like a closed short in the ignition system. The actual ignition could be at fault. The starter may be at fault. Pinched or exposed wiring touching the chassis or another live wire may be the cause. Check your manual to be sure the 20 amp fuse is the proper fuse for the ignition system. It may just be to low of an amp and may be a 25 to 60 amp fuse or more. Only use the recommended size of fuse as using too high a amperage in a fuse can cause bigger problems if the fuse does not blow in time. These fuses serve a purpose to save the electrical and electronic parts form unnecessary damage.
Sep 21, 2012 | 2000 Dodge Stratus
Headlight fuses keep blowing
You have a short circuit somewhere in the wiring. Either a cut or bare wire. If not, the headlamp is causing the short. Last resort, use a higher amp fuse (but this may compromise wiring system).
Jun 17, 2012 | 1998 Mercury Villager
Fuse #109 keep blowing/ driver seat not working please help
If the fuse keeps blowing, I assume it is because you keep replacing it. Those fuses have given up their lives to keep your truck from burning to the ground. Each time a fuse blows, the wires in the system get heated up and weakened. If you keep replacing the fuse, the insulation will eventually burn off of the wires and light the entire truck up. There is a shorted component or wire on one of the circuits that are protected by that fuse. Replacing the fuse without locating and repairing the reason that it blew, will only result in another fuse having to give up its life to keep your truck from roasting and all the other fuses will have died in vain.
The circuits to that fuse will need to be traced, using the wiring diagrams for your vehicle and the proper equipment necessary for performing tests on your electrical system. Nobody online can tell you what the actual cause of the problem is (other than tell you there is a short) without performing the necessary tests on the vehicle itself.
Jan 29, 2011 | 2006 Ford F-150
I have an 03 tiburon and my low beam fuse keeps blowing ? i trid to put a 30a fuse and its still blowes could some one help? thanks
you need to diconnect the lights then replace the fuse turn on the light switch. if the fuse dose not blow you have a bad light. if it blows . look for bear wire.
Feb 25, 2010 | 2004 Hyundai Tiburon
Interior and exterior fuse keeps blowing on my 1999 sunfire
if the fuse keeps blowing then there is an electrical short somewhere and this needs to be found and repaired, fuse keeps blowing so the wires don't over heat and cause a fire, do not put in a larger fuse than is required you can cause a fire
Sep 15, 2009 | 1999 Pontiac Sunfire
THE IGN A FUSE UNDER THE HOOD KEEPS POPPING
You have a serious short. The fuse is keeping you from frying the electrical system. Did you make any changes to the vehicle recently? Is it all stock electrical? If so, check the Ignition relay in the alternate fuse panel. If that does not work, post a reply and I'll help you dig further. Hope this helps
Jun 04, 2009 | 1995-1997 Chevy Tahoe Ignition Starter...
Meter fuses keep blowing out on 1996 nissan altima
you have a short to ground somewhere. Look for worn wires, loose connections, any work recently done.
Dec 09, 2008 | 1993 Nissan Altima
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
162 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
