Question about MTX Thunder7500 T7512-04 Car Subwoofer
MTX Thunder7500 T7512-04 needs repair
The cone became seperated from the ribbed base. is this repairable? please help!
  • 47 Answers
Can try to repair it is it around the outside rim ?? use SILOCONE to repair it as it will flex when used DO NOT USE SUPERGLUE
Posted on Sep 05, 2009
Need reconing kit for a mtx 7500
I have a Rockford fosgate punch 1000.1bd in a sealed enclosure about 1.5 cubic feet each. I have 0 gauge wire for the amp and running it at 1 ohms. My surroundings are dry rotten on both subs. Need new surrounds
Sep 11, 2011 | MTX Thunder7500 T7512-04 Car Subwoofer
Where can i find a foam surround to replace my 10'' mtx 6000?
You would have to look for a re coning kit from either MTX site or amazon or ebay
Aug 22, 2011 | MTX Thunder 6000 T61544A Car Subwoofer
Hello, i have a kicker l7 15 and the voice coil has seperated from the cone. any advice?
Well, you have 3 options really,
  1. Send it in to your local sound shop for repairs.
  2. Replace the subwoofer.
  3. Attempt repairs with super strong glue.
Jan 19, 2011 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Wher do i biy the cone reper kits for my sub and how much
If you are looking for speaker cone repair kit, you can buy them for around $25 and here is a link if you wanna buy it online: http://www.google.com/products?source=ig&hl=en&rlz=1G1GGLQ_ENUS369&q=speaker+cone+repair+kit&um=1&ie=UTF-8&ei=dDmXS7SbCYfiswO43KjCAQ&sa=X&oi=product_result_group&ct=title&resnum=3&ved=0CC8QrQQwAg Hopt it helps and let me know if you need more advice. Please don't forget to rate the answer it was helpful, thanks!
Mar 10, 2010 | Car Audio & Video
Sub stopped working, unless i push on it?
sounds like maybe the wiring from the cone to the magnet is ripped or broken.... which is why when you push the cone in it works because it pushes it far enough to make the wires touch just barely, but when you let it go the wires seperate and you get no sound.
Your wire is built with slack, so when the cone goes in and out during a song, the wire can move with it and not get broken. but when you cone moves too in or too far out, then that wire can snap or become disconnected.
I have fixed this by soldering the copper wire, but you may lose some power because your copper wire might be a bit shorter(it will probly break again)... or you can lengthen it, but it is not easy to solder... some places will fix it for you but the cost may be more than what it is worth.
This is just a guess, take your speaker outta the box, and look to see if these wires are broken, lose, or frayed.
good luck.
Sep 11, 2009 | Insignia 600W Bridgeable Amplifier with...
Hole in subwoofer
Hello colinomalley,
You can repair the hole using a flexible permanent adhesive. If all of the cone is still there, I wouldn't use a patch. I'd just put the jagged edges back together. If part of the cone is actually missing, you will need to patch it. Thin fiberglass cloth works pretty well. Use painters tape that will remove easily and cover the hole from the rear of the speaker. Cut the fiberglass cloth about 1/4" larger than the hole and attach it using a silicone based flexible adhesive. Allow it 24 hours to set up completely and then remove the tape from the rear.
A product called "shoe goo" works very well for speaker repairs. It's strong, flexible, and permanent.
Hope this helps.
May 26, 2009 | MTX Road Thunder RT-1240 Car Subwoofer
Need help MTX 1501d amp diagram
Remove cover and set in direct sunny window for long time, may be no problem with it, Took a month to dry one of my amps out enough that it decided it would come back to life, cell phone dropped in sink took 2 weeks, If you try power to it too soon --fried--, good luck finding diagram and repairing it sincerely-hope its okay, good amp, bad luck,
Mar 13, 2009 | MTX Thunder 1501D Car Audio Amplifier
I LIKE TO HAVE SOME ONE TO FIX MY AMP.
you have to send it to mtx. Most repair shops wont touch it. You can call mtx i had the same amp. It cost about 85 bucks plus shipping. the 85 bucks covered return shipping also.go to there web site it has the info for tech support and repair issue there. hope this helps
Sep 09, 2008 | MTX Thunder 81000D Car Audio Amplifier
Wire to cone connection
try using quick setting epoxy glue. just put pressure on the same spot while holding the epoxy with an old spoon lined with clear plastic wrap. after epoxy sets, remove the spoon and trim away the plastic film with a new razor blade. to be sure the connection is being made, turn sound on just so you can barely hear it before performing this so that the cone vibrations do not interfere with the setting epoxy.
Mar 02, 2008 | MTX Thunder 8000 T8154A Car Subwoofer
MTX Thunder7500 T7512-04 Car Subwoofer Logo
278 people viewed this question
Top MTX Car Audio & Video Experts
Professor_V
Professor_V
Matthew Spark
Matthew Spark
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
