Question about Casio EXILIM ZOOM EX-Z850 Digital Camera
Zoom disp set mode dont work - Casio EXILIM ZOOM EX-Z850 Digital Camera
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Posted on May 22, 2008
Fuji FinePix S9500 has a blank viewer & lcd screen, it has powered up but nothing is being displayed in either.
This took me a bit, in fact I needed to got to one of my Fujifilm cameras to see if I could duplicate what I was thinking the problem could be. So here goes. There is a small button on the back body just off the lower right side of the LCD screen it has Disp/Back written on it. What I'm saying is that this button has been pushed to give a blank screen which will affect both the viewfinder and the LCD. To get to that point I had the camera in Manual mode ISO at 100 and the lens cap on. The aperture was set for F9 and the shutter at 1/60th. My camera has a "shake" icon so in Auto and program there was the shake icon on the LCD screen it also showed in the "A" mode as well. Now that said my version of your camera may be a few models ahead, your camera may not have the camera shake feature or icon. In short I think you have pressed the "Disp/Back" button and changed the view mode.
Dec 20, 2010 | Fuji FinePix S9500 Zoom Digital Camera
How can I reset the camera or modify the date & time of it? Regards
Initial settings
Y
our camera's display language, date and time
should be set before taking photos or videos.
To set the date and time:
1 Turn the power on. Press the Menu button to
enter the camera's settings menu.
2 Press to select the Setup tab.
3 Press to select Simple Mode, then OK/DISP
to open the Simple Mode submenu. Set Simple
Mode to Off.
4 Press to select Date & Time, then press
OK/DISP to set the date and time.
5 Press , , , or to adjust the date and time.
When you are done, press OK/DISP.
Dec 14, 2010 | Insignia NSDSC10A Digital Camera
How do I reset the change engine oil light on this vehicle after changing the oil?
Go into the vehicle settings with the radio controls. With the key turned to ACC, hold DISP on the radio for about 6 seconds and it should go into settings mode. Press DISP until you see oil life in all caps, then use Prev. & Next to scroll to reset oil life mon., then push DISP again. you should here a beep and the display should read Done. Scroll to Exit and press DISP again. Good luck
Jul 11, 2010 | 2003 GMC Envoy
I am unable to see what I am taking a picture of.
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Apr 03, 2010 | Canon Powershot A1000IS 10MP Digital...
2001 Impala TPMS reset, radio and headlight options DONT WORK
CHEVY IMPALA &
MONTE CARLO
On a Chevy Impala or Monte Carlo with indirect TPMS, a totally different reset procedure is required. You can use the light switch or radio to reset the system. With the light switch procedure, turn the ignition on (engine off), the turn the light switch from OFF to parking lamps three times within five seconds. With the radio technique, turn the ignition on (engine off). With the radio off, hold the DISP button until “SETTINGS” is displayed. Use the SEEK button to scroll down the menu until you see “TIRE MON.” Press the PREV or NEXT buttons until “RESET” is displayed. Then press the DISP button again. You should hear a chime and see “DONE” to indicate the TPMS system has been successfully reset. Use the SEEK button to scroll through the menu until “DONE” is shown, then press DISP once more to exit from the learn mode.
Dec 24, 2009 | 2001 Chevrolet Impala
My FZ18 will not zoom. Stuck at wide angle. A msg will sometimes flash when first turned on...CAMERA WILL RETURN TO PREVIOUS ZOOM SETTING...or something like that. It functions otherwise. I have been thru...
Set camera to P mode.
Press [MENU ] to display the [SETUP] menu
and select the item to set.
The [REC], [CUST. SET MEM.] or [SETUP]
menu settings are reset to the initial
settings.
• [FAVORITE] (P98) is fixed to [OFF] and
[ROTATE DISP.] (P97) is fixed to [ON].
• If the [SETUP] menu settings are reset,
the following settings are also reset.
See page 22 in manual.
http://www2.panasonic.com/consumer-electronics/support/Cameras-Camcorders/Digital-Cameras/Lumix-Digital-Cameras/model.DMC-FZ18K
This should reset whole camera to factory setting.
Cheers.
Jul 08, 2009 | Panasonic Lumix DMC-FZ18K Digital Camera
Zoom, DISP & SET controls not working
I too have the exact same problem, and an online search turns up others with similar Casio Exilim models, with the same problem. It involves a malfunctioning Disp, Zoom, and non-functioning Set button, with all other functions working OK. Casio Support seems to recognize the problem, and indicates it has to be fixed at one of their authorized repair centers. Start with their online system: https://www.ecasiorepair.com/
Nov 01, 2007 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Canon Powershot SD600
In shooting mode press DISP. The display mode changes with each press.
Standard>Detailed>Off
I think you have it currently set to off.
Oct 20, 2007 | Canon PowerShot SD600 Digital Camera
Manual Focus
1) Press and Hold the FOCUS button until to you "MF" appear in the lower left corner of the LCD Display on the back of the camera. Then you can release the Focus button. 2) Press and Hold the DISP/i button to see the Manual Focus Range. 3) While holding the DISP/i button, use the Tele/Wide Zoom Key to set the desired Manual Focus. You can see the focus change as you toggle the zoom key. 4) When you are ready, release the DISP/i button and Press the Shutter Button to take your picture. *Press the Focus Button to return to Auto Focus / Macro options
Sep 15, 2005 | Toshiba PDR-M71 Digital Camera
Manual focus
Sep 15, 2005 | Toshiba PDR-M81 Digital Camera
Casio EXILIM ZOOM EX-Z850 Digital Camera Logo
41 people viewed this question
Top Casio Cameras Experts
atollminsk
Level 1 Expert
pontelemon
pontelemon
Starnley Johnwells
Starnley Johnwells
Are you a Casio Camera Expert? Answer questions, earn points and help others
