Question about Canon PIXMA iP1600 Printer
Paper jam without paper canon pixma ip 1600
Orange blinking light that doesnot stop I don't see any paper in
Service error 6000 for canon pixma iP 1600
Error 6000
An error occurred in the LF encoder signal.
Can be the result of a deep paper jam with pins, paper or other miscellaneous objects stuck in there.
Check the unit and clean thoroughly.
Jan 15, 2013 | Canon PIXMA iP1600 Printer
Hi My Canon Pixma iP5300 injet printer will not...
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
May 21, 2010 | Canon PIXMA iP5300 InkJet Photo Printer
Canon iP 1600 printer won't print. Says that
Hi
If it keep saying paper jam Then it maybe just that you may not see any paper in it but it only takes a very small bit of paper that stopping it or I would take a closer look inside, you may have had a paper jam before and it has left a small nit inside. All Best: Pineworks
Feb 01, 2010 | Canon PIXMA iP1600 Printer
Canon pixma ip 1600...can't clear paper jam there is no paper jam but it keeps telling me there is
possible that there is a very small piece of paper near the edge or back that the sensor is picking up ... check again and see if there is something there
Jan 10, 2010 | Canon PIXMA iP1600 Printer
Hello there wondering if you can help me My power light on my Canon ip2000 keeps flashing green/orange and the print queue stops and nothing is happening. I've powered the printer on/off Also have...
Usually means theres a paper jam or your out of paper or some problem is occurring. While that blinking orange is blinking press and hold it for about 5 seconds the printer should stop blinking orange and continue with the print. Also open up your printer to see if there are any documents that are in the print queue. Probably can delete those. Thats my guess as to whats wrong with the printer. Used to have one of those. Nice little printer remember 12 blacks for 12 bucks.
Dec 16, 2009 | Canon PIXMA iP2000 InkJet Printer
Paper jams but doesn't go anywhere!
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 03, 2009 | Canon PIXMA iP1600 Printer
How I can do about Printer Canon Pixma ip 1600 Blinking Lamp...??
I DEPENDS ON THE MESSAGE MOST THE TIME RESETTING THE PRINTER IS THE ANSWER TURN OFF UNPLUG AND WAIT AT LEAST 15 MIN PLUG BACK IN.
Mar 16, 2009 | Canon PIXMA iP1600 Printer
"Paper Output Slot Jammed" Canon Pixma iP4300
These printers are FULL of very sensitive sensors, and chances are that one of them may have a small piece of paper blocking them. If you can get the covers off by finding the "Triangle" arrow markers, you can inspect all these sensors.
Good luck!!!
Mar 12, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
Canon ip 3000 photoprinter not working
things to check.
1. check for any paper that may have jam inside the printer.
2. check for open covers, back, top covers and close them properly.
4. check your power adapter if its giving correct voltage to the printer.
3. Try to move the ink cartridge to the left gently and return back to the right most part.
please let us know if this works.
Feb 07, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP1600 Printer Logo
391 people viewed this question
old marine
old marine
