Question about Bose Audio Players & Recorders
Bose ps321 checked everything have had for 6 yrs not getting power
    Novelist:
  • 142 Answers
It sounds like you most likely blew a fuse. Unplug it and open it, look around where the plug wire goes into the box. You should see a fuse, usually a glass cylinder with metal ends. If its blown, replace and you should be good. If fuse is good, let me know and we will go from there.
Posted on Sep 05, 2009
Bose 6 disc cd player reset button
Acura RSX-type S where is the reset botton on a Bose 6 disc in-dash cd player. I have a CD stuck in the CD player. Need help getting it. Everything I read is telling me to push the reset button.
Aug 17, 2012 | 2005 GMC Envoy
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Cheers
Andy
Apr 28, 2011 | Bose 3·2·1 II System
I was listening to my bose radio and all of a sudden it stopped
i would contact bose, they should repair it or replace it due to the fact of the price that they charge and i beleive they give you a lifetime garuntee, www.bose.com
Apr 17, 2010 | Bose Wave Radio
I own 2 Bose wave radios. One is 5 yrs old and
Around smoking and/or fireplace? Try cleaning lens
with a q-tip and alcohol. The toploader design can be prone to dust but can be easily cleaned1
Apr 14, 2010 | Bose Wave Radio
WAVE radio transformer bad ???
If you can check ohms,you can also read volts. Open the radio again and look for DC volts on the rectifiers capacitors.They look like :cans", normally the color is blue. Check for positive dc v. against chassis ground. If no + tension,your rectifier or your secondary are open.
Aug 24, 2009 | Bose Wave Radio
Bose 3-2-1
Get the free upgrade CD from BOSE and it will solve most of the problems when the program is loaded.
Its not a cable problem...tinkering with the cables will make the connections loose.
Feb 06, 2009 | Bose 3 2 1 GSX System
Ps321 subwoofer
Yes you can wire it to anything but your going to loose power if the amp cannot handle it
Jun 18, 2008 | Bose 3 2 1 GSX System
Bose wave radio wont turn on
I have one that is doing the same thing. Will your radio make a POP sound when you unplug it? I was told by Bose Tech it is 15 yrs old and they will not work on it. He told me that if it makes a POP sound that it is not the fuse or power supply???
May 04, 2008 | Bose Wave Radio
Bose PS321 No Sound
The power supply is 29 volts raw voltage,the IRFI44N fet on the power board is used is a switcher.
It reduces the voltage to 17 volts which is required for the AV3-2-1 meda center.The higher voltage biases the sound to cut off and can blow the drivers,try changing the fet and see if plays........
Jan 28, 2008 | Bose 3 2 1 GSX System
Bose Acoustimass 6 No Subwoofer sound
take it back for refund or exchange without delay. Too many times, there are cases of faulty factory assembly. Most likely a poorly connected wire inside sub, which fell off after a few booms.
Jun 17, 2007 | Bose Acoustimass 6 III System
214 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
