Question about LG Xenon GR500 Cell Phone
Is there anyway to stop or lock the access to media net and other data charges that may apply on some applications
HOW CAN I OPEN MY SIM CARD?
You can't. The SIM card provides system-level data, some limited applications and identity data to the phone. It is not a type storage media you can access.
Dec 31, 2014 | Cell Phones
Nokia s40 nokia 2700
firstly install these applications from Nokia store....third party s/w might not work properly. install application with mmc inserted and use them with mmc inserted............Permissions like always allowed/ask first time are only for network (GPRS) access....Mobyexplorer requires net.........many free applications also require net access as they carry some ads....if these permissions are denied then application closes......but be sure....if u select always allow/ allow first time, data usage charges will be applicable
Mar 13, 2014 | Nokia 2700 Classic
Wd my passport retrieve data
Step 1:
You might not have the appropriate software installed on your computer to show / read the files
IE: adobe flash , directx , win zip , codec , word ...... Determine if access is denied by a sharing violation because the folder and its files are in use by someone else or the computer itself. Wait several minutes, and then attempt to access the folder again. Go to the location where the file or its folder are stored on your computer. Lock files are hidden files in Microsoft Windows. Select "Show hidden files." The lock files for Windows applications have a ~ symbol in front of the file name. For example, for test.txt, the lock file is named ~test.txt. In UNIX, the lock file may be identified by an extension of .lock or .swp within in the file name. Delete the lock file. The locked file or folder unlocks. Reboot your computer, and bring it up in Safe Mode. This prevents the startup of many of the system services and programs that could be locking the files or folders. Attempt to access the folder location and its contents. If the folder is available, save the folder or its contents in a directory to which you have access. Record the active processes running on the computer and the programs available in Safe Mode. Then, log into the computer after a normal boot up. Review the applications running in the background in normal setup. One of these applications may be preventing access to the file folder and its contents. If there are applications that run in normal mode that do not run in Safe Mode, turn off those applications. Then, try to access the file folder again. b> Are the Security Permissions for the Folder or Its Contents Preventing Access? b> Check the file folder permissions by right-clicking on the folder and selecting "Properties." In the "Properties" dialog box, select the "Security" tab. The "Name" list box includes the user and group permissions. If there is no "read," "read and execute," or "write" permissions in your user profile, you do not have permission to view the file folder or its contents. These security permissions are typically set by system administrators. System administrators may be trying to prevent end users from altering system files that are critical to the computer running smoothly. Contact your system administrator, and request local administrative rights to the computer. This allows you to gain access to the files and folders that are restricted to administrators. Edit the system policies using administrative tools via the gpedit.msc program. Users can add, read and modify permissions for folders and other objects via this program. Full control is the best system policy, because it includes read, write, execute and modify rights. However, access to the gpedit.msc program may be restricted, as well. Go to the command line (press on the "Windows" and the "R" keys on your keyboard at the same time), and enter the CACLS command for the folder name. Use the command format: C:\> cacls <foldername> /E /G <username>:F CALCS stands for Change the Access Control ListS. This command allows you to add your user name to the security settings to permit access to the protected system folder when the gpedit.msc program is not available.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities. Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.cleverfiles.com/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
Feb 08, 2013 | Western Digital 1TB My Passport Essential...
I can get facebook on mobile inside my house but not able to get it anywhere else
If, whilst in your house, you are coonected to the internet through Wi-Fi, and loose connection whenever you are outodoors, then your mobile data setting must be disabled. You could try these tips I posted a long time ago. Their title might confuse you, because they address problems when downloading applications from the Android Market. However, they have a general nature, regarding access to the internet via mobile data plan.
Hope they might apply to your case, somehow.
Anyway, please, let me know if I can assist you any further.
Regards, Carlos
Oct 24, 2011 | HTC Wildfire S Smartphone
Every time i try to download something on schoolcomputer it says this policy is blocked by a group of people
What are you attemting to download? Normally a school puts in place controls to stop downloading of anything other than school related applications or assignments. etc.If you know that you should be able to download something, ask your instructor to help you.
Dec 27, 2010 | Computers & Internet
How to stop 'allow network access' pop up window in nokia 7610 supernova. Its very annoying that it always comes in between when i am surfing the net.
you download the java software first before you can run: on the phone to find your JAVA applications. Then select the section to stop the application software, press the left soft key operation, go to see the applications access the. Application access - communication - network access, if the software has a license certificate, then select Always allow, no election for the first time asked.
application software access - communication - data interchange, if the software has a license certificate, then select Always allow, no election for the first time asked.
application software access - data access - read user data, select Always allow the software without authorization certificate for each inquiry to the election.
application software access - data access - increased selection and editing of data is always permitted, the software did not authorize the certificate to select Always ask.
need to read the phone system, network or application software to download the JAD is authorized with the certificate.
this way can avoid the use of mobile phones, java software, always prompt " allow network access " this problem, this method is suitable for the Nokia S40 operating system models.
Aug 14, 2010 | Nokia 7610 Supernova Cell Phone
Error 102 (net::ERR_CONNECTION_REFUSED): Unknown error. means what and hw to cure?
Reference:
http://www.google.com/support/forum/p/Chrome/thread?tid=2307e04010c645c6&hl=en
Generally, in this case, you won't be able to access the internet at all, is this your symptom?
Go to start or windows logo,>settings in windows xp and/or control panel>internet options>connections>LAN settings> and uncheck use proxy server for your LAN.
Apply, and okay.
Close your internet browser and reopen it.
Jul 27, 2010 | Google Chrome
Cannot received mms picture
Menu - Settings - Configuration - Personal config. sett.:
MEdia Net
Account name: MEdia Net
Homepage: http://device.home
Use pref. access pt. : No
Access point settings
Proxy: Enabled
Proxy address: wireless.cingular.com
Proxy port: 80
Data bearer: Packet data
Bearer settings
Packet data acc. pt. : wap.cingular
Network type: IPv6
Authentication type: Normal
User name: wap@cingulargprs.com
My multimedia messages
Account name: My multimedia message
Server address: http://mmsc.cingular.com
Use pref. access pt.: No
Access point setttings
Proxy: Enabled
Proxy port: 8080
Bearer settings
Network type: IPv4
Menu - Messaging - Message settings - Multimedia messages - Configuration sett.
Configuration: Personal config.
Account: My multimedia message
Nov 12, 2009 | Nokia 6300 Cellular Phone
Memory Card Micro SD
hi,
           As per ur problem just do one thing try to unlock ur card by putting it in memory card reader..& if it doesnt wrk their than the only way is to format ur memory card.
Thanks
Oct 18, 2007 | Nokia 5300 Grey Cellular Phone
LG Xenon GR500 Cell Phone Logo
66 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
