Question about Dell 926 All-In-One InkJet Printer
How do I get the fax working on the Dell 926 AOI Printer?
You solved my first problem, but now I have a second problem. I can get the printer to print and scan, but when I click on the setup fax tab I get this message
Copy Error. Setup cannot copy the file fxstiff.dll. Ensure that the location specified below is correct, or change it and insert Windows XP Professional Service Pack 3 CD in the drive you specify.
As I explained, the printer did not come with a disc so I downloaded the Windows XP Professional Service Pack 3 driver and got it to print and scan with your help.
What mode does 926 Printer must be in to print?
For printing from the computer, I beleive it is 'copy' mode.
Mar 30, 2014 | Dell 926 All-In-One InkJet Printer
I can print from my Dell 926 all in one, but it wont scan
Try removing your 926 icon in Printers and Faxes, disconnect the USB cable, restart your computer, reconnect the USB cable, see the 926 and install the driver again. If scan has never worked, you probably need a different driver.
Hope this helps.
Aug 06, 2009 | Dell 926 All-In-One InkJet Printer
Dell All in One 926 won't print from Vista
Go to the control panel and select printers.See if it there and set as the default printer.
Jun 18, 2009 | Dell 926 All-In-One InkJet Printer
Dell 926 won't recognize new color cartridge
Try this...shut down the printer. Insert new cartridge, let the printer cycle out with new cartridge. then reboot the computer. This should solve the problem. The cache in the printer will not cycle out. It wants to see the printer as a new entity
Jun 17, 2009 | Dell 926 All-In-One InkJet Printer
Printing too small on my Dell 926
Please check the paper settings of the printer. for example If the paper selected is A3 and the printing matter is on A4 then this problem may occur.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Mar 30, 2009 | Dell 926 All-In-One InkJet Printer
Printer busy
Your printer has a pending jobs to print. Go to printers and faxes. Double click your printer delete all pending jobs.
Mar 03, 2009 | Dell 926 All-In-One InkJet Printer
Dell Photo 926 - unable to scan
1. try to make a copy.
if it copy fine, then its an issue with software.
2. Try to scan with MS Paint,
Click on Start > All Programs > Accessories > Paint
Click on file > from scanners and camera > scan
It should scan if its not the windows issue...
3. Try different computer if it does not scan with Paint\
4. If it works with Paint, try to open Dell AIO center and try to fax from that too...
5. Turn the printer off, take the power brick out from back of the printer where power cable goes in , wait for 15 seconds to connect it back and turn on and try again to print, it should work fine
Oct 28, 2008 | Dell 924 All-in-One InkJet Printer
926 printer
my 964 printer have the display totaly black no copier and print ok
Oct 20, 2008 | Dell Photo 964 All-In-One InkJet Printer
Dell 926 All-In-One InkJet Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
