Question about Dell 926 All-In-One InkJet Printer
I have a del-all-in-one-printer 926, I believe. The printer says a paper jam. But I have removed all paper and still says paper jam. I cannot print from the computer. Please help.
Every time i try to print paper get stuck. help,,,,,,,
The previous print job was jammed and when the paper was removed, a small scrap was left in the paper path. use a flashlight and look in where the paper is picked up, look carefully for that scrap and remove it. then with a damp cloth rub the pick up roller and you should be able to feed paper again.
Dec 12, 2010 | Dell 926 All-In-One InkJet Printer
I keep getting paper jams. Even if I put one sheet of paper in at a time, the paper keeps jamming and won't print.
Hi
I live in the mid west - during our significantly humid days my 926 wouldn't pull in any paper. I tried a lot of home grown techniques but none worked. I finally raised the air temp in my office which tended to dry out the paper and that worked. Of course your problem could be a broken gear or a worn out feed tire - also something stuck in the printer.
Aug 12, 2010 | Dell 926 All-In-One InkJet Printer
Paper jam on Dell Photo 926
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 18, 2010 | Dell 926 All-In-One InkJet Printer
Paper loading problem
try buying a new **** of paper 20 lb weight. if the paper has been sitting around a while believe it or not humidity levels can affect it. If this does not work I would start looking inside the printer to see if anything is stopping the paper flow.
Oct 17, 2009 | Dell 926 All-In-One InkJet Printer
My dell photo 926 printer keeps jamming up
When you refer to jamming up, what has happened is that the rollers are actually collecting fibers from paper every time you print.
First try and use iospropyl alcohol on the rollers and fan out your paper before printing.
If this doesn't work, check to see if the paper is grabbing evenly.
Jul 24, 2009 | Dell Office Equipment & Supplies
I have a Dell 926 all in one printer and it will not take the paper at all and if it does it jams up inside please help!!
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Hope that helps!
PREM
May 27, 2009 | Dell 926 All-In-One InkJet Printer
Dell printing problems
Try fanning the paper and see if that works.
Jun 30, 2008 | Dell 926 All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
82 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
