Question about LeapFrog Video Game Consoles & Games
Leapster only bottom right of the touch screen working
If I try to recalibrate it does not work. It will only recognize when I touch the bottom right side of the touch screen. Help!
I am having this same problem i don't know what to do my daughter loves her leapster
Posted on Feb 23, 2010
I recalibrated the leapster2. It recognizes the stylus on the calibration screen. When I reboot it still doesn't recognize the stylus at all. Please help.
If your Leapster does not respond to the stylus pen, it needs to be calibrated.
The following are instructions below on how to recalibrate the leapster.
1. Insert a cartridge, turn the unit on and wait for the sign-in screen to appear.
2. Hold down the Home, Hint and B buttons simultaneously.
3. When the screen changes, press the A button.
4. Using the Stylus, touch the center of the targets.
Thanks for using Fixya.
Feb 06, 2011 | LeapFrog Leapster Electronic Book:...
I have leapster l-max and am having trouble with the stylus working. when i try to calibrate, i can't click on center targets
Leapster L-Max recalibrates differently. I was trying to use the instructions and it kept asking for a blue button. For the Leapster L-Max push B, A, Hint, and Home when you turn it on. Do not have a cartridge in the player or it will think it is a regular Leapster. Once it says calibrate screen it will say to press A, then wait until a target appears in the upper left hand corner, touch it and you should hear a sound, then a new target appears in the lower left hand, repeat actions, then lower right hand screen, and finally the upper right hand screen. If it stops at any time and doesn't get more arrows, try it again or turn it off and see if the pen works. It may take several times to get it working again.
Feb 05, 2011 | LeapFrog LeapSter L-Max Console
The Leapster turns on and the sign in screen comes up but the touch screen does not work. Recalibrating does not work. Can't get past the sign in screen
How did you try recaibrating? I just fixed my son's Leapster 2 a few minutes ago. I read a couple different recalibration instructions and the one that works for the Leapster 2 is:
1-Hold down the (?) Hint button while turning on the system.
2-Keep holding it down until the Leapster menu shows up
3-Let it go and press the A button
4-Touch each crosshairs x with the pen tip
5-When it goes back to the menu screen, restart the unit
Jan 21, 2011 | LeapFrog Leapster 2 Learning System
When my daughter touches any object with the pen nothing happens. It will keep telling you to touch a picture on the screen with your pen.
You need to recalibrate. Try pushing B, A, Hint, and Home when you turn it on. Do not have a cartridge in the player or it will think it is a regular Leapster. Once it says calibrate screen it will say to press A, then wait until a target appears in the upper left hand corner, touch it and you should hear a sound, then a new target appears in the lower left hand, repeat actions, then lower right hand screen, and finally the upper right hand screen. If it stops at any time and doesn't get more arrows, try it again or turn it off and see if the pen works. It may take a few tries to get it to recalibrate correctly.
Jan 05, 2011 | LeapFrog LeapSter L-Max Console
Pen not working on screen to use
Hi, have you tried to recalibrate the screen as in your instructions?
Make sure you have no game inserted
Press and hold down the 'on' button and 'hint' button (with questionmark on it) at same time until a menu appears on screen
Press A
Now touch all the little crosses with your pen that appear on the screen
switch leapster off and restart
if still not working, repeat above
Jun 15, 2009 | LeapFrog Leapster 2 Learning System
Hi... I have a leapster whose stylus and screen aren't responding well to each other. For example, in color corral, you can color at the top of the screen, but can't select any tool changes at the bo
Call up Leapster (c/s I reached was not in USA) and they will have you send in your Leapster and send you back a new or refurbished one. I was told this a few years ago, but never mailed it in. We had an issue with it shutting off, but seems to be ok? The kid's don't complain.
May 31, 2009 | Leapster Learning System
Touch screen and stylus pen not working
I just had the same problem and found a solution on another thread on this site. Clean the screen really well with Windex and dry it. Check all 4 edges for crumbs that might be lodged in there. I found one tiny crumb. I dislodged with a small nail file (gently!), wiped the screen off and then it worked! I didn't even bother recalibrating it. When I turned it on and went to the sign in screen, it was working fine. The original post also said to try "milking" the screen in case pressure had caused it to stick. Press gently with your thumb on the screen in various spots around the screen, then try again.
May 26, 2009 | Leapster Learning System
Leapster 2 Doesn't Recognize Stylus
Hold the hint button (question mark) when turning on the device. When the device turns on, do the stylus calibration and touch each of the crosshairs that shows up. After you are finished restart the leapster and you should be fine.
Jan 03, 2009 | LeapFrog Leapster Electronic Book:...
Leapfrog Leapster touch screen
Got my son's to work. Used these instructions.
Question Why doesn;t my Leapster2 respond to the stylus pen? trnsp.gif Answer If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Feb 11, 2008 | Nintendo Game Boy Advance Console
Video Game Consoles & Games Logo
112 people viewed this question
Top LeapFrog Video Game Consoles & Games Experts
Dustin
Dustin
Raymond Richards
Raymond Richards
Andrew Taylor
Andrew Taylor
Are you a LeapFrog Video Game Console and Game Expert? Answer questions, earn points and help others
