Question about Sanyo DP19647 19 in. LCD TV
Sanyo DP19647...power comes on but no picture on screen. Any ideas?
Main Power Board is damaged, you have to replace but it´s an expensive part maybe the best is to buy a new TV
Posted on Sep 20, 2009
  • 3 Answers
There are 7 caps on the power supply board that probably need to be replaced. I just fixed one that powered up, had sound but the screen blinked by doing this.
Posted on Jun 13, 2012
I have a 19 inch sanyo hdtv dp19647 , but no remote. I grabbed the first universal that i had lying around and used the search for code mode. I found the code real quick. I think that you can probably use any universal remote. But you may have to do the searh if it does not supply a choice of codes for your particular hdtv I hope that this is helpful.
Posted on May 01, 2012
Power on but picture ihave sound the volume goes up and down
can also change channels had tv over 2 yrs no problems prior to
this had a picture earlier i checked everything don't know what it could be?
Posted on Jul 02, 2011
Power come on but ligth blinkin g
Posted on Jan 09, 2010
My Sanyo HD TV power light comes on but no picture and no sound.
Fault with the main power supply regulator section. Either it will be on a separate board, or on the part of its main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jul 28, 2015 | Sanyo DP19647 19 in. LCD TV
Why did my sanyo 19" hdtv all of sudden went black? what to do now?
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Aug 12, 2014 | Sanyo DP19647 19 in. LCD TV
Samyo dp19647 green light flashes but no piture
sounds like a bad mainboard or power supply
Feb 03, 2013 | Sanyo DP19647 19 in. LCD TV
Green power light want stop blinking
Problem is with one of the circut boards in the tv, It will have to be replaced.
Oct 21, 2012 | Sanyo DP19647 19 in. LCD TV
Sanyo DP19647 HD picture, but no sound
Check whether it works on the headphone. If it does not, look for any jammed button on remote. If that is ok, the set might need attention by a qualified service technician. In order not to miss the Olympics, connect the audio out to any other amplifier either from the TV (if it works) or from the set top box.
Jul 31, 2012 | Sanyo DP19647 19 in. LCD TV
MY SANYO DP19647 DOESM'T WORK ON MY VERIZON FIOS, WHN I DIRECTLY PUT IN THE COAX CABLE TO IT, IT CAN'T SEARCH THE DIGITAL CHANNEL..WHAT CAN U SUGGEST TO ME?
That means your tv cant support the cable that way do it the way it suppose to be as you do it before. or check the company they will be able to help you by sending personels from the company to assist you.but with a fee i believe.
Sep 24, 2011 | Sanyo DP19647 19 in. LCD TV
SOUND, TUNING, REMOTE ALL WORK. SANYO DP19647 NO PICTURE OF ANY KIND
Ur LCD inverter board is dead.Replaced this board will get ur pictture back.It usally a long board.Tries Shopjimmy.com,Ebay.com for a refurbish part board.
Feb 15, 2010 | Sanyo DP19647 19 in. LCD TV
Green light blinks but no sound no picture
Power surge will knock out picture and sound if you don't have a power strip. Found out from Best Buys when purchasing another LCD TV. They have a warrenty against such problems.
Jan 18, 2010 | Sanyo DP19648 19 in. LCD TV
Sanyo DP19647 19 in. LCD TV Logo
1,066 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
