Question about Sony Ericsson w580i Cellular Phone
When I try to take a picture the screen shows: Close all applicat
When I try to take a picture the screen shows: 'Another application is running. Close it and then start the camera." I have checked all applications and can't find one that is running.
Every time I try to open my irulu tablet camera, it says unfortunately UHD player has closed. I can't take any pictures.How do I fix it?
Go to settings >applications >running and force close UHD player and camera. If they don't show up there click menu and show cached processes. If not try a factory reset but backup everything first.
Jun 10, 2015 | Irulu 7" Google Android 4.0 Capacitive...
I have nokia n73 phone.it's showing genaral memory full close some application and try agin when watching videos editin images etc.
Long press navigation or menu button,if there are existing application running or unwanted application,navigate that apps and just press c to exit or close that application.this may happen when you open an apps and do not close the apps properly then open a new one,this error takes place. If does not work,you need to format the phone to remove the unwanted running application on your system,just type *#7370# on your home screen,a lock code will be ask then enter your preferred code if change before, or 12345 as the default code,be sure to back up all of your data before doing this method.
Jul 27, 2011 | Nokia N73 Cellular Phone
Profile pictures do not come up for people I am chatting with and vice versa. Before I downloaded the update for the messenger they were showing. how do I get the profile picture to show?
1. Reboot your computer. 2. Press Ctrl+Alt+Del on your keyboard. Thiswill bring up the Windows Security window. Click the "Task Manager"button and then click the "Task Manager" tab. 3. You will see a list offiles/applications. These are the applications running in the background onyour system, whether they show on your taskbar or not. Any one of theseapplications could be causing a conflict with the Yahoo! Messengerinstallation. 4. Click the top item on the list tohighlight it. Then hold the "Shift" key down and click the last itemon the list. This should highlight the whole list. 5.Click the "End Task" button. This will temporarily close allbackground applications on your system. 6. Click the "X" in the upperright corner to close the Task Manager window. 7. Install Yahoo! Messenger. You should notexperience the same issue that you had before. 8. After Yahoo! Messenger is installed,runregistry cleaner reginout also rebootyour system. All other background applications will return to their originalconfigurations.
Feb 19, 2011 | Yahoo Messenger
Can't take pictures with my sony ericsson w350
Press and hold the back arrow button.Then if some applications are running, then you can see the popup for minimizing the application and close the application.If any window is coming, please close the applications if any.
Aug 22, 2009 | Sony Ericsson Walkman® W880i Cellular...
Text will not send
Sorry about the prompt on your phone, please follow the the simple steps I'll outline to close the open applications on your phone.
Step 1. Press and hold the "Home Key", you would have the open applications show up on the left corner of your screen. Scroll to 1st application you wish to close, and then ok it. Once you do this you would be in that application that is open.
Step 2. when trying to close the application that you are in right now, select on the options on the bottom left of your screen and ok exit. Once you do this that application is closed.
Step 3. repeat the process on Step 1 & Step 2 until you have just one application running on your e71, which is the "home screen".
Hope this helped, please specify if it did.
kind Regards
Jul 25, 2009 | Nokia E71 Smartphone
My camera is not working/ black screen.it tells me to close apps
Alright, I just had this problem. I dont know how this happened, but some settings were changed. If you go to media and press the menu button then go to options. Now change device memory limit to 15mb and reserved picture memory to 2mb. Now try your camera, it worked for me.
Jun 27, 2009 | RIM BlackBerry Curve 8310 Smartphone
It showing message while i open the camera"Another application is running.close it and then start the camera".
yea i have this phone it usually only does that if you are talking but some spplications and the camera cant run at the same time like when your listening to music.. it stops when picture is taken so ya...
May 31, 2009 | Sony Ericsson w580i Cellular Phone
Lexmar X5410 - scaner
Does scanning work when initiated from the computer using either the "Imaging Studio" or "Productivity Studio" software that came with the printer ?.
Here's the link to the user guide:
http://www.lexmark.com/publications/pdfs/2007/5410/v8760668_en.pdf
Goto to page 69 for help with scanning.
Hope this helps !
Mar 30, 2009 | Lexmark X5495 Printer
Nokia 6630 problem
hi! may be you do not close web and just switch to oher applications. this cause the current open application to run in background which consumes bettery! make sure to close applications properly.here is the tip "press and hold menu button, it will show list of opened application on top left of the screen, goto those applications and close them"
hope it will work!
Jan 30, 2008 | Nokia 6630 Cellular Phone
Sony Ericsson w580i Cellular Phone Logo
201 people viewed this question
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
