Question about Nintendo DS Console
My DS charger isnt charging at all, how can i fix this, please help me!
  • Dawn1476 Feb 21, 2008
    i have to take the battery out and charge it in another ds, mine will not charge i have replaced the charger works great if i charge the battery in another ds.. what can i do?
Can you borrow a friend's charger to see if that charges your DS instead? If so, you know you need to buy a new charger. If not, you know that your DS charging circuit is not working.
You might be able to buy an inexpensive USB-to-DS charging cable and charge it from your computer.
Posted on Dec 19, 2007
I just got my touchscreen replaced and now my ds wont charge, when I plug it in there is no light or anything and it used to charge before they fixed it
If that DS has been opened by any tech, they are supposed to give warranty.
Bring back that DS to the one that repaired it and tell them that it was charging before you brought it to them, otherwise you could complain that some part have been( hopefully not ) replace mistakenly from another DS.
Hope that helps!
Nov 25, 2011 | Nintendo DS Lite Console
I got my DS in 2009 april, then on september i lost my charger then on march 2010 i found my charger then i found out i could'nt find my DS anymore a few months later i found my DS i charged then it...
The red LED indicates low power. When the DS is charging an orange LED should be on and the DS can be switched on, giving a second green light. If you tried charging it but the orange LED did not come on or only came on for a few seconds then the battery has not charged. The charger may be faulty or the power connector on the DS may be faulty. You need to try another charger. If another charger does not work then the DS is faulty and needs repair. It could be the power connector or the battery or some other fault inside.
If the amber LED comes on to indicate that the battery is charging then the battery should be fully charged within 3 hours. If the DS does not switch on after charging then the battery may be faulty. It can be removed by opening the cover on the bottom of the DS.
You should try and find a friend with a DS who will let you try their charger and battery in your DS.
If the DS itself is faulty it will probably be uneconomical to repair. If this is the case then try selling it on ebay as a faulty DS.
Oct 30, 2010 | Nintendo DS Lite Console
My ds wont charge. How do I fix this?
on the ds, after you connect the charger, the charging light goes on? if not, the problem can be the charger, or charger cable or plug.
if possible, test the charger with another ds, if the charger works, then the problem is ds internal, maybe a fuse or another component.
May 29, 2010 | Nintendo DS Lite Console
My nintendo ds won't charge I tired everything is
If you DS isn't charging there are two possible things that could be causing this.
The first one is that the batter inside the DS is shot, in which case you'd have to replace it.
The other one also requires replacement, and that's assuming your charger itself isn't working. Either way, you're probably going to need to replace something.
One way you could tell which is messed up is to try and charge someone else's DS. If that doesn't work then it's most likely the charger.
Hope I was able to help.
Sep 16, 2009 | Nintendo DS Console
When i turn my ds on it just turns back off
is it doing this when the charger is plugged in too? it sounds like the battery isnt taking any charge so is constantly flat!
Jul 12, 2009 | Nintendo DS Lite Console
Nintendo DS Lite - does not charge
i would suggest trying to find what the issue is, if you know anyone who has a different charger, try it on your daughter's ds. if it still doesn't work, it's a DS problem...if it's under warranty, go to whatever store you bought it at and have them fix or replace it. If you try the different charger and it DOES work, then the only problem is the then all you have to do is go buy a new charger...hope this helps.
Feb 05, 2009 | Nintendo DS Lite Console
Wont charge
if yuo dont let the battery completely drain and charge before ds wil never again comletely charge up.
Jan 05, 2008 | Nintendo DS Console
Ds light not coming on and charger not working
When I hooked up my DS with the charger the orange light would flicker for only a few seconds then turn off.
I found out that if you KEEP THE DS ON WHILE HOOKED UP the DS will charge. Although, because you are playing/DS is on the charging will go extremely slowly.
Best option, and what I did, was was just return/exchange it. I just did that today.
Nov 28, 2007 | Nintendo DS Console
Nintendo DS Console Logo
60 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
