Question about Canon PowerShot A95 Digital Camera
My LCD Monitor displays only black w/ fuzzy white bands or blocks as I move it around. No images come on at all. This was an intermittent problem, but now that's all I get. All 14 modes affected - none work. Cannot take pictures at all, however, images on the CF Card are still viewable.
  • jahoule321 Sep 06, 2009
    Thanks for responding.
    Yes it is a Canon PowerShot A95, Model PC1099
    Thanks for your help. With your help I went to Canon's site and was able to ask the right questions. They are going to repair it!
    Many thanks!!!
  • 10,594 Answers
Is this Canon A95 camera or some other model?
Let me know exact model number please as symptom shows its defective ccd imager IC problem.
Awaiting your reply to proceed.
Thanks.
Posted on Sep 05, 2009
  • Shahid Electronics
    Shahid Electronics Sep 06, 2009
    OK, Canon will repair it free of cost.
    get back to you shortly with more info.
    Click Canon CCD Imager Advisory for details, Canon will repair A95 camera free of cost.
    Thanks.
Display problem
Sounds like the LCD has some damaged crystals in it. Try connecting the netbook to an external pc monitor using a VGA cable. Hold the Fn key and hit the F8 or F7 key until the display shows on the external monitor. This will determine if it's a driver/settings or display issue. If the display is fine on the external monitor, the LCD display on the netbook is the problem. Good luck!
Jun 06, 2012 | Computers & Internet
I get ghost images. Is there a way to de-gaus an LCD monitor?
Sounds like it's either ghosting, or image persistance.
Ghosting on LCD monitors is usually caused by interference via the monitor cable. Try moving your monitor cable so that it doesn't pass near any other cables or electronic devices. If that helps, then position the cable away from the others perminantly or replace the cable with a "shielded" monitor cable.
Image persistance on an LCD can be caused by leaving it on with the same image for a very long time. The pixels don't exactly "burn-in" like on the old CRT monitors, but over time, they can develop a memory that causes them to change color slowly or incompletely. Prevention is best (turn the monitor off when not in use, or use a rotating screen saver.) But if it is already a problem, you do have a few options. You can turn it off for a long time, run a rotating screen saver for a long time, or display a solid white screen for a while. Another technique is to create a slideshow in the Windows screensaver with a solid white image and a solid black image (create them in MS Paint and save them where you can find them later.) Let it alternate between the white and black screens for a while and check to see improvements.
Jan 11, 2011 | Envision EN-7100e 17" Flat Panel LCD...
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
Dell LCD Monitor Pictures, Dark Colors Course, Fuzzy, Pixelly
You might find a BACKLIGHT FLUORESCENT BULB on eBay.
Jul 04, 2009 | Dell E173FP 17" LCD Monitor
LCD Monitor pixels that should be black are white
The contrast of the monitor is very low. reset the monitor settings using the menu button in the monitor.
Apr 17, 2017 | Sony STYLEPRO SDM-S71R/B (Black) 17" LCD...
White screen appears, Screen turns fuzzy intermittently
To determine if the video card is faulty or the LCD screen, connect an external monitor to the laptop. Power up the monitor first and then the laptop. The video will automatically switch to the monitor. If you see a normal Windows image the the video card os OK.
The next thing is to reseat the video cable and if this doesn't fix the problem then the fault is the LCD screen.
May 23, 2009 | Acer Aspire 2930-4661 Notebook
Monitor lcd acer al2016w 20" letters and image are fuzzy,,why?
I also have an Asrock motherboard (M266A) and have the AL2216W. The image and text is also fuzzy. I did improve it a by by unplugging/replugging all of the connectors on the back of the computer. I believe my mouse had a somewhat loose connection and this was causing interference. I can actually create interference on screen by moving my mouse up and down.
These Acer monitors seem to be very sensitive. I also tried this monitor on a old Desktop with Win98 and another new laptop with XP and it looks good on those computers, but not on my Asrock based system.
Nov 30, 2008 | Acer AL2016W 20" LCD Monitor
KDS K717s 17" LCD Monitor
The white screen tells me that the display cable (inside your monitor) may be unattached or broken.
The color bands if they are vertical or horizontal lines tell me that your display cable needs to be replaced.
So overall replace your display cable. If this doesn't entirely fix the problem your logic board (inside the monitor) needs to be replaced.
Feb 21, 2008 | KDS K717s 17" LCD Monitor
Fuzzy, shadowy LCD monitor warranty
Occasionally the cuplrit to a shadowy haze on an lcd monitor is the VGA cable. A new one that is better shielded may help.
Jan 25, 2008 | Gateway FPD2275W LCD Monitor
Canon PowerShot A95 Digital Camera Logo
83 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
