Question about Bruder Toys McCormick XTX 165 Tractor
IH Model F8 Carburetor Breakdown WD9 - Bruder Toys McCormick XTX 165 Tractor
  • 906 Answers
Good day,
hope this link below will solve your problem.
toys
Posted on Jul 30, 2010
358356070 it has 3 carburetor lines I don't know where the one in the block goes to?
If you are referring to the impulse line that comes from the Cylinder it goes to the inlet on top of the carburetor which can be seen right after screw (part 147) in this breakdown http www searspartsdirect com model part 358356070 0247 1503220 00041614...
Hope this helps.
Feb 19, 2016 | Craftsman Garden
How do I fix a carburetor
First the question; although, being a good one is going too generalized. So here is generalized answer.
Most carburetor require a complete breakdown and very good cleaning be it either ultrasonic or chemical. Then as the carburetor is re-assemble worn parts are replaced.
In order to obtain a carburetor repair kit you must use the make and model number along any other required number depending on the manufacture to look-up the correct parts. Example: Briggs engine require model - type along with the date code as sometimes at different times during the manufacturing of the engine they may changed parts used.
Some whole equipment manufactures are now referring engines and transmission part look-ups their specific manufacture.
Nov 25, 2014 | Craftsman Garden
Need a picture of a carburetor side mound for a briggs and stratton engine.
i can probably help you if you can tell me the model type ,and code of engine.i am not really sure if you meant carburetor photo or part breakdown
Aug 05, 2013 | Televison & Video
I need a diagram for a nikki 498888n carburetor. It goes on a B & S 14.5 h.p. It checks 50 psi pressure
You can get a breakdown of the carburetor on a parts website like partstree.com by entering the model number off the engine, and picking the appropriate type number, and selecting the carburetor and you will get an illustrated parts diagram which includes and exploded view of the carburetor.
I hope this helps you out.
Aug 23, 2011 | Garden
What is the carb model # for zr05870, Its a Walbro carb?
From the pictures in the parts breakdown, this appears to be one of the newer model rotary-type carburetors. It is listed as part number 308028001. There is no mention of this machine in the Walbro carburetor application guide however. After viewing the picture and with the prefix of the carburetor known, you should be able to locate it on the Walbro website. I have the link to your machine's parts breakdown and to the Different Walbro models. Please view:
http://www.ereplacementparts.com/ryobi-ry08570-backpack-blower-parts-c-7931_15636_15640.html
http://wem.walbro.com/distributors/servicemanuals/
Jun 28, 2011 | Ryobi Backpack Blower 25.4cc
I'm trying to reinstall briggs & stratton 393397. Need a picture to show how to put the carburetor back together. any help please?
You might go to www.partstree.com and see if they have a parts breakdown to help you out. It will also list part numbers in case you have to replace anything. You'll need your model type and code off of the engine to get to a parts breakdown.
Mar 28, 2011 | Garden
Weed eater featherlite primer bulb won't fill with gas. it does not appear to be broken and fuel line is clear and filter is new. any ideas?
Hello
From your Description and Depending on the OEM (Zama or Walbro) of the Carburetor it Sounds like a Bad Fuel Filter or the Primer Check Valve has Stuck and the Carburetor Requires Soaking and Cleaning.
>>You can View a Breakdown/IPL of the Mower at this Site Addy, http://www.poulanpro.com/poulanpro/indexAction.do?id=default and Select Order Parts and Accessories. On this Page Select Illustrated Parts List from the Menu on the Left. Now Select the Manufacturer (Poulan/Weed Eater) and Enter the Model Numbers in the Boxes at the Lower Left of the Page.
I Require the OEM (Walbro, Zama, ect) and the Model Numbers Off the Carburetor. With these I can Locate a Breakdown of the Carburetor and Better Assist you.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 10, 2009 | Poulan/Weed Eater No. Te475 952711797 17"...
Blower
You need to rebuild the carburetor. Go to m-and-d.com then parts diagram then illustrated parts online then parts look up then under select OEM select Homelite then do as instructed. You should find the parts you need and hopefully the parts breakdown for the carb. this will help you in the rebuild. If it does not have the parts breakdown for the carb. find what mfg and model carb. it is then go to that site for breakdown.
Apr 04, 2009 | Homelite 'Yard Broom' Leaf Blower
Bruder Toys McCormick XTX 165 Tractor Logo
333 people viewed this question
Top Bruder Toys Experts
ptpumpman
Marc Taylor
Colin Stickland
Colin Stickland
Are you a Bruder Toy Expert? Answer questions, earn points and help others
