After washing pillows in a GE washer it will not spin and water will not drain out Serial number WIRR417061WW
  • Samuel Charles Spriggs May 11, 2010
    Is this a belt-driven top-load washer? Can you hear the motor running when the unit is supposed to be spinning/draining? Does it agitate? Charlie
  • 1,543 Answers
Unplug machine. Scoop out water. Remove front panel by pressing in on clips at the seam with the top, using a putty knife. Remove pump mounting screws and hoses from pump (you will spill some water) and clean out obsturctions. Reassemble and test. May need to be repeated.
Posted on Sep 06, 2009
Model WPRE6100GOWT; Serial #AM931842G does not spin the water out.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Apr 25, 2011 | GE Washing Machines
WATER WON'T DRAIN PILLOW "EXPLODED"
Hi
I would need a little more info like what type of machine and model number
Feb 23, 2011 | Washing Machines
Problem washing pillows. They get full of water and washer won't spin the water out.
You can remove the pillows and squeeze most of the water out and then put them back in to spin the rest. Washers weren't really made to wash pillows and pillows werent really made to be washed in a washer. Get new pillows and put hypoallergenic covers to keep the funk out. Wash the covers as necessary.
Alternatively heating and tumbling them in the dryer might get rid of whatever aspect you were trying to neutralize or wash out of the pillows.
May 14, 2009 | Frigidaire Washing Machines
Stopped mid wash cycle,no drain,no spin, will not go to next cycl
water pump blocked with nylon stuffing from old pillow.removed front panel from hinges under the lid. water pump at the right hand corner removed hose then removed 2 cups of nylon threads and stuffing forced into pumps small openings where it was compacted to a solid mass.
Jan 05, 2009 | GE Profile WPRE6100G Top Load Washer
GE WCSR2080B4WW - After wash cycle the washer does not spin and..
your washer must drain to spin.you may have a blocked or failed pump.you get to it thru the frount.use a putty knife between the lid and the frount ,push the springs.top comes up take frount off.pump has two hose .pumps white or tan smaller.God bless,tom
Jan 01, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
Waont drain
I would check the pump.
Follow the drain hose back to the pump, disconnect the outlet hose from the pump and disconnect the inlet hose from the pump. Look inside both hoses and the pump for pillow pieces.
The pump may have to be removed for cleaning, you should be able to turn the pump by hand, if not, replace the pump.
Inner tub.
Run some water in the washer with the inlet hose disconnected from the pump. You'll need a pan or bucket for the water to run into and look for pillow pieces.
Dec 21, 2008 | GE Washing Machines
Water Won't Drain from Washing Machine
Hello phylislw61,
If you had an incident where a pillow broke and feathers where dispersed throughout the washer..then there is a good chance that teh drain fiilter screen, pump or hose feeding the pump is clogged. I would verify that the filter is free from anything that would limit water flow from getting to the pump.. then if the problem is still there.. examine the pump itself to make sure it isn't clogged...
If you or someone in your family is reasonably handy, here is a link to your washing machines exploded view and parts and this should provide sufficient information for how to access the pump and associated hoses etc that feed into and out of it for cleaning..
If you are having problems after you verify the lines are free of restriction, feel free to contact me and I will try to assist you in solving your problem.. Here is the link..
http://www.pcappliancerepair.com/model-display.php
Regards,
Rick
Dec 06, 2008 | Roper RAS8445KQ Top Load Washer
I washed a feather pillow and it busted, now it wont pump water out.
There is a filter down in the bottom front of the washer (below the drum) that is probably clogged with feathers. It is a pain to get to, but once you get it cleaned out, the washer should spin and drain without problems.
Oct 25, 2008 | GE WSXH208A Front Load Washer
GE Top Loader - Spin Cycle Problem
bad door switch, probably ripped out by a comforter or pillow
May 29, 2008 | GE WBSR3140DW Top Load Washer
GE washer, does not spin
You probably broke the 4 black snubber straps on the top of the tub lid and it is cousing your washer to always be off balance and not reach a full speed spin
Oct 30, 2007 | GE WBSR3140DW Top Load Washer
Washing Machines Logo
57 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
