Question about Yamaha RX-V490 Receiver
How do I connect to my Yamaha RX-V490 some bose speakers. The ones that are only 2
    Brigadier General:
  • 8,546 Answers
Perhaps if you named the Bose system or go to Bose.com and find its manual.
Posted on Jan 21, 2011
Yamaha receiver keeps turning itself off
Have you tried the unit without speakers connected , just left on it's own for a while?
Oct 31, 2016 | Yamaha RX-V490 Receiver
Yamaha receiver keeps turning itself off model .RX-V490
Have you tried the unit without any speakers connected at all?
I am trying to connect my Bose Wave Radio to my Yamaha RX S 70 receiver so that I can listen to the radio through my speakers. Right now the speakers are connected to the Yamaha...but radio isn't playing...
There's actually 2 ways of doing this.
Using the variable out connections on the Bose, connect your L&R channels to the desired input, I recommend the auxillary, on your Yamaha and select that input. Turn the volume all the way down on your Yamaha. Turn the volume on your Bose all the way up; then readjust the volume as desired on your Yamaha.
Optional connection; the headphone jack. Connect a 3.5mm mini to stereo plug cable from the Bose to Yamaha in the manner described as above and use the volume control approximately the same way.
Dec 12, 2014 | Yamaha Audio Players & Recorders
How to connect my bose 901 to rx-v2200
Bose Equalizer Out > to RX 2200 Tape/DAT In
Bose Equalizer In > to RX 2200 Tape/DAT Rec
more instructions on page 9 Bose 901
Sep 12, 2012 | Bose 901 VI Main / Stereo Speaker
Can I use an Ipod Dock with a Yamaha RX V490 receiver?
No, but you could still access the audio directly from the iPod...
Anything that has a headphone output can be adapted to feed an RCA cable pair for standard stereo to an amp or receiver. Get a cable like the one described here:
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10218&cs_id=1021804&p_id=665&seq=1&format=2
and connect it into any available analog input EXCEPT "Phono". Turn the MP3 player volume up.
http://www.retrevo.com/support/Yamaha-RX-V490-Receivers-manual/id/319ci975/t/2/
Dec 01, 2010 | Yamaha RX-V490 Receiver
My RX-V490 Amp. has no audio from Centre speaker.
Is your center mode set to "Phantom" instead of "Normal" or "Wide"? That would split the mono Center channel program and mix it equally with the programs for both front speakers so your brain would believe it's in the center.
May 17, 2009 | Yamaha RX-V490 Receiver
Can you run 200watt 6ohm speakers on the RX-V490
Hi I have just read the specs on about your Yamaha system and you cant run 6 ohm speakers to your amp. You have to impedance match the speakers and the amp otherwise the speakers will "blow". So you need some 8 ohm speakers, the wattage of the speakers doesn't particularly matter as long as they are not too weak or too powerful becasue the amp will drive the speakers no matter what but if the speakers are of a low wattage then the amp could blow the speakers if it is turned up too loud. The specs of your amp are given in the link below.
Yamaha
Regards
Rob
Nov 13, 2008 | Yamaha RX-V490 Receiver
Yamaha RX V490 Turning itself Off
The amp is in protect mode which means that the output section has a problem. With nothing connected, there are defective parts inside the unit. This type of problem is not likely to have been caused by any shipping damage. I would guess that the output transistors are shorted.
Dan
Jul 22, 2008 | Yamaha RX-V490 Receiver
Circuit Diagram of Yamaha RX-V490 requied.
I have the schematics in PDF file, but how can I send it to you?
Apr 16, 2007 | Yamaha RX-V490 Receiver
Yamaha RX-V490 Receiver Logo
216 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
