Question about Kenmore Dryers
Kenmore 400 series dryer won't start
Hello, my name is Sandra. I have a 3yr old kenmore 400 series dryer and it will not start. I have checked the breaker box, and checked the 220 outlet to make sure it is getting power and it is. I have taken off the back panel and have checked it out and everything looks like it is in place. I did check the voltage where the cord hooks to the back of the dryer and found one side gave a full charge and the other gave hardly any( don't know if that might be whats wrong). Just hoping someone might know what the problem is. Did read someone's suggestion about a white thermal fuse on someone else's blog of having trouble with their dryer starting. But not sure where that is to check it! Thank you for your time!
  • 5,911 Answers
If you checked the voltage at the terminal block on the back of the dryer while it was plugged in, you should have gotten the following readings:
RED to BLACK = 220-240VAC
RED to NEUTRAL (White) = 110-120VAC
BLACK to NEUTRAL (White) = 110-120VAC
NOTE: If the wires are not color coded at the terminal block, the OUTER two wires (LEFT and RIGHT) are the HOT leads and the center conductor is the NEUTRAL.
If you got anything other than these readings, you may have a bad power cord or a service breaker tripped. Some homes use two separate breakers to make up the 220 service instead of one single 220 breaker. If one breaker is tripped, the dryer may or may not start, depending on which leg it is. Can you please confirm your readings?
You need to confirm you have the proper input voltage before assuming you have any bad components.
Posted on Sep 19, 2009
Kenmore 400 series gas dryer doesnt dry clothes
Replace timer, if you are sure that it is not working.
Do an internet search for kenmore driver parts and get dozens of hits.
Aug 03, 2014 | Kenmore Dryers
Its a 400 series washer actually, and it will only spin very small amounts of clothes. It won't even spin a single sheet by itself??
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 10, 2011 | Kenmore 400 6942 Dryer
My kenmore 400 series gas dryer will not start it just makes a click sound its a couple of years old
Hello & Welcome to FixYa
If you have already cleaned the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing.Please get back to me if you have any other questions.
Kevin
Aug 25, 2011 | Dryers
My kenmore 400 series dryer will not start. It has electricity the inside light comes on when I open the door. I push the start button and nothing happens.
There is a thermocouple on the inside that prevents the dryer from getting too hot. If this burns out this opens the circuit so the dryer will not work but all other functions will work.
Sep 23, 2010 | Kenmore 400 6943 Dryer
Kenmore series 400 electric dryer when I press the start button won't start bar
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Aug 31, 2010 | Kenmore 400 6942 Dryer
Kenmore 70 series gas dryer - does not start when pushing the start button
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 19, 2010 | Kenmore 77632 Gas Dryer
I HAVE A KENMORE 400 SERIES DRYER. THE LENT NO LONGER STICKS TO THE FILTER. WHEN I PULL THE FILTER OUT TO CLEAN IT, THE LENT SLIDES OFF THE FILTER CONTINUALLY CLOGGING THE VENT IN THE BACK OF THE DRYER....
Try cleaning the filter to remove any residue from dryer sheets (a dish detergent solution should cut the softener build-up). Be as gentle as possible. An old toothbrush is useful for this.
Also, a weak exhaust flow may be the culprit. Check the dryer vent line all the way outside for excess lint.
Your fan impeller (inside the dryer) may be loaded with lint, too.
Apr 29, 2010 | Kenmore 400 6943 Dryer
I have a kenmore 400 dryer that will not start The dryer is only 10 mos. old I checked the breaker
i have the same problem.....ours is just 7 months old............it really ****..............they say it will be three weeks before they can work on it
Jun 05, 2009 | Kenmore 400 6943 Dryer
Dryer Gets Too Hot!
Could be the heat switch on the motor or a grounded heat element
May 20, 2009 | Kenmore 400 6942 Dryer
Kenmore 400 series electrical dryer
I have a 400 series kenmore dryer that just quit running after 10 min. into cycle. breaker in house checked and is ok but no power to dryer. what could the problem be
Oct 18, 2008 | Kenmore 73952 Gas Dryer
Dryers Logo
425 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
