Question about Bose 901 VI Main / Stereo Speaker
Bose 901's Yes what equipment, i.e. preamp etc do I need to use the speakers with a Ming Da MC34A tube amp?
  • 3 more comments
  • mmille3222 Dec 08, 2007
    So how would I hook up the equalizer/ 901 to these recommendations?
    also where on the web site you listed are these preamps? and generally what are their costs?
    guys, I am getting more confused here. One expert tells me it can't be done. 2 others tell me to just get this or that. tell me WHAT it is that I am to use, preamp with... etc. and how it would be hooked up.
    OK let's find a solution LESS expensive then just buying new speakers please! A used Wadia 20 alone is 1,950 dollars! I have the bose speakers. I just bought the ming da. What is an inexpensive way to connect them!!!!
    I have the equalizer. It uses two sets of cables and requires a tape in and tape monitor connection. You need to be able to use both and have your source operate as well. The Ming Da has a simple selection knob that allows ONE source. So tell me how the equalizer solves this problem!!!!!!
  • 4,889 Answers
Source Wadia 20 Transport
DAC/Pre Wadia 25
Cable loom and mains by Omiga Audio
Just get these things thats all the instructions on conection will be provided in the wadia manuals.. Also the wadia stuff may cost you a free extra pounds but if you wanna feel the music then dont hesitate...
Regards,
Eagle.
Posted on Dec 08, 2007
  • eagle338
    eagle338 Dec 08, 2007
    Buy Bose 901 Direct Reflecting Active Equalizer.. this should solve all the problems and the best part is that its tailor-made for BOSE speakers so that u dont have to worry abt anything else
    Novelist:
  • 173 Answers
Yes u can use a KT88 tube amp , or BTW-2 amp for this da mc34a..this will work good, and you can buy this in e bay that would be cheaper.
You may also want to look at http://www.cattylink.com.
2 Suggested Answers
SOURCE: how to use my bose 901 speakers with my new ming da amp
just plug it
I'm trying to hook up a Carver HR-752 to Bose 901's series VI, I would like to use the preamp out and in on the back, do I need a seperate amp to use these? I have them going through the Tape
To setup the Bose 901's so that all of your connected equipment's sound (cable/dvd/games/stereo/etc) comes out of the 901's.
If you already have a receiver with front left and right pre-outs, I would add an amplifier. (other option is a pre-amp) Use the amplifier to create the loop the 901's need w/ their EQ and it will also add a cleaner sound and added power. That's how you can really make the Bose 901's sound amazing.
Feb 01, 2013 | Bose 901 VI Main / Stereo Speaker
Bose 901's
yaa you can use its best idea but i think you cannot integrate the equilizer into the amplifier settings! it will not give as much effect as you want!
Dec 08, 2007 | Bose 901 VI Main / Stereo Speaker
I have a Crest Audio V900, a set of Bose 901, a Gemini EQ-3000. Do I need a PREAMP? Or can I hook up the Crest AMP to the Equalizer?
You could use the EQ but it won;t sound as good as it will with a pre amp and also could make it a bit trickier when adjusting the volume and getting it to sound right.
Mar 10, 2012 | Crest Audio Audio Players & Recorders
Will bose 901 speakers work with a AVR-4308CI
Yes they will, I have a set on a denon receiver amp ( not sur of the model # its in another town). The main thing for bose 901's is that the equlizer has to be connected somewhere beteen the preamp and the main amp, most higher power amps have a switch that opens a set of patch cord jacks that the Eq. can be connected thru. So you should verify this feature with any amp you chose. With out the Eq connected the 901's have no bass or highend sound.
Apr 11, 2011 | Bose 901 VI Main / Stereo Speaker
`Which ampliphier is compatible for my Bose 901 series 6 with equilazer.
Ideally, an amplifier or receiver should have either a "Tape Monitor" selector switch and Tape Input & Tape Output jacks, OR have Preamp Output & Amp Input jacks to enable insertion of the Bose Active equalizer into the circuit before the amplifier stage. Power requirements - according to the 901 Series VI manual:
"Your 901 speakers are designed to work compatibly with receivers or amplifiers rated from
10 to 450 watts per channel."
If you have questions not answered by the manual, you can contact customer service at The Bose Corporation in Framingham, MASS toll free at:
1-800-999-2673
Hours of operation:
7 AM - 2 AM ET, 7 days a week
I hope this helped & good luck!
Nov 22, 2010 | Bose 901 VI Main / Stereo Speaker
I have an old integrated amplifier and an old BSR EQ-3000 stereo frequency equalizer. i just bought a used bose 901 speaker set. how do i hook-up the bose 901 equalizer in this system?
Hook the signal source to the equalizer input and the equalizer output signal to one of the signal inputs on your amp. This is one way, but this way only one signal source will go through the equalizer (unless it has several signal inputs and a source selector switch).
The other way (inserting the equalizer between the preamp and the main amp) is:
If your amp has RCA connectors on the back named "preamp out" (or similar) and "power amp in" (or similar) that have slugs connecting them, remove the slugs, hook the "preamp out" signals from the amplifier unit to the signal inputs on the equalizer and outputs from the equalizer to the "power amp in" inputs on the amplifier.
Basically, what you do is that you insert the equalizer between the preamplifier section and the power amp section of the integrated amplifier so that you can still select the signal source without having to switch any signal cables (however, i can't say if your amp has got this type of "slug" connection feature between the preamp and the power amp on the rear panel, so i'm not sure which way you'll have to hook it up).
Hope you can make it work the way you want.
regards
Triarcuate
Sep 30, 2009 | Bose 901 VI Main / Stereo Speaker
Latest model surround receiver for bose 901 speakers VI
I can think of no reason any amp pushing 120 watts would not work with 901-VI's. They're very efficent and will probably play louder and cleaner than you would ever need. As I recall, my old series IV's have no maximum amplifier rating specified, but I did blow up a bridged Carver M-400 Cube (pushing 400 watts to one speaker with a DVD-Audio of Yes - Fragile cranked dangerously high) with them. I'm convinced my speakers are indestructible in any home application.
Keep in mind that whatever you decide to use as your control/amplifier section, a pair of 901's need a dedicated stereo amplifier. I suspect you're thinking surround sound so a receiver with separable preamp/amp channels, due to the Activbe EQ, would be needed and as far as I know they don't exist. A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver and the 901's amp channels. My receiver controls everything and just drives the Center and Surrounds.
Modest amps would work but at very loud volumes may go into clipping, which is bad for any speaker. 120 clean watts is good. I'm using only 110W for mine.
A Carver M-200 is a fine, efficient amplifier that would have you cooking just fine (2x100W).
Mar 20, 2009 | Bose 901 VI Main / Stereo Speaker
Bose 901 and Tube amp
Yes! When the Bose ~Steve901 first came out that was the amplifier of choice -like the McIntosh classic amps. The 901s have their own equalizer as that speaker system is a phased-array,
Nov 05, 2008 | Bose 901 EQ1915 Home Equalizer
Connecting Bose 901 Series VI Direct Reflecting Speakers to JVC RX-8020VBK Receiver
in order to make those speakers sound good (if they can sound good at all) you need to use equalizer box witch came with them. If your receiver does not have tape monitor loop or preamp to amp jumpers you can not use those speakers. To be honest you do not loose much... none of this stuff is any good (sorry for bad news), but if you like those speakers (I know they have big fans, even if in HI-FI world, they not consider as good) you have to change you receiver. Dariusz
Feb 13, 2008 | Bose 901 VI Main / Stereo Speaker
Bose 901 VI Main / Stereo Speaker Logo
391 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
