I pull up on the knob to start a wash and nothing...no water filling the tub, no sound...nothing. Ive checked all the hoses, my fuse box and etc. Anyone had this problem? Maybe the knob needs replaced? help.
  • tanya_pahl Sep 06, 2009
    You are AWESOME!!! You were correct....the breaker wasnt affected...the outlet isnt working. I plugged it into another outlet via extension cord. yay!! I can do laundry now. Thank you thank you!!!
  • Samuel Charles Spriggs May 11, 2010
    Are you sure you have power at the electrical outlet? If this is a GFCI outlet it could be tripped without affecting the breaker in the main service panel? Charlie
    President:
  • 1,489 Answers
Fantastic!! Could you please rate my response.
thanks...
Charlie
Posted on Sep 06, 2009
Testimonial: "Charlie responded to my post with in minutes...which suprised me greatly...i didnt expect a response so soon. He is fabulous!! :D"
Washer will just fill to the lower level for a small load when i put on large load it still fills to lower level and starts to wash as usual. Only probolem is the water level every thing else works fine
water level is controlled by a pressure switch that is connected to the lower part of the tub-it may be clogged-pull off the small rubber hose that is connected to the water level control knob-make sure the fitting on the tub is clear and the hose is clear-take the hose off both ends and blow through the end that connects to the control-cheers Denny
Oct 26, 2013 | Washing Machines
My washing machine wont stop filling up with
well the part that tells the water to stop running in is the pressure switch if the water valve is working properly so disconnect the power and if the water continues to run in it is the water valve just replace it
Apr 26, 2010 | Washing Machines
The water will not stop filling up.It never start to wash.
Hi, This will be one of two problems. Either the pressure switch is bad or the valve is stuck open. The way to figure which is: when the tub is filling pull the power cord out. If when pulling the power cord out the water stops it means the pressure switch is bad. The pressure switch can be located inside the control panel. It has 2 wires and a plastic tube sticking into it and is attached to the water level knob. If the water fails to switch off when you pull the power cord this means the valve is stuck open so you should replace the valve. This is located behind the machine and are what the hoses attach to. If you have any other questions please feel free to comment. Mike
Dec 10, 2009 | GE WBSR3140DW Top Load Washer
Kenmore Top Load Model 110.82870100. Does not fill tub with full flow. Can make full flow by depressing and pulling out control knob several times.
It sounds like you need a new water level sensing transducer.
Unplug the power cord and turn off the water at the angle stops (you don't need to disconnect the supply hoses yet).
Release the front clips for the top piece and look for the transducer fairly high near the rear corner ( the parts people at sears will show you a diagram).
Sep 13, 2009 | Washing Machines
Keeps on filling and wont drain
please follow the steps which i give to find and rectify the mistake (1) First check the wash load/laundry. If it is unevenly distributed in the tub making it unequal, rearrange it, close the lid again.
(2) Make sure your washer is leveled and you have filled sufficient water in the tub for that size of wash load/laundry. Insufficient water can make imbalance.
(3) Make sure the power cord/cable is plugged into the working electrical wall socket.
(4) It is better to check the appropriate circuit breakers or fuse of the fuse box and reset if necessary.
(5) Inspect the drain hoses and remove any bends. Inspect the drain system, too - if it's clogged.
(6) Then close the washer lid and pull out the knob to start it. For your safety, the washer will not spin unless the door is closed.
(7) Excessive foam can also cause this problem. If you find it to be the solution, rewash the clothes with plain water. For future, ensure use of correct amount of detergent with low-foam.
(8) It is possible that the lid switch, that prevents the washer from spinning when the lid is open, could be malfunctioning. If that happens, a built-in mechanism – brakes will be applied and washer will stop washer operations until the lid switch is repaired/replaced.
Jun 13, 2009 | Washing Machines
Keeps filling with water
The water level in a washing machine is determined by the pressure switch. The switch is located behind the load selector, water level, load size (has various names depending on model and manufacturer) knob on the operator console. If the switch malfunctions, the water will not shut off and the washer will overflow.
Now...before assuming the switch is defective, a common problem that occurs is the small air hose on the pressure switch coming loose or leaking. This air hose attaches from the wash tub to the pressure switch. The pressure swtich senses the change in air pressure as the tub fills and shuts the water off at the selected level. The following link explains:
http://www.fixya.com/support/r762094-washer_overflows
To access your pressure switch, unplug the washer and open the operator console. Look for a clear plastic hose. If it is NOT attached, you may have found your problem. Reconnect and test operate.
If it IS attached, check the entire length of the hose all the way to the wash tub for any cracks of leaks. In addition, remove the electrical connection(s) and check for corrosion. Clean if necessary.
If all these preliminary steps don't solve your problem, replace your pressure switch. Read through the link I provided and let me know if you have any questions. I hope you find this information helpful.
Jun 12, 2009 | GE WJSE4150B Top Load Washer
Doesn't fill with water - goes straight to agitation.
open the console and find the pressure switch. it has a clear hose attached to it. pull the hose off the switch and turn on the washer. if water starts to enter shut it off and blow through it back to the tub. some piece of junk may have plugged it causing the switch to "think" the tub is full of water. put the hos back on and run a short spin cycle to reset it and try again making sure to run a small load to see if it shuts off properly. if no water enters when hose is pulled off most likely bad pressure switch. keep the lid closed while doing these tests. some units wont work w/lid open.
May 25, 2009 | Whirlpool Washing Machines
The washer overflows with water. help
make sure the water level hose is connected to the tub and the switch,you can remove the front panel to and flip up the top check,let me know now you do-mike
Dec 02, 2008 | Washing Machines
Washing machine
it is possible the heater is at fault try this first / then check motor / after these there could be an exposed wire shorting on the chassis . always remove plug from mains when carring out checks . good luck
Apr 20, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Washing machine overflows
sorry in advance for the lack of appropriate terminology. my "solution" comes from a mother with no mechanical experience point of view.
i had the same problem with my washing machine overflowing. I opened up my machine, found the clear hose that went from this little square box on the side of the tub up to the switch for the "load size" knob. i pulled the hose off the square box and saw that there was a piece of paper in it. i pulled it out, scraped the scum out and reconnected it. started the machine. - that didn't work.
so, I got the thinnest pipe cleaner i could find pulled the tube from the little box, and stuck the pipe clearner down the pipe of the little square box. pulled out a bit of scummy lint, then I blew in the tubing. I heard a "click", I thought.. okay maybe that's it. reconnected everything, started my machine.. and now it works :)
This probably wasn't the proper thing to do, but it worked and saved me from the cut throat washing machine mechanics in this area.
Nov 10, 2007 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
